battery problems - SaabCentral Forums
Old 28-01-04
charles windsor charles windsor is offline
New Member
Default battery problems
hi,
i am a new owner of a 1991 900s. i ahvent really had time to dig into it but one thing i know for sure is thast teh battery drains over night. i dont know what causes it to drain but it does. i go to start it in the morning and it is deader than a brick. please help
charles
Old 28-01-04
jetman jetman is offline
My Saabs: 1984 T8
Possibly the little light in the back of the hatch is stuck on or something of that nature?
Old 29-01-04
gerryp's Avatar
gerryp gerryp is offline
Hi Mr Windsor, welcome to SaabCentral.
A few things to try:
1) Disconnect one of the battery terminals before you go in at night. If the battery is still dead in the morning, you need a new battery.
If the batttery is OK:
2) Check the ignition switch is fully off. If it's not; the light in the main light switch will be on, anything in the accessories circuit will be supplied with current (if switched on), anything plugged into your cigarette lighter will draw power.
3) Check the quiescent current draw of any alarm or radio fitted.
4) Check the earthing points are in good condition (strange things happen with bad earths)
5) Check the battery is being properly charged. With the engine running the voltage across the battery should be 13.8 to 14.1 volts. With the engine off a fully charged battery should be more than 12.6 volts.
Best of luck
Old 29-01-04
alan forsyth alan forsyth is offline
i had this prob 6 months ago when i got my 16t the radio was removed and the live wire was hitting metal and therfore draining the battery i put some insulating tape on it and bingo cheers alan
