kick down cable route - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > Saab 9000 Workshop
Saab 9000 Workshop Saab 9000 (1985-1998) Technical Forum
Old 31-08-11
sp53 sp53 is offline
My Saabs: 1989 saab 9000 1992 9000 1993 9000
Default kick down cable route
Hi all I put the auto box into my 93 9000 with TCS and I am have some concern on the routing off the kick down cable on the trans. The cable travels in an almost loop to the KDW and there is some confusion on the brackets on the bell housing and frame. Does anyone know where I can find or have a picture of the cable in its correct position?
steve
Old 01-09-11
I have posted some pictures to try and explain what I mean. I have the tail end correct, but as the cable leaves the trans, I am not sure if it is routed correct the way I have it. There is a third removable bracket on the bell housing that looks like it should be used. All the information I can find is only for the 93 without the KDW.
Thanks steve
Old 01-09-11
chengny chengny is offline
My Saabs: 1996 9000 CSE 2.3 16v & 1997 CS 2.3 LPT
NOTE: Component identifier numbers used in the following illustrations relate to specific steps in the procedures below.
NOTE: This adjustment should be carried out before calibration.
  1. From transmission number 174150- a modified kick-down cable has been installed, with the end protector removed and better lubrication.
    • Around the same time (from chassis number P1020737), the bracket for the Kickdown Cable Motor (KDW motor) was reinforced.
    • If this reinforced bracket is used on older cars the omega clip should NOT be installed.
  1. Push the KDW motor lever fully away from the outer cable adjusting clip.
  2. Check that the lever reaches the mechanical stop on the KDW motor at the same time as the cable reaches its mechanical stop in the transmission.
    • If OK: Proceed to point 5.
    • If not OK: Proceed to point 4.
  1. Detach the outer cable clip and move the outer cable to comply with point 3.
    • Then proceed to point 5.
  1. Check that the cable and its casing are straight.
    • If necessary, the cable casing.holder is bent so that the cable and cable casing are aligned.
Old 02-09-11
Wow Chengy I am impressed, where did you find that? It even comes with instructions on how to set the cable. I am very grateful. You must have access to factory manuals. That settles that big issue about cable adjustment. I think I might have figured out the problem I was having with the cable on the other end as it leaves the trans case. Near as I can figure, the one cable clip I was concerned about fits the vehicles without the KDW and was on the Bell housing (perhaps this trans is not the original). Anyways, I say that because the bracket is on the other car I have without KDW and I cannot see how it could work on a KDW system. If I do this again, I am taking pictures.
Steve
Similar Threads
kick down shift cable adjustment help pmcag Classic Saab 900 Workshop 25 06-08-12 06:30 PM
route finder for usa patrick2536 The Lounge 3 03-05-06 06:46 AM
CD Changer Cable route demonreedler Saab 9-3 & NG900 Workshop 4 27-10-04 12:07 PM
ppc upgrade route nphobb01 Saab 9-5 Performance, Mods & Tuning 1 02-08-04 04:07 PM
Kick down Cable? Saab newbee Classic Saab 900 Workshop 7 13-12-02 08:33 PM
