Gearbox Malfunction message on SID - SaabCentral Forums
Old 5th September 2011
stpoolshark's Avatar
stpoolshark stpoolshark is offline
My Saabs: 2004 9-3 linear
Default Gearbox Malfunction message on SID
As the title states- what could this mean and should I be worried. I turned the car off and back on multiple times to see if the message would go away, but no luck. I took a picture of the message with my phone incasr you all haven't seen the message before.
xp3's Avatar
xp3 xp3 is offline
My Saabs: '03 Saab 9-3 2.0t
Tech2 scan will answer your question.
I had the message once and it scared the c*** out of me
but turned out to be a short in the shifter which went away by itself.
I would probably disconnect the battery and drive around and if it still shows
up, have it scanned with Tech2
Current mods: 14t swap w/ JZW tune, GS Strut Brace, Aero front lip, 9-5 Aero turbine wheels,
(check out my for-sale-thread)
Coming soon: downpipe/exhaust, Aero body kit
My other SAAB is a car.
Old 6th September 2011
039-3arc 039-3arc is offline
My Saabs: '03 9-3 arc midnight blue
Garage
Could be a number of things, but for me this was bad news. I had to replace the transmission.
Get the code read and it will specify what exactly you've got going on. Good luck!
JonV JonV is offline
Saabista
My Saabs: 03 SE 5 Spd
Could be simple,could be catastrophic.... the Code is the Key.
cjamesqb8 cjamesqb8 is offline
My Saabs: 2003 9-3 Vector Limited Edition
Default Alternator
When this happen to me its was my alternator going bad, but of course the battery drained also and the car wouldn't start
Thanks for the feedback, everyone. Hopefully I can get it checked out soon. I'm about two hours away from home for school and I don't think that there are any Saab dealerships up here, but I know there is one back home. I haven't even found any garages here yet. I just got a CEL today and don't know what it's from so I'm going to go to advanced auto to borrow the code reader to see if that code is strange and something besides a vac leak. The car seems to drive fine and shift properly, but I'd rather be safe than sorry. I can't have another saab-story on my hands...
Saabista
Get the costs read at any auto parts store. Disconnect the negative battery terminal for about five minutes and see if things normal up. Have you been getting any other electrical glitches...like doors not opening, multiple warning lights on occasion would are predecessors of a failing battery?
The battery isn't too old. Probably about a year now at this point. I have been occassionally getting stability/traction control failure messages. Rarely will ABS lights come one. My driver door won't lock/unlock sometimes but I'm pretty sure that's an actuator problem. I can go have the battery tested and what not. I think I may have found a shop where I am that specializes in euro products. Again, thanks for the feedback.
Old 7th September 2011
gryffingirl gryffingirl is offline
My Saabs: Silver '04 Saab 9-3t
Like everyone said the code will tell the story. imo dont disconnect the battery, get the code read first than clear it. You DO NOT need a tech2 to read codes, maybe it can read some that normal reader cannot. Just stop at a parts store and have it read. Mine did that before and went away shortly. Almost a year later it happened and went into limp mode and stuck in 5th gear. Input speed sonsor went out, due to faulty o-ring in the radiator. A very common thing in 03-04's. good luck
Old 3rd October 2011
meisme33's Avatar
meisme33 meisme33 is offline
My Saabs: 03 9-3, BSR Stg 1, Optiflow, FSDs
Garage
I am very interested to hear back on what you find. That same message popped up yesterday on my car. I pulled it into the garage, where it will sit until I can go get the code read this weekend. I am hopeful that it is only the sensors or software. I'll report back as well when I know.
Old 5th October 2011
Default New Tranny it is!
After the car sat in the garage for about 3 weeks, I decided to make sure the code was the same as the last time--which indicated I needed a new input speed sensor (replaced that)... I made it to the parts store 3-4 miles..much to my surprise, it was a different code- P1743, Continuous Variable Transmission Clutch System Fail...then I was going to limp it home, made it about a mile and then the tranny started slipping, free revving and wouldn't make it up the hill. I coasted backwards onto a side street, called Saab and had it towed. A few days later, Saab informed me that I needed a new tranny. This all resulted in a $2,600 bill...and the car stayed at Saab for 2 weeks. I swear...this car better be done giving me trouble. We believe that this is all attributed to the faulty O-ring that allows coolant into the tranny, but Saab retracted the TSB about that issue and admits no fault.
Old 17th October 2011
meisme33's Avatar
Garage
So after letting it sit for a week in the garage, I went out yesterday to get the code read at the local parts store. I started the car... got the message. Then I realized I should look in the coolant tank to see if anything seemed awry... turned off the car, looked in the tank... nothing. Started the car back up and NO MESSAGE. Car drives and shifts just fine. Took it to get checked out anyway... no codes stored in the Tech II. Makes me a bit nervous though.
Anyone who had the message disappear and then suddenly get slapped with catastrophic failure?
Anyone who's message disappeared still driving along with no issues?
Should I get the shop to check out my tranny fluid while they change my oil?
I had the code a year ago and it went away for the entire year and came back. More than likely the Saab dealer is going to tell you that regardless of the TSB's there is no reason to suspect catastrophic failure and coolant in your tranny...even tho there are SEVERAL accounts on forums. They could care less about the forums..they think we are all idiots. Good luck trying to get them to check your fluid..most they will do is look at it..they will not do a test on it or anything. I tried that multiple times. They dicked around until the tranny did go and then I finally got it replaced. I concluded my vin number was one included in the range with the o-ring issue..perhaps you should check into that. If you have access to ALL DATA you can find the vin range. Next time, if you don't have a SID message or a CEL, don't bother taking it in for a Tech II reading as nothing should come up. You need the light to be on to pull a code. I know how you feel...like you are waiting for the other foot to drop. I got lucky that I purchased an aftermarket warranty, but if you add up all the deductibles on the random bs probs this car has given me, I've spent waaaay too much. Good luck.
Old 15th October 2015
chuuby199 chuuby199 is offline
New Member
My Saabs: saab 93 trbo 2.0t
Can anyone help me I have the same problem but the car won't even start anymore and I notic that gass and oil was coming out the back when I tried turning it on
Old 16th October 2015
smurkenstein's Avatar
smurkenstein smurkenstein is offline
My Saabs: 03 9-3 Aero
that doesn't sound very good - gas and oil from the engine or exhaust? did the you get the gearbox error show up once or has it been showing for a while?
I wouldn't start it up if there is gasoline leaking out. Accident waiting to happen.
New Member
It still has it when I try to turn it on but I don't even try to turn on anymore
Old 24th October 2015
gazo's Avatar
gazo gazo is offline
My Saabs: 9000
Default Gearbox Malfunction on and off
I got this Gearbox Malfunction warning again two days ago. Last time I had it, I had to get a whole new transmission because the coolant had leaked into the gearbox via a faulty heat exchanger. I took the car back to the mechanic who did that work and he jacked it up and checked the transmission oil and said that is definitely not the problem this time. Unfortunately, he didn't have time to read the codes as well and cannot book me in for another week.
So I drove the car (2003 9-3 Arc 2.0t) home and whatever he did under the car, the warning light was gone. I went for a long drive and no problems at all! Then my wife went for a drive and (predictably) the warning came back. I went to rescue her and drove it home: all the way, the gear changes were shaking the car, power was lower than usual (esp. uphill), and whenever I had to stop the engine cut out and had to be restarted (unless I kept the revs up).
Now I have left the car overnight and the warning is gone again! I went for a short drive and it feels OK at low speeds, but I am not game to hit the highway again. I am thinking maybe a sensor problem? But which one? I am thinking maybe crank position sensor, but how to know until the warning reappears and the code gets checked? Any ideas appreciated.
Diggs's Avatar
Diggs Diggs is online now
My Saabs: 2003 9³SS Linear
get the code(s) read
The answer is almost always....Tech2
Old 25th October 2015
SAABalingus's Avatar
SAABalingus SAABalingus is offline
My Saabs: Ltd. Edition 2008 Lynx Cabrio.
Sounds like the input or output sensor could be going in the gearbox, not a very expensive repair. But like Diggs said, get the codes checked.
gazo's Avatar
My Saabs: 9000
Code read: PO785 | 3-2 Shift Timing Solenoid Problem.
Mechanic says the solenoid is on it's way out. I was hoping it might be just a sensor.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Airbag Malfunction Message Coco's Owner 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 5 5th May 2010 01:37 PM
Airbag Malfunction Message Coco's Owner NG900 & OG9-3 Workshop 4 3rd August 2009 12:05 PM
sid message steering lock malfunction??? andyb983 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 9 28th June 2008 10:07 PM
Gearbox malfunction message on SID etsmiths 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 2 17th March 2004 08:59 PM
OnStar Malfunction Message snaab 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 5 4th April 2003 06:46 PM
