How to replace fuel level sending unit in Saab 93 Aero 2004 - SaabCentral Forums
Old 3rd July 2011
Saab93Addict Saab93Addict is offline
My Saabs: Saab 9-3 Aero 2004
Question How to replace fuel level sending unit in Saab 93 Aero 2004
Hello,
I'm pulling my hair a little bit on that one. My fuel level sending unit seems shot (reads empty when I fill up, eventually resumes reading when the tank is about half-full - well now when it's almost empty, it's getting worse and worse). I have the replacement part and I'm trying to locate where the fuel level sending unit access is on my car. Is it on the right side of the trunk by the tank (see pic)? Or is it under the rear seats (also see pic)? I'd appreciate it a bunch if someone could guide me. Unless it's under the spare tire? I've read a few threads about this and can't seem to understand where this darned thing is!
Thanks.
ID:	24203   Click image for larger version
Old 3rd July 2011
cadcamjim's Avatar
cadcamjim cadcamjim is offline
My Saabs: 2006 9-3 Sportcombi 2.0T, 5-M/T
There is no access panel; the correct procedure is to drop the tank and then remove the fuel pump/sender unit from the top. Many people have cut an access hole in the previous generation 9-3's and maybe some on the newer ones. Dropping the tank is usually not really that bad; just get the fuel level as low as you dare first so the tank is light.
Old 3rd July 2011
Really? That's a bummer, I was under the impression that you could access it from the trunk (plus I just filled up!). How do I drop the tank? Do you change it from underneath the car once you've dropped the tank?
Old 3rd July 2011
cadcamjim's Avatar
Thanks to N2STY for this one:
http://www.saabcentral.com/forums/sh...ht=fuel+sender
Old 3rd July 2011
Wow, thank you so much. I think I'm going to have go take it to the mechanic for that one though...
Old 3rd July 2011
cadcamjim's Avatar
Yeah if it's not something your comfortable doing yourself, have your mechanic do it, but you'll still want to wait until the fuel level is low to make it easier for them.
Old 3rd July 2011
I guess I could do it. I just wonder if my mechanic would charge me more than the $100 or so of tools I'd need to do the job myself (mostly the hydraulic jacks and 3 axle stands).
Old 16th September 2011
u1538526 u1538526 is offline
My Saabs: 2006 9-3 aero
I have a 2006 2.8 V6 and have the dancing needle problem. I wish to change the fuel sender unit. Is this part [22672171] (some call the part 10 22672171) the same for that engine?
thanks!
JonV JonV is offline
Saabista
My Saabs: 03 SE 5 Spd
It's about a 2. 2.5 hour job.... .5 hr longer if you have to drain a lot of gas slowly.
chris_de_ze's Avatar
chris_de_ze chris_de_ze is offline
My Saabs: '03 9-3SS Aero, I4, MT6, Maptun Stage 1
thanks!
While EPC gives a separate part number for the fuel sender unit on the B207 2-liter engine, it does not give a separate part number for the B284 2.8 liter engine. The sender unit on the B284 motor is integrated with the pump! Is this strange?
At least this is what my EPC (2009 release) says!
Fuel tank (2006 - 2009), B284, CA, US
Article : Fuel pump
PartNo : 12763086
Order Quantity : 1
Fuel tank (2003 - 2009), B207, CA, US
Article : Fuel gauge sensor
PartNo : 22672171
Usage : (OBD II)
Order Quantity : 1
founding member of the Greek Saab Forum
Old 24th March 2013
Coombi Coombi is offline
My Saabs: 2006 Saab 93 Sportcombi Aero
thanks!
Did this part fix your gauge problem? The only solutions that I have seen is for the 4cyl model
Old 24th March 2013
TunnanXWD TunnanXWD is offline
My Saabs: 280-XWD Aero & a 2.0 XWD
Just as a note, the XWD cars have two sending units, one of which is not being produced. This is because the drive shaft forced them to go to a "U" configuration for the shape of the tank.
Semper ubi ubi inn captut tuum
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Fuel Sending Unit DIY jmcox44 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 89 26th October 2016 09:44 AM
Fuel Sending Unit 415k 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 0 7th April 2009 01:37 PM
Advice on best approach to fix fuel level sending unit and P0341 Code grcsomd NG900 & OG9-3 Workshop 3 1st October 2007 10:42 PM
Replacing the fuel level sending unit CJOS10 C900 Workshop 1 3rd November 2004 09:33 PM
Fuel level sending unit question CJOS10 C900 Workshop 1 29th October 2004 06:02 PM
