BSR Performance ECU and Exhaust Upgrades & PPC Systems available from PFS
Home Saab Pictures Saab Classifieds Saab Dealer Listings Saab Forum
Go Back   SaabCentral Forums > Saab 9-3 Sports Saloon/Sedan/Convertible/Combi > Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop
Old 30-01-04, 10:14 PM
alex_c alex_c is offline
Default I got AUX WORKING !!!!
Thanks to the excellent post by Viscouse and with the help of the info provided by Saba, I finally got AUX working, wired and ready to use!!!!
First, I used a 4 wire cable from Radio Shack (I spliced the white cable and removed it, to make it a 3 conductor cable).
Second, I got an RS-232 DB25 port, in order to use the individual female pins to be connected to the male port on the back of the EHU.
Third, a standard 1/8" stereo jack from Radio Shack.
Here's a picture of the items:
Here's the cable with the pins connected and the 1/8 jack soldered at the other end:
added after the original post...
In order to get a better fit and prevent any possible problems, I added another step to insulate each one of the pins.
I bought a bag of Butt Connectors, Radio Shack Part # 64-3073 (see picture below) which is nothing more than a small barrel with a removable plastic insulator.
What I did was first remove the barrel from the insulator and then use the yellow thing to cover the pins on my cable. Please note that if you can't slide the insulation all the way back, you may need to cut the bottom of the insulator to be flush with with the pin.
If you see the picture, first is the bag of connectors, to the right is a disassembled barrel/insulation and on the bottom you can see how I used the insulation to cover one of the pins.
I actually covered each one of the pins and that made for a very sturdy and tight fit on the back of the EHU. After I was done, I realized that I could've have used the butt connectors complete, instead of using the pins from the DB-25 and covering them.
If you decide to use the butt connector as it is, you may need to press a little bit on the end with pliers to make the hole smaller and get a better fit between the connector and the pins on the back of the EHU.
Once I had the cable, I removed the EHU according to Saba's instructions. I found out that it is much easier to remove if you have the car on Drive (automatic) so the shifter will be out of the way. I used a thick towel not to scratch the shift knob and/or the dashboard.
I tested the connector to see if that was indeed the correct one and if the pins were the correct. They were: Pin 10 for ground and pins 3 and 4 for left and right (or right and left?) The are 2 12 pin connectors side by side. The AUX is the one on the right according to this picture:
I connected each individual pin to the EHU and secured the cable with some tape:
I routed the cable thru the back and then to the bottom of the passenger side...
Some final testing.... IT WORKS !!!!!!!!!!
Enjoy!
[/i]
Old 30-01-04, 10:36 PM
joshd2012's Avatar
joshd2012 joshd2012 is offline
My Saabs: 2004 9-5 Aero
Nice Work :!
Glad to see that this is doable. Do you plan on running the input into the center console?
Old 30-01-04, 10:43 PM
Yes, that's why I had the cable on the floor, just before routing it to the console. I drilled a small hole on the AUX cover and attached the 1/8" Stereo Jack, just as the factory harness. By the way, I just tried connecting my phone's headphone jack to the AUX and... I can listen to my phone on the stereo, and obviously I can change the volume with the steering wheel controls. Yeahhh!!!
Old 30-01-04, 11:07 PM
kedvale kedvale is offline
That looks awesome. Thanks for the details. I have a question though...what do you mean you tested the pins? Ie, did you do physically do something verify the locations of the ground, L and R pins, or you just went by the schematic posted on the other thread? And, after getting this to work, have you been able to tell which one is L and which is R? Thanks!
Old 30-01-04, 11:21 PM
-andrew-'s Avatar
-andrew- -andrew- is offline
My Saabs: 1966 Saab 95 - 2002 Viggen Coupe
How hard was it route the cable into the center console and install the jack in the "aux cover"?
This is great. I had my iPod hardwired into my GTI and realized it's hard to live without. I just picked up my arc a few days ago and luck has it that I didnt have to wait long for this at all! I just have to avoid my fiance who is sure to kill me for taking apart the new car right after picking it up!
Old 30-01-04, 11:31 PM
finklejag's Avatar
finklejag finklejag is offline
You da man. Very nice work for being a newbie.
XM here I come.
Old 30-01-04, 11:35 PM
MarkJ's Avatar
MarkJ MarkJ is offline
My Saabs: 2004 9³ Aero SOLD
Excellent work Alex!! Now why can't Saab USA put out a cable and set of instructions to the dealers??
How do you choose AUX as a source (besides radio and CDX)? My 2004 Aero does not have AUX as a choice when I cycle through them...
Old 30-01-04, 11:39 PM
CosmicSaab CosmicSaab is offline
Aux has to be turned on with the Tech II unit. It is not an option by default.
Old 31-01-04, 12:22 AM
saabfan's Avatar
saabfan saabfan is offline
My Saabs: '04 93 Aero & '05 93 Linear
I'm impressed. Good job.
Now, for those of us not willing to tear our car apart (read: not talented enough to do it properly), when is Saab going to release the parts for this and provide instructions for dealers to do it?
I want AUX for use with an iPod. No more burning CDs would be really nice. BTW, do you notice any degradation in sound quality?
Thanks.
Old 31-01-04, 12:47 AM
moz moz is offline
Great work Alex, almost brings a tear to my eye.
Old 31-01-04, 12:54 AM
italiancousin italiancousin is offline
Here's a question... can I "hardwire" my phone's audio output into the AUX in and use that as a poor mans Tel1 install?
My phone car kit actually uses a standard minidin (phono cable) to output to its car speaker.
Old 31-01-04, 12:58 AM
WASAAB's Avatar
WASAAB WASAAB is offline
Wow..Great Alex..
:P
You are voted for the NEW MEMBER OF THE YEAR :wink:
BTW, How's the sound quality? :P
Old 31-01-04, 02:07 AM
Viscouse's Avatar
Viscouse Viscouse is offline
My Saabs: 2003 9³SS Arc, 100k+ miles
alex_c, my hat is off to you!
Excellent step-by-step, by the way. Probably the cheapest solution too. For some reason, I was so gung-ho on an intermediate cable, this solution never gelled in my head. ops:
I'm still working on finding proper plugs though.
Alex, 3 questions:
1. As asked before, how's the sound? Comparable to radio, CD?
2. I swear (but can't remember where) I saw something about someone who did this, and ended up with a lot of interference from other electrical signals. I was wondering if a filter (those fat cylinders on your printer/perepheral/phone) was needed. Is it?
Great job! I LOVE THIS FORUM!
Old 31-01-04, 03:35 AM
Jet 9-3's Avatar
Jet 9-3 Jet 9-3 is offline
My Saabs: 9³ Arc 2.0T Sentronic
Wow. Nice job. I guess I'll be asking for them to turn on aux in when I bring in for service
Old 31-01-04, 03:38 AM
jcancio's Avatar
jcancio jcancio is offline
great job! this is so awesome!
Old 31-01-04, 05:53 AM
Wow! Thank you for all your nice comments!
I'll try answer some of the questions:
Sound quality: EXCELLENT, just like CD, no degradation or distorsion at all.
Italiancousin: Yes, you can hook up your telephone's audio out (or headphone jack) to the AUX in, and hear the sound thru the stereo. I did this and is awesome!
How do you select AUX: You press the SRC (source) button on the steering wheel and it will go from RADIO to CDX and then to AUX. Also, you can press the DISC button on the Infotainment console and it will select the CD, press again and it will select AUX. Also, you can press the DISC button and then scroll down to DISC SOURCE and it will show "CDX (Front)" and "AUX (Input)"
How hard it is to route the cable: Very easy. From the back of the EHU you can lower the cable to the passenger side and then with the side console cover removed (only one torx screw) you can guide the cable very easy all the way to the console where the jack should be.
Old 31-01-04, 06:00 AM
Saba's Avatar
Saba Saba is offline
Congratulations Alex. I will be going down to my local electrics store today and getting same. This is a great day in Saabcentral folklore. The day Alex took on GM and won! Guys go get your aux-in activated before it is no longer available.
Old 31-01-04, 06:47 AM
hts666 hts666 is offline
Dude, Alex, you're my favorite person today
I'm taking my car to the dealer to get AUX enabled first thing in the morning, hope they don't give me problems with it. Then I'm doing the install . Man I can't wait. And I almost ordered an fm modulator and antenna adapters today. Good thing I held off.
Man, mad props to everybody that made this possible, you guys rock!!!
BTW, do i need ROW seetings for the AUX to be enabled, or that doesn't matter (logic says it shouldn't, but....)
Old 31-01-04, 07:33 AM
silent2n silent2n is offline
This is definitely a great day.. when someone other than Saab had to figure this one out. Perhaps now we should send them the instructions on how to do this. hehe
Old 31-01-04, 08:27 AM
Vector-SS's Avatar
Vector-SS Vector-SS is offline
My Saabs: 2006 9-3 Aero Vtuner Stage 0
Alex,
Can you please tell me in what part you used the "D-sub connectors?
copyright © 2003 saabcentral.com, All rights reserved - website by WDD serviceshttp://www.whiter.co.uk - valid xhtml - valid css
SaabCentral is an independently run website and is not affiliated in any way to Saab Automobile AB
