cutting the front bumper support.. how much body integrity depends on it?? - SaabCentral Forums
Old 03-08-11
geck0 geck0 is offline
My Saabs: 1999 9-5 lpt stage 3+
Exclamation cutting the front bumper support.. how much body integrity depends on it??
I'm mounting a rather large front mount intercooler on my modified 1999 9-5. To fit it i'll need to shave the front bumper (the steel bumper welded to the frame rails) I will need to trim all but the upper portion where the plastic bumper slides in and the back side of it (basically if you cut the bumper in half side to side it would look like a upside down L with the back of the L being on the engine side) This cut will be shaving a section in the center of the bumper about 2.5 feet wide.
I'm just don't know how much the car relies on this bumper for the integrity of the cars front end.
Old 03-08-11
xbriansg36x's Avatar
xbriansg36x xbriansg36x is online now
My Saabs: 2001 Saab 9-5 V6 Stage 3 :)
I was going to do that but was told in a crash it would be incredibly dangerous and that it would compromise a lot of integrity.
Sent from my Autoguide iPad app
Old 03-08-11
Jssaab Jssaab is online now
My Saabs: 2000 9-5 320hp, 2003 Aero Hirsch "Clone"
You will destroy the car and likely your life in a front end collision
Old 03-08-11
I'm more worried about body flex or twisting. As for a wreck mines 200k miles totalled is totalled
Old 03-08-11
Totaled is totaled for the car sure. It's totaling yourself we're worried about.
Old 03-08-11
What about just shaving the lower edge??
Old 03-08-11
Its a box beam, remove the box and its useless.
Why is your IC so much bigger than anyone elses? I run 300WHP with a drop in ETs others have run 450 hp with the IC up under the bumper support
If yor IC is too big (es its possible) it will take you tie to spool while it loads with air to pressurize. Unless you are using liek a 80 CM compressor side...
Old 03-08-11
I'm. Having no issue with lag I'm having a heat issue above 80 degrees cut out at full boost 20psi nordic just above stage 3 ecu 3in downpipe no cat with TD04-15hl turbo head ported mani's ported 4 angle valve job. It seems heat is my only issue
Similar Threads
Wanted: Front bumper, hood, headlight, radiator,radiator support Viggen93 Parts for Sale/Wanted - North America 1 01-02-11 11:20 PM
Body Question (Front bumper) SaabNineThree Saab 9-5 Workshop 7 04-04-09 08:23 AM
Front bumper support/foam SAABturboDRIVR Saab 9-3 & NG900 Workshop 6 19-12-08 06:57 PM
Bumper Support Bar Compatibility? ubermich Classic Saab 900 Workshop 17 05-05-06 07:09 AM
Fmic and bumper support Q Ryan33 Saab 9-3 & NG900 Workshop 2 29-03-06 03:38 PM
