1987 SPG project - SaabCentral Forums
Go Back   SaabCentral Forums > Saab C900, 1979-1993 & '94 Convertible (C=classic) > C900 Performance, Mods & Tuning > C900 Projects
C900 Projects For ongoing threads concerning classic 900 projects
Old 9th August 2011
Malko's Avatar
Malko Malko is offline
My Saabs: 2008 Turbo X & 1987 Lime Yellow SPG
Default 1987 SPG project
purchased a 1987 spg in summer of 2009 for $300 in a non running condition. i did a few things and got it running the night i brought it home. it leaked oil, ticked like crazy, and had a gearbox in poor condition. i started taking it apart the summer of 2010 and i pulled the motor and everything in the engine bay. i am going to paint the car (including the SPG kit) saab's lime metallic yellow and use satin black to everything else. the engine has transmission and head have been completely rebuild by scanwest in seattle. these guys are all saab nuts and were well worth the $. it has taken a long time to accumulate everything being a full time student and finding the time to work on it. i bought a 1990 spg as a parts car in 2011, i need lots of miscellaneous parts so this was perfect. as of right now the car is pretty taken apart and in primer, needs a couple more dings filled then she will be ready to be painted. i have taken a lot of pictures but have had 3 phones in the mean time so a lot has been lost. here are some current pictures.
Old 9th August 2011
Malko's Avatar
for paint i shaved the antenna hole, i pulled the handles, locks, mirrors, i will be pulling the glass, doors, lights, spg kit, bumpers, the engine bay is completely disassembled and the bottom of the engine bay has been painted with por-15 before primer and paint to prevent any possible rust. i blocked the whole thing by hand with 150 at first, then after i primed it i started to block it again with 220 and filled the smaller dings that were not spotted in the initial once over.
to finish paint prep is must finish blocking the sides then hit everything with 400 grit on the DA sander. i will be sealing everything with a light colored epoxy primer then the base coat lime metallic yellow, then clear. this will be followed by a wet sand and buff to remove any orange peel.
Old 9th August 2011
Malko's Avatar
i have bought all new bushings, lots of sensors, gaskets, rebuilt the drive train, new water pump, timing chain & guides, seals, lots of new hardware including manifold & exhaust hardware. every thing that was not new has been disassembled and scrubbed clean. i bought a stage 1 spec clutch since i plan on about 230hp to the wheels for my daily driver ( i wanna keep the miles low on my turbo x i just picked up!!) i also bought a water/meth kit so i am not sure how this will play into the power, should work quite well. so all the long hard expensive work has been done now i just need to paint it and start the assembly process, and drive it until i can get the interior done.
from the 1990 i am using the whale tail side vent covers, hubs and upgraded brake assembly in respect to the 87's w/o the abs stuff though. i will also be scavenging and keeping some engine stuff for future maintenance and to replace some of the parts i think are worn. it is also nice to have a running diagram since it has been a few years since i took it apart.
the attached picture is a fine coat of bondo to cover the scratches from the course bondo bodywork
Old 9th August 2011
Malko's Avatar
i am going to finish the bodywork and get it cleaned up this weekend and post some more pictures. if you guys have any questions about what i have done so far or what i am doing feel free to ask i am pretty handy. i also have a gang of extra parts so pm me if you need something i will let it go for pretty cheap.
the gray car is my project one before body work, the black one is parts (no whale tail available!)
Old 10th August 2011
SPGreg's Avatar
SPGreg SPGreg is offline
My Saabs: Down to one SPG (black '90)
Garage
Wow, lots of work, well done!
Old 11th August 2011
Malko's Avatar
thank you! i have spilled a lot of time and a lot of $ into this project, i just can't wait to get some color down, i have the paint now but now i just need to dedicate my weekend to shootin it out after finishing taking the doors and glass off/out. hopefully by sunday i will have some parts sprayed out and more pictures to post, i will post a picture of my clutch when it comes
Old 16th August 2011
Malko's Avatar
more primer today on some random pieces, pulled the doors, rear windows, and gaskets. tomorrow i need to finish the passenger side gutter end mod i did, i thought this would look better than the caps. i'll grab some pictures tomorrow when they are completed. also i have started the re-assembly of the drive train assembly. tomorrow i plan to paint some color on some pieces to get a taste of the lime metallic yellow!
tomorrow i need to finish the bodywork on the hatch, pull the steering rack and firewall heat shield (the rivets are out) pull the rear hatch and window, prime any other spots that need it and finish the fiberglass part of the whale tail and prime that( i fixed the cracks with fiberglass epoxy), the rubber strip will be a bit more involved.
Old 19th August 2011
Malko's Avatar
got bored @ work today waiting for bondo to try so i decided i wanted to see some color that is going on the spg. sprayed out the vents in the new car color (lime metallic yellow) for the whole car hand blocked, filled, sanding primer, blocked, sanded down with 400 (red scotch brite in the jambs and hard to get places) epoxy primer, color, clear. hope you guys like!
Old 20th August 2011
88saab900s's Avatar
88saab900s 88saab900s is offline
My Saabs: 1990 talladega SPG
Garage
cant wait to see the final project! that lime metallic yellow will really pop out
Malko's Avatar
when i initially sprayed out the paint it was blinding in the sun really yellow with green flake that just popped, when it dried out before clear it really mellowed out and became more lime green with yellow flake. i was a little nervous to see if i would like this paint, but i love it. very different flops and fades, i cant wait to get it on the body over some contours to see the range of color within the paint. my goal is to have the front end painted by wednesday. i need to take out the a-arms and brake lines to get a quality job. while everything is out i will replace the inner sway bar bushings, a arm bushings, power steering rack bushings, and maybe start the hub swap from the 90 to the 87.i need to be careful spraying in those fenders.
Old 25th August 2011
Malko's Avatar
more progress,
Malko's Avatar
here is the progress on the motor
li Arc's Avatar
li Arc li Arc is offline
My Saabs: '85 900 T16 Sedan
Garage
Fantastic paint job! I'm always leery of painting in the garage, there's always dust that flies around. But without a paint booth, that's pretty impressive...is it done with cans or with a proper HVLP setup? Maybe I should invest in one, even with the occasional amount of painting I do...
li Arc
Old 27th August 2011
Malko's Avatar
The garage is set up with the right ventilation and fans, there is a legit paint gun set up with multiple water vapor filters and what not. I used PPG dbc (the best PPG base coat) and clear all PPG products are being used.
Old 3rd September 2011
Turbofun_907 Turbofun_907 is offline
My Saabs: 2006 Saab 9-3 Aero Vert 6mt
lets see a pic of the finished product!
Malko's Avatar
patience my friend! my dad helped me sand a lot of the car today while i tucked away some things in the engine bay. tomorrow i just need to do some minor scuffing with a red scotchbrite, mask and i will paint the body of the car. there will be many before and after pictures from every angle, i'll bring a nice camera instead of my phone. stay posted!!!!!!!!
Old 4th September 2011
B202NUT B202NUT is offline
Banned
My Saabs: 1992 900S // 1991 Turbo Vert SE
and please make them smaller (the pictures); I need an IMAX screen to see your work
spg1 spg1 is offline
My Saabs: 2008 Aero 95
Very nice work, can't wait to see the final product. I love this color, and the pictures look great on my end. now that you have painted the parts and put up the pictures, does the color look the same on your computer screen as the color on the car?
The reason I ask is there are times where the camera sees the color on the car differently and also how we see it on our monitors.
Malko's Avatar
SO! today i stated at 10:45 and quit at 4:45
i pulled the front windshield and got rid of all the nasty goop around that so my lime yellow paint will not react with the silicon
pulled the sunroof, sanded and cleaned what you see when the sunroof is open, so the color change looks nice and complete
pulled a few more things that i forget of, but then i masked the doors, rear quarter windows, where the hatch goes, windshield, sunroof, any random holes in the fire wall and fenders that expose themselves into the cab.
then i got to sand more and more and more and more in all the little places a DA could not reach.
i took pics on a high resolution camera, but i am waiting to upload the pics until tomorrow when some (and by some i mean a lot) of color goes down.
before i left the shop, i wiped everything down with DX330 (wax&grease remover) twice so that i could do it again in the morning to get everything. i found a few more spots i need to sand then tomorrow i can epoxy the car in the morning, come back in the afternoon, tack the car down and spray some color, then do the clear!
Malko's Avatar
in the pictures the paint looks gold, but in person the color is very nice, looks like the inside of a lime with yellow metallic in it, i think the pictures will be better when i get some color on the car tomorrow and have it out in the sun
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
1987 8v na 3dr SteveTheFolkie Cars for Sale - North America 9 19th October 2010 12:09 PM
My 1987 900 SteveTheFolkie C900 Workshop 1 11th April 2010 02:03 AM
For Sale: Parting out 1987 SPG lancer Parts for Sale/Wanted - North America 60 24th July 2009 10:03 AM
1987 900 turbo BABE Rally project slickdizzy C900 Projects 1 19th January 2009 10:25 PM
Uma: 1987 Saab 900T project mikewitdaspike C900 Projects 10 2nd July 2007 11:42 PM
