A problem with Crankshaft Position Sensor - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > 9000 Workshop
9000 Workshop 9000 (1985-1998) Technical Forum
Old 18th June 2011
thana3152 thana3152 is offline
New Member
My Saabs: 9000 CD
Post A problem with Crankshaft Position Sensor
Hello there,
I'm a new member here. I have Saab 9000CD yr.1993 which is its Crankshaft Position Sensor is dead, I'm wondering if I can replace it with 4AV16F instead of 3AV51E?? Will it work???
The old one doesn't have in Thailand anymore.
Thank you for your answer!
Old 19th June 2011
sp53 sp53 is offline
My Saabs: 1989 saab 9000 1992 9000 1993 9000
Saabs in Thailand wow. Been there, it is nice, never say any Saabs though. Anyways often people will take a CPC out of a 900 and put that in a 9000. In fact some (shops) actually cut and splice them in right above the main pulley.
Steve
Old 30th June 2011
saab9000noobie saab9000noobie is offline
My Saabs: '92 9k N/A 2.3 5spds
the sensors are a direct swap aside from the connector? do you know which year 900's can be used on which years 9000?
I have a '92 that the tach needle doesn't move on and the car cranks and cranks. Then, eventually the needle will bounce and it will fire up and drive fine.
Old 30th June 2011
I am not sure if the CPS is the problem or not. I have a 92 9000 that acts the same way and I replaced the sensor and it did not help. I figured it was high miles because mine has 250+. I am not sure which ones will switch, but I bet they all might. Sure give it a try, but a hard start could be many things. I finally gave up on my 92 because I could hear a knock in the engine at about 2,500 and figured it was not worth that much work, funny because mine has good compression.
steve
Old 30th June 2011
That's interesting, mine has 165k on it but unsure if that's accurate and has a knock at idle that is intermittent. One theory i had without getting my hands dirty was maybe the front seal was leaking and had gunked up the sensor, but by spinning the engine it threw the crap out. Long shot I know . Other thoughts were a lazy relay. Long shot as well.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Crankshaft Position Sensor Chris 9-5 9-5 Workshop 7 25th January 2011 07:23 AM
crankshaft position sensor AC8070 9-5 Workshop 4 2nd July 2010 10:29 AM
crankshaft position sensor (CPS) pushkin 9-5 Workshop 3 13th August 2007 08:15 AM
Crankshaft position sensor 93-conv NG900 & OG9-3 Workshop 10 5th August 2006 05:53 PM
Crankshaft Position Sensor (CPS) 900SEVictoria NG900 & OG9-3 Workshop 3 18th July 2006 10:07 PM
