9-3 2004, key won't turn in ignition - SaabCentral Forums
Old 23rd July 2011
weebigman weebigman is offline
My Saabs: 9-3 Linear
Default 9-3 2004, key won't turn in ignition
Start of the problem was that the fuel pump needed replaced, in the process of trying to start the car the battery ran down, I then changed the pump, verified that it was operating by connecting 12v direct and this ran ok.
Now the I have a major issue. I recharged the battery, re-installed it into the car. I put the key into the ignition, nothing happens, the key won't turn and the SID doesn't display anything, not even the back light. There is not the usual click of the steering lock disengaging in fact the lock isn't even on with the key out.
The car will lock and unlock using the key. The interior lights work ok. I have checked all the fuses and everything looks ok. I have started to clutch at straws. The drivers window is open from before the battery was removed(does this have to be closed?) and won't close because the car won't switch on! Is there an interlock on the tank that would stop the car from registering a key in the ignition?
I am really at a loss what to do, does anybody have an idea what could have happened.
Old 23rd July 2011
aerojon's Avatar
aerojon aerojon is offline
take the key out of the switch..unhook the neg term off the battery for 5 mins..
reconnect batt,insert key in switch don't try to turn leave in about 10 secs allowing the key to resync to the car..remove key for about 5 secs,reinsert key it should now turn..
Is still running factory oe coils with Hirsch tune..
Old 23rd July 2011
Thanks for the reply.
the car is out at a friends who allowed me to use his lift to change the fuel pump. I will try what you suggest tomorrow.
Old 31st March 2014
baxte118's Avatar
baxte118 baxte118 is offline
My Saabs: 2004 Saab 9-3SS
Default Help
I am having the same problem with my car, my battery died and after replacing it, the key won't turn at all? Does anyone have a solution????
Old 31st March 2014
Diggs's Avatar
Diggs Diggs is offline
My Saabs: 2003 9³SS Linear
put it in and out a few times.
The answer is almost always....Tech2
Old 1st April 2014
baxte118's Avatar
That's what she said. And thanks for the reply, I put the key in and jiggled it around and was finally able to get it to work
Sent from AutoGuide.com Free App
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Key in Ignition: Won't turn!!!@?? randymo 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 23 22nd October 2016 02:59 PM
Ignition won't turn, won't go out of P imagesinthewind C900 Workshop 2 3rd February 2011 12:09 PM
2005 SS key will not turn ignition, New Ignition Switch steelixjr 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 3 10th May 2010 05:07 PM
Ignition key won't turn Kwicksaab24 9-5 Workshop 9 26th November 2006 02:09 PM
Key won't turn in ignition?! xtrmntr315 C900 Workshop 21 8th February 2004 04:34 AM
