Ignition switch "stuck" - SaabCentral Forums
Old 15th July 2011
hybrid0175 hybrid0175 is offline
My Saabs: 05 SAAB 9-5 Aero
Default Ignition switch "stuck"
So I picked up a new (to me) SAAB the other day....so far so good and the car drives nicely!!
Here's my first question. When I pull out the key after it's been switched off, the key comes out fine, but sometimes it's not completely shutting off - i.e. radio/nav is still on. It's almost like the silver ignition cylinder has not completely disengaged. I have to put the key back in and wiggle it for it pop out and then everything shuts off.
Is this a sign of a bad ignition cylinder? Is there a fix without replacing it? Will WD40 work? Thanks!
Old 15th July 2011
Saaber95er's Avatar
Saaber95er Saaber95er is offline
My Saabs: 1999 9-5 SE 5spd
Garage
WELCOME TO THE FORUM!!!!!!!!
You might have some debris under the cylinder that's stopping the switch from popping the cylinder up. The best way to go at this is to remove the cylinder and check. DO NOT USE WD40
http://www.saabcentral.com/forums/sh...d.php?t=214533
Old 15th July 2011
Default Problem solved
Thanks so much!! I did do the search prior to posting it but didn't come up. Again, thanks!
BTW, I know you said no WD40, but a solution is to use it once the cylinder it out. I guess you meant not to use before taking it out
Old 16th July 2011
Saaber95er's Avatar
Garage
No, I meant not use it because WD40 attracts dust and it will cake up dust over time the best thing to do when it's out is to use graphite or a teflon base lubricant.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Wanted: Direct Ignition Cassette "DIC" "IDM" (Cash or Trade) jwwells Parts for Sale/Wanted - North America 5 20th June 2011 12:38 PM
Replacing Ignition Switch and "coding" r9895 9-5 Workshop 2 9th September 2010 04:09 AM
Ignition switch not returning to "On" on start rdsc49 9-5 Workshop 2 11th May 2010 03:11 PM
1998 900s' radio stuck on "1111", can't change to tape or cd or tune donkor NG900 & OG9-3 Workshop 7 4th September 2008 06:18 PM
"Check Latches". Top won't unlatch from hardboot. Stuck closed. 1998 Convertible Jrodnj NG900 & OG9-3 Workshop 1 29th August 2007 10:35 AM
