Could these work. - SaabCentral Forums
Old 29-07-11
Robb65's Avatar
Robb65 Robb65 is offline
My Saabs: 2002 93
Garage
Smile Could these work.
Hey Saabers
I'm look for some new wheels for the 9-3, 17's for under $500, I came across these that I kinda fancy and was wondering if they would work with the proper hub centric rings. Specs below.
Thanks for lookin
Brand: Vision Wheel
Style: Shockwave 539
Finish: Silver w/ Machined Lip
Bolt Pattern: 5X110
Offset: +42
Hub Bore: 74.1 mm
If at first you don't succeed, add more mods.
*SAABCentral NEW ENGLAND CREW Member 021*
http://www.saabcentral.com/forums/cu...pic26876_2.gif
http://www.cardomain.com/ride/2667524/1
Old 29-07-11
jakejm79's Avatar
jakejm79 jakejm79 is offline
My Saabs: 1999 9-3 Convertible
I believe the hub size of the 9-3 is 65.1mm so they will fit on there, but you may get a vibration since you are only relying on the lug bolts to hold the wheel in the correct location.
Old 29-07-11
BobSaabit BobSaabit is offline
My Saabs: '97 NG900 'vert; '03 OG 9-3 'vert
Originally Posted by Robb65 View Post
Hey Saabers
Thanks for lookin
Just FWIW... in my experience, cheap wheels are always a bad deal. They're soft, they get out of round adn out of true on the first few bumps, and you regret them until the day you toss them on the metal pile. You'd be better off finding a set of higher quality wheels used and refinishing them if needed.
Old 30-07-11
bogan's Avatar
bogan bogan is offline
My Saabs: 97 900se Talladega stage 5
Garage
If the hub size different you can get ring spacers made up at a fitter machinist shop.
I got wheels and the hub centers were to big.I got some made up no problems
B.L.T.H.....Brake late Turn hard
Old 03-08-11
votoms88 votoms88 is offline
My Saabs: 2002 9-3 SE HOT
Just get 74.1mm ----> 65.1 hubcentric rings. Most sellers will include them for free if you ask them.
Most of the time wheels are ok just being centered by the lug nuts (lug centric) but it is way better to run with hub rings. My Rx7 is running lug centric with no problems at all and it has been to the track more than once.
Old 03-08-11
Hub centric rings are normally free with most wheel purchases. If not you can find them on EBAY for around 20bux. I ran my 9-3 centered on lugnuts for over a year because of my 5mm spacers and had no vibrations at all. However, when I got my new wheels I got the proper rings.
Similar Threads
T7 BPC work on T5? Shaft Saab 9-3 & NG900 Performance, Mods & Tuning 46 12-04-11 02:24 AM
bov ? will this work ? trooper Classic Saab 900 Performance, Mods & Tuning 0 21-08-10 09:13 PM
Anyone done social work / youth work ? SaabKen The Lounge 0 03-06-10 01:19 AM
How would auto warranties work(or not work) thru automaker bankrupcies? SaabJitty The Lounge 25 20-11-08 11:50 AM
Why does it still work? nefarious Classic Saab 900 Workshop 2 15-03-04 02:13 PM
