1987 SPG project - Page 9 - SaabCentral Forums
Go Back   SaabCentral Forums > Classic Saab 900, 1979-1993 & 94 Convertible > Classic Saab 900 Performance, Mods & Tuning > Project 900 Cars
Project 900 Cars For ongoing threads concerning project classic 900 Saabs
Old 01-07-12
Krizzie's Avatar
Krizzie Krizzie is offline
My Saabs: White MY91 900S Aero
Garage
If you get the regular bumpstops and put a longer bolt with a bushing of somesort in it your pretty much there.
I ordered a custom set which someone here in Holland made. But I think you can easily make them for yourself seeing how handy you are.
Here are some pics of them:
Normally you have the metal bushing between the chassis and the bumpstop
Old 01-07-12
Malko's Avatar
Malko Malko is offline
My Saabs: 2008 Turbo X & 1987 Lime Yellow SPG
would anyone like to donate (or i can buy) 3 of these hatch shock retaining clips, i can't find them at a hardware store, auto store, or junkyard. pm me!
Old 09-07-12
QuickOrange's Avatar
QuickOrange QuickOrange is offline
My Saabs: '92 900S, '93 900 Turbo Vert
I used a circlip on mine. Cost a couple pennies each at Home Depot, works perfect.
'93 Saab 900 Turbo Vert: New project...
'92 Saab 900 S: My first 900 and what a beauty
'90 Chevy 1500, Stepside: Ongoing project, future recipient of a 400HP LS2
'00 Kawasaki Ninja 500R
Old 12-07-12
Malko's Avatar
more progress!!! after starting the whaletail foam surround, i have been focusing on the mechanical aspect rather than aesthetics so i can get it up to scanwest and get the last few things done to get it running and work on the interior things later. i got some tires, got 2 wheel back from the powder coater a lot of the wiring is completed including the battery tray and power/ground is complete. i checked the grounds at the front of the spg and everything works and grounds out just fine! also ended up using the circlips (thanks to quickorange)for the hatch shocks. enjoy some more pictures!
scanwest is going to sort out the rear brakes for me as well as shift linkage, bleeding the clutch and brakes, and final wiring, timing, and the initial start up! plan on dropping it off the first week of august once i button up a few more things.
after scanwest i'll bring it to get aligned to sort out the steering rack and make sure all the suspension is nice and straight for the new tires and everything
by that time i'll have it driving and slowly piece together the inside
Old 22-07-12
About how much paint did it take to cover the exterior? I'm trying to estimate the cost of a paint job, but I wasn't sure if a gallon would be enough.
Old 22-07-12
Malko's Avatar
I think I used 3 quarts of color, 2 quarts epoxy sealer, 4 quarts of clear, I used a epoxy grey green sealer coat as my base so the color covered well, I did 3 coats of color cause it was pretty light
Old 22-07-12
Cool, thanks! I'm looking at a nice single stage, and at this rate, I think my prep supplies are going to cost more than the paint itself.
Old 22-07-12
Malko's Avatar
After everything I was about 650-750 in materials at my shop prices single stage is nice though!
Old 22-07-12
I definitely won't end up with as nice a product as you, I just want to get it looking halfway decent and not have to worry about rust.
Old 05-08-12
Malko's Avatar
update!!!! :
spg kit is fully fastened (minus front bumper and doors [still off] and fore most front fender panels [i need to keep them off so it clears the tow dolly] had mostly new bolts that i painted black and new speed nuts
rear and quarter glass (edges trim blacked) is in after lots of tint scraping and adhesive removal
+ battery cable from back is ran to distribution block next to shifter and the - is all grounded in the back and carries ground to the front everywhere i checked !!
tail lights are sanded down again and ready to be tinted (shaved the branding on them)
tail light housings and bumper trim are trim blacked (in satin)
new vinyl on the lower part of the hatch (will paint eventually)
painted the rear portion of the carpet
have other 2 tires will mount monday or tuesday and get it on the ground!
ordered intercooler & some install components, downpipe, silicon vacuum hose kit.
will finish the front portion of the carpet, and buy new sound deadener to replace the once coolant soaked foam
also need to scrape off the door window tint
more to come soon!!!!!!!!!
*****help, what is the order or the wiring for the lights on the hatch? there is a green, black, and red which goes where? thanks!
Old 06-08-12
dmgb5's Avatar
dmgb5 dmgb5 is offline
Moderator
My Saabs: '89 900 T16Spg, '97 9000 Aero
In case you didn't figure it out yet...
ID:	30798   Click image for larger version
Old 07-08-12
Malko's Avatar
now on the ground! hoping it will go down 3/4" -1" after the new shocks settle in and the springs and once everything is put back on. a few last things i need to wrap up before i bring it to scanwest next week so they can get it all fired up!
Old 08-08-12
Squaab99t's Avatar
Squaab99t Squaab99t is offline
My Saabs: '89 900t 4dr '78 99t 3dr '76 99ems 16vt
Default Looking awesome
You have a lot of weight you have not added back on the car. Hood, Windsheild, seats, I'd guess at 150 lbs. She will sit lower.
Love to see the car in person. We are have a dyno day Sept 1 are R&H garage. You can run, but you don't have to. You are more than welcome to come visit and cheer on your fellow enthusiast. Might have to bring some napkins for all the drool when folks check our your ride.
Old 08-08-12
Malko's Avatar
i'll try to put something together for the 1st! i would love to drive it for the first time in a looong time! almost there gotta keep chuggin along!! i figure between the doors, windshield, spare tire & stuff, interior, fluids, hood, sunroof i'll add more than more than just 150 pounds! looking forward to start showing her off though!
Old 09-08-12
AUSSIE900 AUSSIE900 is offline
My Saabs: 89 900 AERO, 88 900 Aero , 93 900 Aero
Default Looking Absolutely ..... AWESOME
Amazed at the job you have done to date , absolute credit to you.
U copped a bit of flack early days re color , but boy its coming together well .
Love the dark accents ( bumper inserts and tail light tints ) One very unique quality car , without being ricey or Bling ...
Top job .
Curious on the SPG panels as I am fitting some up now to a vert , did you use any edge moulding between the skirt and the panel ? Cant pick in the pictures .
Old 10-08-12
Malko's Avatar
I did use foam between the panels and the body, I'll post some picture of it next time I take some!
But thanks for the love, some people hated the lime yellow but I love it its all coming together when all the trim and what not I did in satin is put on.
Old 10-08-12
rawill's Avatar
rawill rawill is online now
My Saabs: 97 9000CD,93 9000griffin 92 900s LPT vrt
Yes looking real good, and the colour makes a real good statement.
03 V6 Renault Laguna! 97 9000CD 2.3 St I-T7mod. (to be sold) 93 9000 griffin 2.3 St-II. 93 9000CSI na man. 92 900 S LPT vert.
Old 10-08-12
ejenner's Avatar
ejenner ejenner is offline
Banned
My Saabs: 900 Carlsson, 99t, 99 T16, 900 t16 vert
here is the progress on the motor
Missed this project. I must have been spending too much time over on the other forum (link below ) - Your car looks awesome. I think these colours which have a sort of light metalic quality like what you've chosen and the prototype SPG colour are really good for the shape of the 900 / 99.
One question, in the photo showing the transmission from the front, what is that sensor which has been screwed into the hole for the 5th gear peg and what are you going to use it for?
Old 10-08-12
spg1 spg1 is offline
My Saabs: 1989 Saab spg, 2008 Aero 95
I was going to ask the same question. Funny, if there is something out of the norm, you pick it up right away.
Old 10-08-12
Malko's Avatar
i have no idea it was out of the ordinary, it was just there when i got the car, i'll ask scanwest thursday!!!!!!!
Similar Threads
1987 8v na 3dr SteveTheFolkie Cars for Sale - North America 9 19-10-10 11:09 AM
My 1987 900 SteveTheFolkie Classic Saab 900 Workshop 1 11-04-10 01:03 AM
For Sale: Parting out 1987 SPG lancer Parts for Sale/Wanted - North America 60 24-07-09 09:03 AM
1987 900 turbo BABE Rally project slickdizzy Project 900 Cars 1 19-01-09 09:25 PM
Uma: 1987 Saab 900T project mikewitdaspike Project 900 Cars 10 02-07-07 10:42 PM
