Horn won't honk - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > 9000 Workshop
9000 Workshop 9000 (1985-1998) Technical Forum
Old 30th August 2011
Pratt Pratt is offline
My Saabs: 1993 9000 CSE 2.3L Turbo
Default Horn won't honk
So my horn has never worked ever since I got my car. I need to get my car inspected this week, and need a working horn to pass. When I push the horn button the relay clicks but nothing goes beep. I assume there is no power getting to the horns, I hooked them directly to the battery and they work..
Any thoughts? I have tried a different relay.
Jope's Avatar
Jope Jope is offline
My Saabs: 900 Turbo Finlandia 1982
Replace the fuse for the horn.
If the fuse is ok, do a continuity check between the fuse holder and the horn's plus cable.
9000 CC 2.3T '92/96 | 900 4D Finlandia T16A '82/90
Thank you for the advice. But I'm unsure how to do a continuity test, do you mean ohms? Could this be done with a test light, for I have no multi-meter.
Jope's Avatar
I take it you already tried it with an intact fuse?
One option could be to just wire up a light bulb in place of the horn, see if it comes on when you press the button..
Superaero Superaero is offline
My Saabs: 1997 Aero manual
Bad ground at the horn? More likely just a failed relay.
Ok I have tried multiple relays, with no change. I couldn't for the life of me find a fuse for it. And my test light is telling me that there is no power to the connector... ever. So there must be a broken wire somewhere in the miles of wiring.
Old 31st August 2011
bc109 bc109 is offline
My Saabs: 9000 2.3CSE;9000 2.0CD
Default Horn fuse
Don't know if 1993 car has same wiring as 1997.
According to wiring diag:
Look for fuse number 10, 25 Amp in box in front of battery.
Brown wire to horns.
This is the "take action" side of the relay. So if the relay operates, a circuit is made to send power to the horns. This power comes via fuse 10, through the relay to a brown wire connected to the horns. The earth side is via the chassis, near the horns "left front structural member" black wire.
Yeah there is one brown and one black going to the horns. I will be sure to check that fuse. It seems dumb that the fuses aren't marked that well, or maybe the words have been rubbed off my cover. Either way I bet that is my problem, there is actually a fuse missing from that box.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Honk when doors are locked/unlocked. Filbert 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 9 26th February 2009 08:25 PM
Help! Just Installed MBC, Runs Rich, Hits Fuel Cut Off, BOV Honk, CEL suicide bobb NG900 & OG9-3 Workshop 2 9th December 2008 03:11 AM
95 CS9000 horn honk lights blink when lock suddenly jcoplan 9000 Workshop 4 19th November 2006 04:33 AM
Honk Honk...? bettykid NG900 & OG9-3 Workshop 1 30th November 2005 03:34 PM
New owner questions: make keyless entry not honk, CD changer cartridge etc.? Darmok NG900 & OG9-3 Workshop 4 22nd March 2005 01:41 PM
