97-x oil consumption - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9-2X, 9-4X & 9-7X > 9-7X Workshop
9-7X Workshop 9-7X Technical Forum
Old 11th July 2011
pauln1 pauln1 is offline
My Saabs: 2007 9-7x Altitude 5.3
Default 97-x oil consumption
We have a 2007 97-x with 50k miles (second owner). We've been experiencing oil consumption (i.e. more than two quarts down before logging 3k miles). There are no visible external oil leaks. Just curious if anyone else is experiencing this or if the 5.3 is known for a thirst for oil.
Thanks.
Old 11th July 2011
saabmeatball saabmeatball is offline
My Saabs: 2007 9-3 2.0T
Yeah, check out my cyclinder 1 misfire thread.
You are having the same issue as me. Hopefully yours is still under warranty like mine.
There is a TSB for this issue, it has to do with the cylinder deactivation.
Old 17th July 2011
Road Ghost's Avatar
Road Ghost Road Ghost is offline
My Saabs: Saab 9-7X 5.3i (not anymore)
Next time you are on the highway cruising, and you start to accelerate from 4 to 8 cylinders, look in the rear view. Big puff of blue smoke will be seen the odd time.
Yeah, GM sucks.
Old 26th July 2011
slicksilver slicksilver is offline
Is TAC646 the TSB 'number' I should give the dealer? My 5.3 is burning oil as well.
Old 26th July 2011
Nevermind. I just found this tidbit in another thread:
I found this:
UPDATE: TSB 10-6-01-008A
10-06-01-008a
#10-06-01-008A: Engine Oil Consumption on Aluminum Block Engines with Active Fuel Management (AFM) ( Install AFM Oil Deflector and Clean Carbon from Cylinder) - (Sep 28, 2010)
Subject: Engine Oil Consumption on Aluminum Block Engines with Active Fuel Management (AFM) (Install AFM Oil Deflector and Clean Carbon from Cylinder)
Old 30th July 2011
So I took my truck To the dealer to have an axle seal replaced and mentioned this TSB. The dealer stated that the most likely cause is a mistake by the tech who performed my last oil change. I'm going to monitor my oil level on a weekly basis and will take it back to the dealer should the level decrease.
Old 30th July 2011
yeah right.
Start bring a spreadsheet to the dealer for an oil consumption test. Don't add oil yourself bring it in. Have them note it.
My Saab dealer said right away they had this issue before.
Old 30th July 2011
Road Ghost's Avatar
When I gave the dealers that TSB (GM and Saab) they couldn't find it.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Oil Consumption! Jonathan93 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 18 9th December 2009 02:15 PM
Consumption SteveTheFolkie NG900 & OG9-3 Workshop 5 2nd December 2009 07:52 PM
Oil Consumption? dostler 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 15 7th July 2005 01:34 PM
oil consumption? platypus 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 1 2nd January 2004 08:51 AM
Oil Consumption JFK-USAF 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 11 29th April 2003 10:55 AM
