1999 9-3 water pump replacement. - SaabCentral Forums
Old 4th July 2011
saabtour saabtour is offline
My Saabs: '95 900SE, '99 9-3 convert., '99 hatch.
Default 1999 9-3 water pump replacement.
Hi. My water pump needs replacing. Bougth the replacement part and started to dive in, but it looks damn daunting. Anyone have experience with how to replacae one of these? Thanks in advance.
Old 4th July 2011
earthworm's Avatar
Saab Sage!
http://www.saabcentral.com/forums/sh...d.php?t=198085
I use anti-rust in the cooling system, even with that, I'll have to do the pump sooner or later, but the last one was on an eighty's Saab, or a 70s, really forget which.
A daunting task its not, IMO... but please do read up, use anti-seize and PB blaster...
The earthworm
'96 900S, Automatic
Old 4th July 2011
win_k win_k is offline
My Saabs: 99 S Coupe, 01 SE Vert
It's tight, but not really that difficult.
You'll need to start by removing the air cleaner assembly, air cleaner to turbo hose, the turbo heat shield, the serpentine belt and move the power steering pump out of the way.
You'll need to remove the right front tire and the plastic shields between the engine and wheel well.
After that, it's only a few lines and hoses need to be removed or loosened.
The hard line between the back of the water pump and the back of the cylinder head is easy with a long extension to reach behind the exhaust manifold/turbo.
Old 4th July 2011
watkins's Avatar
watkins watkins is offline
My Saabs: '99 Viggen
Uhh.... No
By no means would anyone ever need to do that. The water pump is accessed from above. with the possible exception of the turbo coolant line, which can be done from above or below depending on the tools. From below there isnt any need to go through the wheel well.
Old 4th July 2011
Ross Daniel Ross Daniel is offline
My Saabs: 900NG; 9-3 SE, 9/5 vector, 04 9-3 AERO
It is not that difficult, maybe 1-2 hours max. The pump with no housing is about $30 on parts geek. Make sure you replace two o-rings between the block and the pump housing sleeve. Replace the thermostat and its seal and check all water hoses. Pay attention to the heater hoses especially the one that connects to the head (it tends to deteriorate at the bent). Good luck.
Old 4th July 2011
Mr. Bingley Mr. Bingley is offline
My Saabs: 2000 9-3
It's been a little while since I did mine, but here is my advice--if it appears to be in the way, remove it--it is. I spent more time trying to work around removing parts than I spent removing (and reinstalling) them after I discovered that there is no work around. Just pull everything out of the way until you have a clear shot at the pump. I do recall ending up removing the aluminum turbo inlet plenum, and wishing I had removed it in the first place. Pay attention to the order things come off and make sure to put them back on in the same order--then you won't have to be like me, and take it all apart again for want of a little bolt that goes in before the inlet plenum goes back on.
+1 on the two o-rings, and be sure to clean the line they go on, and the block where it mounts. I think you do remove the passenger's wheel and flip back the front inner fender liner--to get at the belt. It's no big deal to do, and like I said, just remove everything in the way--don't waste time trying to do a work around.
Have some big wire ties handy to secure the steering pump to the core support, and use a rag where it contacts the support to protect the paint. I found that removing the passenger's headlight and the grill made getting the air cleaner out and in a snap--well worth the 2 minutes it takes to take them out and put back in. I lubricated the o-rings with silicone RTV water pump sealant, as it appeared that the factory had done this as well. So far so good on that--no leaks.
If you haven't already upgraded your crankcase breather assembly, take this opportunity to do it at the same time--most of the same parts have to come off to do either job, and the breather has been redesigned to address a flaw that could cost you your engine.
I found a long (2 foot) 1/4 inch extension and 1/4 inch swivel and deep sockets to be very handy. Tilt head GearWrenches 8mm, 10mm, 12mm and 13mm were also very useful. Also a long magnet will be of great help.
It's a lot of work for a water pump--not impossible, but a lot of work for a wear part--I think Saab had a brain freeze on this one.
Good luck.
Old 4th July 2011
earthworm's Avatar
Saab Sage!
Tilt gear wrenches ?
Harbor Freight ?
Are these strong enough to break loose screws ?
The Saab 99/900 series from the 60s,70s were better designed, easier to work on...The 9000 ?.... IMO, it was too short, too compact.
The earthworm
'96 900S, Automatic
Old 5th July 2011
Jeremy R.'s Avatar
Jeremy R. Jeremy R. is online now
My Saabs: '97 900SE Talladega, 2000 9-5 Aero Wagon
I took mine out today and it didn't take any exotic or fancy tools. A 1/2" ratchet, a short extension, and a 13mm socket got the upper two bolts off, and a 3/8" ratchet, extension, and 13mm socket got the bottom one off. Part of the A/C compressor stuck up too high for a 1/2" extension or ratchet to get a straight shot at the lower bolt. The hard pipes were interesting. They're weren't hard to get off, just a few 10mm bolts, but I've never seen such a design. I agree that taking off the wheel and the access panel in the wheel well makes it a lot easier to get to the belt.
Old 5th July 2011
My Saabs: 2000 9-3
Harbor Freight ?
Harbor Freight?!? No--GearWrench brand--I learned long ago never to use cheap tools where it matters. That being said, I wouldn't break a tight bolt free with a GearWrench, I break it free with a regular wrench and then back it out with the gear wrench--quite the time saver in a tight spot .
http://www.gearwrench.com/catalog/wr...x_combination/
Old 5th July 2011
watkins's Avatar
There is no need to take the wheel off because there is no need to remove the belt. The belt just needs to be slipped off the power steering and water pump pulleys and tucked out of the way. You people are making way more work for yourselves than is needed. The belt is incredibly easy to do with the car on the ground. Ive done it countless times on several cars.
Old 5th July 2011
earthworm's Avatar
Saab Sage!
I must agree, I'd rather spend 2 minutes to save 2.5 minutes than to be frustrated into not spending the time to save time and effort...
Make sense ?
And its more satisfying to use brains as opposed to brawn, at least most of the time...
The earthworm
'96 900S, Automatic
Old 5th July 2011
My Saabs: 2000 9-3
If you are replacing the water pump, you should replace the antifreeze, O-rings, thermostat, belt, hoses and clamps at the same time--unless any of these items were recently replaced. Not changing the belt is like not changing the filter when you change the oil--penny wise... Like I said earlier, if you haven't upgraded the crankcase breather system already, do this too while you're in there. The belt is something that you should replace any time you take it off--it is cheap but catastrophic if it breaks on the road. Depending on mileage, you will also want to replace the idler and tensioner pulleys too. Preventative maintenance beats repairs every time. If you really wanted to get the maximum prevention points, you would replace the CPS while you're at it (I didn't, and I'm sure I'll regret it sooner or later).
Old 5th July 2011
mr rx-7 tt mr rx-7 tt is offline
Don't use the GBH brand I have had nothing but trouble with them, they don't last. I purchased a Saab OEM after going through two GBH water pumps in 11 months. Also the neck to the water pump comes out and it has two O'rings, I replaced both of them as well.
1999 Turbo SE
2000 Viggen
1993 Mazda RX-7 "It ain't stock"
I live in a high test world...
Old 6th July 2011
GarrettCharger's Avatar
GarrettCharger GarrettCharger is offline
My Saabs: 06' 9-3 Aero 6-spd
Default +1
Couldn't agree more with this part. There is nothing more frustrating than getting it all back together only to find out you have a small coolant trickle and need to repeat the entire job again... Go ahead, ask me how I know this .
Old 6th July 2011
watkins's Avatar
If I replaced the belt every time I took it off Id have bought probably 15 or more belts in the last two years. At $35 a piece, thats quite a bit of pocket change.
Belts dont just snap. They always show signs of wear first. I take a look at the condition of my belt every time I check my oil.
Ive only ever had one belt go on me, and that was because the idler seized. The belt itself would have lasted many thousand miles longer were it not for that. Unsurprisingly, the idler was clearly in need of replacement and I already had one on order to be installed the weekend following the incident.
Old 6th July 2011
My Saabs: 2000 9-3
To the OP: did you do the job and if so how did it go?
Old 6th January 2016
StonePipes StonePipes is offline
My Saabs: 99 Saab 9-3 Turbo SE LPT, 99 9-3 SE HOT
Purchased a 1999 saab og9-3 which needed water pump, pump was completely shot causing the belt to come off all pulleys.
Seeing I couldn't drive it home to Wisconsin and already had a import direct water pump for my other 99 og9-3. I was able to replaced the water pump on 4th and 4th ave west in Duluth MN with my tool box and a friends help.
It took 6 hours. If I can do it on the streets I'm sure you can do it in the shop. Was only able to complete the job because of a DIY youtube video on replacing the water pump which I highly recommend watching!!!!!
Old 12th November 2016
Spurlock Spurlock is offline
New Member
My Saabs: 2002 saab 9-3 Se
Default banjo bolt fitting washer
please for the love of God, can someone tell the part # for the banjo fitting washer that connect to the water pump hosing. 2002 Saab 9-3. Mine had a metal washer with a black inner washer. help!!!!
Old 13th November 2016
BobSaabit's Avatar
BobSaabit BobSaabit is offline
Saabista
My Saabs: '97 NG900 'vert; '03 OG 9 'vert
Do you have a copy of the EPC? You can get the part # from there.
Jeremy R.'s Avatar
The banjo fitting on the water pump is supposed to have two copper washers, not the rubber-lined ones. The part number is 11066422.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
1999 Saab 9-3 water pump anxj1998 NG900 & OG9-3 Workshop 2 5th January 2011 08:16 AM
water pump replacement cseturbo 9000 Workshop 7 3rd October 2010 11:17 AM
Water Pump Replacement 9-5 1999 4cyl BlackandTan 9-5 Workshop 1 2nd November 2007 08:09 PM
Water pump replacement Somberlain C900 Workshop 14 13th February 2006 12:39 PM
Water Pump Replacement kraia C900 Workshop 3 4th September 2002 12:33 AM
