C900 5 Speed Gearbox Rebuild - Nutcase Style - Page 17 - SaabCentral Forums
Old 20-04-12
peva peva is offline
My Saabs: '94 T16 Ruby 3dr, '93 T16 Ruby Vert.
Originally Posted by spg1 View Post
One thing I thought as well, a foundry should be able to pour a cast steel casing and since we already have good castings to take a mold from, it should be possible. Im surprised no one has done this.
You make it sound easy. Trust me it's not. I have some experience in this and it's a lot more involved than you think, and that's why no one has done it.
Old 20-04-12
S900t8v's Avatar
S900t8v S900t8v is offline
My Saabs: Trionic 5.5 1984 900t 8v
Garage
This would make sense since with my 89 I can still drive it forward with no problems, but forget going in reverse. Too bad they didn't use two large bearings instead of one. One thing I thought as well, a foundry should be able to pour a cast steel casing and since we already have good castings to take a mold from, it should be possible. Im surprised no one has done this.
The weight of cast steel on the fasteners would be huge?
Old 20-04-12
S900t8v's Avatar
Garage
Originally Posted by nutcase View Post
As I understand it, the 89- pinion bearing housing is as strong as the -88 8720732 Chilcast housing. Prior to that there was a sandcast unit (8720239 I think) and prior to that a die cast unit that is failure prone (possibly 8704215). Of those three the chillcast is the desired part. Not sure exactly when it was introduced, but the sandcast one came in some time in 1982 so not long after that as it wasn't used for a while. When older boxes came in for refurb the die cast housing was replaced as a matter of course (if Saab's instructions were followed!).
The larger rear bearing on the 1989- pinions give a longetivity improvement. Some have suggested however that some of the other bearings in the box get the chance to wear more in the mean time causing more damage than if the bearings are changed when the older style pinion bearings start to whine. Not sure on that one though
Not sure where you got that info from? You can mix and match like for like between boxes.
Nutcase I mean you can't mix cluster gears between different revisions. Yes you can use any from same revision 88 and earlier. 89/90. And 91+. You can't mix between these without changing gearset.
Old 21-04-12
nutcase's Avatar
nutcase nutcase is offline
My Saabs: 1978 99T in black; 1983 99GL in Beige
Sorry, misread what you put
Photo Gallery
Old 22-04-12
Nice to see your stuff on eBay Nutcase. Well done and good luck. Paul
Old 22-04-12
nutcase's Avatar
Trying to raise some pennies after spending far too much on tools and bits
Photo Gallery
Old 22-04-12
crwchf01 crwchf01 is offline
My Saabs: Menagerie of 14 and climbing
If they are what you need, you can NEVER spend too much on tools and bits, but may bust your available budget
It's too late for blind faith and ignorance.... gotta get a bigger hammer.
Old 22-04-12
spg1 spg1 is offline
My Saabs: 1989 Saab spg, 2008 Aero 95
Can you give a link to your parts for sale?
Old 22-04-12
S900t8v's Avatar
Garage
http://myworld.ebay.com.au/nutcase_1...id=p4340.l2559
Old 22-04-12
It's actually this; http://www.ebay.com.au/sch/nutcase_1...&_trksid=p3686
Old 22-04-12
S900t8v's Avatar
Garage
close enough smarty pants
Old 22-04-12
nutcase's Avatar
Everything is up for roughly what I paid for it, with import tax etc. postage etc. except the cluster shaft which was made for me here
Photo Gallery
Old 22-04-12
Going through the documents I have, the non-moly synchros are compatible with the 2nd-3rd gears. The moly coating was to prevent wear, but I think we kill pinion bearings long before this becomes an issue, at least for us conservative drivers.
Old 22-04-12
nutcase's Avatar
Conservative eh?
That is as I understand it
Photo Gallery
Old 22-04-12
Conservative eh?
Don't miss shift and don't try to smoke tires at start is conservative in my book. Accelleration after full engagement and nice twisty roads ARE conservative in my book. Saab never had a really good scatter shield ever developed for truly aggressive drivers. For those who are scratching heads- check National Hot Rod Association rules and regs.
Old 22-04-12
nutcase's Avatar
True
Photo Gallery
Old 27-05-12
AJs900Turbo AJs900Turbo is offline
My Saabs: 1988 SAAB 900 SPG
Question Installation Question
Is it possible to install the input shaft after installing the 5th cluster gear?
Old 27-05-12
nutcase's Avatar
No, the hub that the synchro fits over is in the way. Do you have the diff in? If not it's easy to remove the locking plate and then tap the layshaft out enough to free 5th.
Photo Gallery
Old 27-05-12
Thumbs up Thanks...
...good to know as I was planning on putting the diff and everything in minus the input and primaries. Now I know not to do that, thanks.
Old 27-05-12
nutcase's Avatar
Primaries can go on pretty much last of all, still need the side cover for 5th off to allow you to get it into 2 gears at once.
Photo Gallery
Similar Threads
Gearbox rebuild kit - anyone used? lux95 Saab 9-5 Workshop 7 03-03-11 07:04 PM
did the C900 ever come out with a 4 speed manual gearbox? ludichris001 Classic Saab 900 Workshop 24 19-06-09 01:33 AM
Gearbox rebuild Dead Centre Saab 9-3 & NG900 Workshop 0 06-04-04 05:34 PM
Gearbox rebuild ejenner Classic Saab 900 Workshop 1 17-02-04 04:57 PM
Gearbox Rebuild Deanosabby Classic Saab 900 Workshop 1 30-08-03 12:53 PM
