What did you do on your Classic 900 today? - SaabCentral Forums
Old 23rd July 2011
c900's Avatar
c900 c900 is offline
My Saabs: 81 8V 900T, 91 2.1 900i, 90 9k 2.0 Carly
Default What did you do on your Classic 900 today?
This is a topic which hopefully everyone can contribute to!
Today I contemplated the process for replacing the alternator in my 81 turbo sedan and wished I could afford right now to replace the quite worn tyres with something that will grip better off-road.
Craig.
Craig Dewick - Somewhere in Oz -
Flux Capacitor Engineer at Mr Fusion - 1981 8V 900T, 1990 9k 2.0 Carlsson, 1992 2.1 900i - RIP Moose.Parts
Old 23rd July 2011
S900t8v's Avatar
S900t8v S900t8v is offline
My Saabs: Trionic 5.5 1984 900t 8v
Garage
Craig.
I couldn't think of any servicing that I could afford to do either haha so I simply drove it and put $10 of petrol in it. Yes it was a pointless endeavor.
Old 23rd July 2011
16saabs 16saabs is offline
My Saabs: 2x LPT convertible's, 1 x 900 SE
checking rear brake pads ready for MOT test, and changing wife's main wiper motor as getting slow
22saabs
Old 23rd July 2011
Technics's Avatar
Technics Technics is offline
My Saabs: 93 Turbo Vert
New Bilsteins all 4 corners,rebushed the rear end as well big difference, now for the front.....
My other car has 565hp 1950ft lbs of torque and gets 5 mpg on a good day..........
Old 23rd July 2011
B202NUT B202NUT is offline
Banned
My Saabs: 1992 900S // 1991 Turbo Vert SE
Going to buy 2 new tires for my NA so we can finally have both Saabs running at the same time. Give NA good cleaning to prepare for the work week.
3 alignment shims fell out from the verts left front upper A-Arm earlier this week, and was making a horrid clunking sound at low speed when load at the left tire (LHD) turning hard (i.e getting into or our of a park space). I wasted no time or posts trying to figure it out.
Took the car to the indy Saab guy yesterday and they put up on the lift and found shims mangled laying in the axle tunnel; they straightened the shims for me (no cost), handed them to me, and confirmed I only need to replace them when i get home and tighten the bolts properly.
They cleared the SRS mode flash for $45 since i replaced the horn ring earlier this month.
Was gunna put new top on today but wife and I promised daughter fun in the sun so off to the amusement park this afternoon.
Ended up getting a custom grey top for the vert and it looks good in my opinion.
Replacing Shims today before we go play games.
Old 23rd July 2011
88aero's Avatar
88aero 88aero is offline
My Saabs: 1988 Saab 900 Aero, 1989 Saab 900 EMS 16
Garage
Cleaned and degreased engine bay followed by a good wash
Old 23rd July 2011
argylesocks's Avatar
argylesocks argylesocks is offline
My Saabs: '08 9-3 Aero SC VTuner-0, '78 - 99GL
I gave each of them a hug.
Old 23rd July 2011
TroyD TroyD is offline
My Saabs: '89 Turbo Convertible
Gave her a quick bath and a rub down....getting ready to go to a Saab get together in Cary, NC.
Troy
Old 23rd July 2011
JeffCullen JeffCullen is offline
My Saabs: '85 SPG (11/84), '89 SPG (01/89)
In the last month, I have:
-replaced the serpentine belt on my 9000CSE (SaabKen's ex Matilda)
-on Woywitka's '87 turbo convertible
--pulled engine/gearbox
--transferred engine accessories to new donor drivetrain
--transferred good driver's side inner driver from old drivetrain to passenger side of new donor drivetrain
--changed lower ball joints
--dropped new drivetrain in
--hooked everything up
--adjusted timing, idle, LH2.2 AMM using dwell meter
-converted an '84 8-valve non-turbo automatic 4-door to manual
--pulled drivetrain from '84 8-valve non-turbo 5sp 3-door which was unsafe to continue driving due to rust
--pulled the clutch master with the drivetrain so we wouldn't have to bleed the clutch! :P
--pulled shifter assembly
--pulled auto drivetrain from 4-door
--dropped 5-speed drivetrain into 4-door car
--transferred clutch and brake pedals
Last night, I was jacking around with the audio system in the '84 4-door. I've got an '88 Saab/Clarion system in there, and 3 of 4 speakers working. Gotta hit my garage and dig through inventory for some better speakers for the front--one sounds awful and the other is completely dead.
edit: finished stereo on '84 4-door today
SAABCENTRAL.COM -- where the kool-aid never runs dry, and misinformation is always on special!
Old 23rd July 2011
MyFirstOne MyFirstOne is offline
My Saabs: 1990 Saab 900s 16v hard top
I took Bella My 90 900s out for a relaxing cruise through town and the country..shes my daily driver and its amazing how she turns heads. it is the only Saab I have seen anywhere around where I live in SE Missouri!! Bought her from an older gent who kept her very well maintained and shes in almost like new shape.
I love when I stop at a store or wherever and get the questions... what kinda car is that, are you from another country.. or if its somebody who knows Saabs..... its OMG A SAAB!!
SAAB ON!
Old 23rd July 2011
spg1 spg1 is offline
My Saabs: 2008 Aero 95
It may not be the motor at all that is slow, you may have to take out the whole wiper. Take the clips off of the spindles that hole the wiper arms and grease them. I had one that was so bad that it broke trying to get it apart, good thing I had a spare.
Old 23rd July 2011
jskrebs jskrebs is offline
My Saabs: 93 9K CSE, 85 900T 3dr
Welded up the drivers side suspension tunnel rust on the 85T. Hot!
Took a short cruise in the 87 8v Slow!
Old 23rd July 2011
mad-machine mad-machine is offline
My Saabs: Down to one, an 87 900 Turbo
Nothing.. it was 105 degrees today..
it was 105 yesterday
Tomarrow will be cooler.. hopefully I can finish getting the engine and transaxle out of my dead 91 so I can send it off to the scrappers
1977 Fiat 124 Sport Spider
1994 Saab 900 SE Turbo
1991 Saab 900 S
1996 BMW 318 Ti Sport
Old 23rd July 2011
nuclear944's Avatar
nuclear944 nuclear944 is offline
My Saabs: past:89 900 5sp N/A sedan and 89 900 SPG
I flushed the intercooler and painted the front bumper.
TURBO PEOPLE: flush your intercooler with spirits and high pressure water! Adds 10+ hp on a poorly maintained car.
Old 23rd July 2011
c900's Avatar
Aww - feeling the love! 8-) At least it's genuine Swedish love not Ikea-style 'Chinese Swedish' which is how a lot of modern vehicles are designed.
Craig.
Old 24th July 2011
jamengual's Avatar
jamengual jamengual is offline
My Saabs: 89T,87 SPG,93 900S,91 4d, 97 9K Aero
I changes the tires to summer tires and I got my turbo rebuild kit but now I need Aeroquip flex lines for the return and feed oil lines to the turbo an I need to figure out where to get all that.
and I gave a look to my convertible that is siting there waiting for me to change the top and finish the interior once and for all..... .
Old 24th July 2011
c900's Avatar
Default New (reman) Bosch 80A alt installed in 81 turbo sedan - snookered by the tensioner!
Installed the Bosch 80A alternator into my 81 turbo sedan with a new mounting bracket as well as the alternator (since the early style bracket uses the smaller bolt) but got snookered by the slot in the tensioning arm not being wide enough for the larger diameter (and much longer) tensioner bolt! argh! I'm not sure I can come up with a way to substitute another way to tension it up that will be reliable without getting the correct tensioner bracket. bugger...
Anyway the new alt is installed, and the belt is on. I haven't wired it up yet and without a tensioner bracket to use I can't get the belt tightened up. I have all the wiring stuff I need including a cable salvaged from my 9k to join the M8 output stud of the 80 A alternator to an M6 terminal block onto which I can bolt the existing +12 v feeder wires which all have M6 hole lugs.
Shame I can't test it but I did remember to recover the 'key' from the shaft of the old alternator to use on the new one when re-constructing the single-belt pulley on the replacement alt. 8-)
BTW the old 70 A alternator has shocking bearing noises when I was rotating it by hand out of the car, so Good Thing I decided to change it and get a new good alt with a new vreg put into the car.
Oh well such is life! It looks like I'll be driving the landcruiser tomorrow and if I have any $$ in the bank accounts, ordering the right tensioner bracket from Saab Salvage. 8-)
Craig.
Old 24th July 2011
li Arc's Avatar
li Arc li Arc is offline
My Saabs: '85 900 T16 Sedan
Garage
I'm still trying to diagnose my lifter ticking problem. Spent most of the day working on my beater's exhaust, but it's time to focus on the Saab again, so I took the intake cam off and attempted to measure valve clearances today. Nope, got two done then it was dinner time and chat with a friend. So much for being productive. Gotta get the darned transmission back out to fix a botch I did last year before the summer's out!
li Arc
Old 24th July 2011
c900's Avatar
li Arc
At least you have warm weather at the moment - it's winter here and morning/evening temps are down in the single-digit C range, so I get a window of about 5 to 6 hrs if it's sunny, or a bit narrower if it's not, either side of which it's too cold to be outside playing 'bush mechanic'. 8-)
I still haven't had a chance to do anything more with the engine in the black 2.1 hatchback since I bought the skimmed cylinder head from Saab Salvage well over a month ago. I do though now have the special timing chain tool (genuine Sir Tools product) that I purchased from Pelican Parts again over a month ago - I'd also ordered a Sir Tools valve spring compressor but they're NLA.
Hopefully I can snaffle a week of annual leave out of work some time in the not too distant future and get the 2.1 car running. Even if I don't have the $$$ to reg and insure it, I want it to be drivable at least so it can be moved around to mow the 'forest' of grass growing under and around it!
Craig.
Old 24th July 2011
MrDoc MrDoc is offline
My Saabs: 900 Turbo Classic
Changed a fuse that blew, interior light/aerial if you were wondering
Tags
900, c900, classic, today, work
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
RIP Classic 900 KaMiKaZi_t0M C900 Workshop 14 22nd July 2012 10:01 PM
2002 9-5 today in Melbourne SE today GTlegs The Lounge 0 8th October 2010 06:10 AM
Saw a classic BMW moment today boon94 The Lounge 33 5th December 2008 01:27 PM
Classic 900 in DanComden The Lounge 0 20th February 2008 11:08 AM
Classic NG 900??? gildedsplinters NG900 & OG9-3 Performance, Mods & Tuning 6 27th June 2006 07:46 PM
