Lightening Up Our Overweight NG900/9-3s - SaabCentral Forums
Go Back   SaabCentral Forums > Saab NG900, 1994-1998 and OG9-3, 1999-2002 & '03 Convertible (NG=new gen/OG=old gen) > NG900 & OG9-3 Performance, Mods & Tuning
NG900 & OG9-3 Performance, Mods & Tuning Covers Tuning & Performance modifications for the NG900 (1994 to 1998) & OG9-3 (1999-2002) & '03 Convertible
Old 24th August 2011
monza2t's Avatar
monza2t monza2t is offline
My Saabs: 1999 9-3, 62 Austin Mini
Default Lightening Up Our Overweight NG900/9-3s
Ok, so our cars are sort of overweight. My particular car has a published weight of 2990, which IMHO is about 300+ lbs more than it should be. Yeah, I know its a 'premium' car with lots of fancy stuff.
So, obvious removal items aside (like the 32lb spare tire/ jack) what non-critical items can be removed without compromising the 'look', or safety of the car? I dont care if it gets a little noisier.
Fog lights are one example of what Im talking about. The ones I have are worthless from a functional standpoint. 3-4lbs.
Headlamp washers are silly. I already removed mine and sold them on Ebay (made $50) and they weighed 4lbs.
Dont think I can take out the AC. For one it works, two I live in the Midwest and the defrost feature is key in the winter.
Lightweight battery is a 20lb savings.
Now Im up to 20+32+4+4=60lbs in just those small things.
I dont have power seats, but I do have a sunroof (superflourous item I dont use, and its going to start leaking sometime soon anyway). Whats the weight on that item? I dont mind welding in some metal and re-painting the roof.
Its all the little junk that adds up. On a previous car I had (MINI Cooper S) I removed all sorts of useless crap and reduced it 200lbs and it still looked the same inside and out.
And please dont reply if you dont have anything constructive to add to the conversation. I dont care that I dont have a spare, I pay $100+/yr for AAA, I can get a tow if I have a flat. No, this isnt a track car, othewise I would just strip the hell out of it.
'99 9-3 Stg 4 Combi Coupe, 6x,000 miles
'08 328i Sport/Prem
'62 Austin Mini - '63 Vespa 150
lms's Avatar
lms lms is offline
You mention nothing about why you want to save weight, so why?
monza2t's Avatar
The most effective 'horsepower' increase is through the reduction of weight. Plus, handling, fuel econ, etc... a lighter car is just more efficient.
'08 328i Sport/Prem
'97 Saab SE Turbo's Avatar
'97 Saab SE Turbo '97 Saab SE Turbo is offline
Saabista
My Saabs: Black on black '97 Saab 3-door SE Turbo
Since you pulled the headlight wipers, pull the pump and reservoir. A gallon of wiper fluid has to weigh 7 lbs by itself. Did you also pull the rear wiper? That's another few pounds... Ron
monza2t's Avatar
Good one. In 2 years I have rarely used the rear wiper. Plus its ugly.
Power antenna too. I dont even listen to radio, I have a dedicated iPOD for my car, and if I wanted to listen to radio, my iPOD has a tuner
'08 328i Sport/Prem
straycatkid's Avatar
straycatkid straycatkid is offline
My Saabs: '98 900SE 5-spd, 5-door
I actually use my rear wiper pretty often, couldn't imagine getting rid of it. The headlight wipers on other hand...
The pad or whatever it should be called underneath the hood, that'd be something easy to ditch. Obviously this is fairly expensive, but some light weight wheels would help, too. Not sure what else you could pull, especially if you like your A/C.
pitman pitman is offline
My Saabs: 900se with b234r stage 3
take out stereo, speakers and wires. change glass to lexan, race rims/tires. gut interior and sound dending material. only need one race seat, if you have a sun roof remove that whole assembly and use lexan, maybe go on a diet. drive it with less gas in tank. 8lbs a gallon. swap power seats for manual seats. make it remote control. vaccum it. thats all i got
I Just Saved An Bunch Of Money By Fleeing An Scene Of An Car Accident. That's Better Then Geico!
monza2t's Avatar
Yeah, that pad probably is 2lb.
Already have some lightweight, but practical tires and wheels. Wish I had written down the weight savings. It was pretty significant, plus it was unsprung weight.
Mentioned before it has to be a daily ride and cant look significantly different. If it was a track car I would gut it.
Im seriously looking at that. The sunroof assy from my MINI weighed almost 50lbs. Its easy to weld in some metal or make a permanent lexan moon roof that doesnt open.
maybe go on a diet.
HA! I might waste away to nothing then... already @ 155
'08 328i Sport/Prem
monza2t's Avatar
BTW, someone PM'ed me (wont say who because it doesnt matter) but they had concerns I would hurt the value of my car. While it is in immaculate condition and only has 58,000 miles on it, the book value is $2600. Is taking off the rear wiper and fog lights going to appreciably hurt the value? No.
'08 328i Sport/Prem
Saabista
Just put all the stuff you take off in a box and then put it in the trunk when you sell the car... Ron
monza2t's Avatar
So was looking at the removal of the antenna...
$50 for a plastic plug?!?
http://www.genuinesaab.com/catalog/p...807781dc9bc868
'08 328i Sport/Prem
monza2t's Avatar
Im actually going to sell all the good working stuff on ebay. I plan to keep the car until it falls apart, and with 58,000 miles on it that will be a long time, at which time it will be worth nothing
'08 328i Sport/Prem
ya i agree on the plastic plug for 50+ waste of money. if you would weld in the sunroof just weld the hole from antena. or make your own plug
monza2t's Avatar
any excuse to use my MIG welder is wecome
'08 328i Sport/Prem
BobSaabit's Avatar
BobSaabit BobSaabit is offline
Saabista
My Saabs: '97 NG900 'vert; '03 OG 9 'vert
Two door or four door? If it's four door, remove the rear power window motors. That's at least 20 lbs. Power locks can go too. Truck lining material if it's not a hatchback. You could pull the carpets and paint the floors, although that might leave a lot of stuff exposed you don't want showing.
Meanwhile, I think you're nuts... the minimal savings aren't going to make an appreciable difference and you'll have much less valuable and less enjoyable vehicle when done. Just run your tank on 1/4 all the time if you care that much about weight. Put your time into the ecuproject and building an "economy tune" if you want to save gas.
bikerchris's Avatar
bikerchris bikerchris is offline
My Saabs: 2002 9-3 SE
2990 lbs sure isn't overweight. A 2011 Saab 9-3 weight 3210 lbs. Be happy.
TwinCam TwinCam is offline
My Saabs: '99 9-3
I can't see owning a Saab and removing all the items that kind of make it Saab (like the headlight wipers)
Unless of course you're going full blown weight reduction, seats, windows and all.
Though I will admit, she is a bit of fatty.
AWD Matrix weighs less than the Saab.
I'm sure Turbo, oil cooler, intercooler, and all the accompanying lines add a bit of weight.
BobSaabit's Avatar
Saabista
Not to mention, the sheet metal is about twice as thick as the Matrix, and there's significantly more structure underneath. There's a reason people walk away from major Saab accidents.
Old 25th August 2011
My Saabs: '99 9-3
This is good to know, now I feel even safer in it
lms's Avatar
lms lms is offline
I don't see the point if this is a street car, and this is coming from a guy that has another car that was stripped for lightness due to racing/auto-x. Unless you remove all the seats, except the drivers, replace with fiber glass, strip out the supports on the front hood, rear trunk, panels on the doors, stereo, etc... then removing just the wiper crap is chump change. When I was really into this, drivers would literally try to drop weight before an auto-x which to me was really a joke. But if you really are into this post the weight of you and the car on a truck scale before and after, then let us know how much gas you are saving and how much faster your car is.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
lightening the 9-5 guitarguydudeperson34 9-5 Performance, Mods & Tuning 59 7th February 2007 04:10 AM
White Lightening Willy Wonka The Lounge 4 4th September 2005 10:51 PM
Flywheel Lightening Nuts C900 Performance, Mods & Tuning 16 27th September 2004 08:42 PM
Lightening the flywheel Kirkpatrick C900 Performance, Mods & Tuning 2 14th January 2004 08:31 PM
Improving the lightening ? niko C900 Performance, Mods & Tuning 22 1st December 2003 11:42 PM
