Sputtering and stalling - SaabCentral Forums
Old 22nd July 2011
Aedhan Aedhan is offline
My Saabs: 2001 Saab 9-5 SE
Default Sputtering and stalling
Hey guys.. me again with my magical 2001 9-5SE 3.0t
This problem is relatively new and happened again tonight. When I started the car after work it fired right up but the RPMs would fluctuate, dropping real low like it was going to stall and then going back up again. I revved it up a bit and then started driving out of the lot. After a VERY short distance it stalled out completely.
I have had this problem before but usually after some cruising. The power just drops like crazy. What I find weird is there is no power, it doesn't really rev up but the boost gauge goes up. I was thinking maybe some sort of problem where cylinders were not firing or compression was lost. When it happens I usually stop, turn the car off and then turn it back on and it usually works just fine.
Once, it did it, no power and all that, sputtered, backfired and then ran fine. It threw a check engine light a couple times but not every time. The code was an O2 sensor high voltage and I believe once it gave an O2 sensor no activity or something along those lines. I have an exhaust leak and I think there is a good possibility that it is near one of the sensor, could that trigger it.
One more piece of info is that I know my front valve cover gasket is leaking oil into the spark plugs. (new gasket and grommets are on order to be replaced next week)
Old 22nd July 2011
carbonbased carbonbased is offline
My Saabs: 1995 saab 900s 212,000 miles
i would check air filter cheapest thing, then mass air sensor, or throttle position sensor....its possible its one of those things but Ive never heard of a oxygen sensor doing that but i also don't own a newer Saab
Old 23rd July 2011
Yeah, like I said, the O2 error is come and go, we figure it may be coincidence.
I will check the Air filter and and the MAF sensor when I get it apart next week. My old caddy had HUGE problems with the throttle position sensor because the head gaskets were bad and it blew oil back through and coated it. Hoping to replace the air box with a high flow intake, since I have heard a few good things about it.
Old 23rd July 2011
yea i want a high flow intake too, my Buick was doing exactly what your saying stalling and everything and it was the air filter a ten min change lol...didn't have a problem since
Old 23rd July 2011
Mendota's Avatar
Mendota Mendota is offline
My Saabs: 2000 9-5 Aero wagon, 1999 9-3 convert
This just happened to me 2 weeks ago on a road trip. The car sputtered and lost power and died. I coasted into a parking lot and stopped, turned it off and restarted it just fine. As we pulled into our destination the car literally died. We coasted into a parking lot, again, and this time it would not start for anything. It ended up being the fuel pump. That was replaced but I am still getting some of the same symptoms of dipping RPMs and sputtering. I just replaced my spark plugs and that has helped a bit.
Next on the list is to replace my air filter, and if that doesn't do the trick then the DIC is next.
Good luck! These cars are awesome when they run properly!
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
stalling and sputtering saabrider C900 Workshop 3 7th July 2009 01:00 PM
sputtering 9-5 danlay 9-5 Workshop 17 19th September 2007 12:04 AM
HELP!!!! Sputtering..... babyjet 9000 Workshop 2 13th March 2006 09:54 PM
sputtering? williamsvr6 9-5 Performance, Mods & Tuning 2 3rd May 2004 10:47 AM
Sputtering SPG thebracko C900 Workshop 4 23rd February 2004 06:22 PM
