Vacuum Hose Diagram. - SaabCentral Forums
Old 22nd June 2011
YoSaabo YoSaabo is offline
New Member
My Saabs: 1999 Saab Wagon
Exclamation Vacuum Hose Diagram.
I have a 99 9-5 wagon 2.3L turbo.
It overheated on me so I pulled over and I saw a leak on a small heater hose that was steaming out the coolant. I cut of the end that was bad and re fitted the same hose for a temp. fix. I filled it up and tried to drive it home. that's when I heard a pop under the hood and it started to over heat. I pulled over again and saw it was another heater hose that had exploded.
once the second hose exploded the temp. gauge went back down so I got back in my car and drove it home (about a mile) I made it without it heating up.
I replaced that heater hose and started it back up but it stalls on me, I think I may have connected the vacuum hoses wrong. Does anyone have a diagram of the vacuum hoses that go from the Bypass valve or pvc valve I dont know its exact name. I am also going to change the thermostat just in case but I would appreciate any info or suggestions. Thanks!
Old 23rd June 2011
Saaber95er's Avatar
Saaber95er Saaber95er is offline
My Saabs: 1999 9-5 SE 5spd
Garage
WELCOME TO THE FORUM!!!! This thread should help.
http://www.saabcentral.com/forums/sh...d.php?t=213273
Tags
pcv hoses, pcv valve, vaccum hose dilema
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
I need a vacuum hose diagram please 2blackSAABs C900 Workshop 12 19th August 2016 09:57 AM
96 saab throttle body vacuum hose diagram demon06 NG900 & OG9-3 Workshop 2 25th April 2011 09:17 PM
Vacuum diagram supremedalek C900 Workshop 2 16th November 2007 06:25 AM
leak: radiator hose and vacuum hose DBAJonR NG900 & OG9-3 Workshop 5 13th February 2006 05:38 PM
can anybody email me a vacuum hose diagram or help me please brtboy 9000 Workshop 8 2nd March 2004 10:35 AM
