steering lock malfunc. - SaabCentral Forums
Old 10th June 2011
Hueso8 Hueso8 is offline
My Saabs: 2003 Saab linear 2.0t
Exclamation steering lock malfunc.
i need help plz, when i try to start the car it says steering lock malfunc. make a safe stop contact saab dealer. when i put the key before turning it, it made a click and now i doesnt make it and so i can turn the key to the right. plz help is there a way to fix it or i have to take it to a saab dealer cuz the closest saab dealer is like 250 miles from here
Old 10th June 2011
JMarkert's Avatar
JMarkert JMarkert is offline
My Saabs: 2004 9-3 linear
It might not be a big deal - often this message comes up as your battery gets older.
Short term, jiggle the steering wheel and try again, this sometimes helps. Try disconnecting the battery for a few minutes to let the computers reset, and/or put a battery charger on it for a little while if you have one.
Long term, maybe go to a shop or autozone and get the battery checked out.
Old 10th June 2011
i tried playing with the steering wheel and didnt work so i heard also to remove fuse 1 and 2 ill try that and if i doesnt work then i disconnect the battery and if that doesnt work then i dont have option and take it to saab dealer.
Old 10th June 2011
SebastianG's Avatar
SebastianG SebastianG is offline
My Saabs: 2006 Saab 9-3 Aero
1 Don't panic. Like mentioned before, its most likely your battery.
Old 10th June 2011
Saabstory34's Avatar
Saabstory34 Saabstory34 is offline
My Saabs: 2006 Saab 9 2.0T Custom E85 tune by JZW
Garage
I had the same issue after my tie rod ends were replaced on my car. After about 2 weeks it just cleared itself up and now I no longer have the problem.
Edit: I just want to make sure I read correctly, you can still turn your key and start the car correct?
JZW Custom E85 Tune, JT 3" DP with 3" exhaust, Spec 2+ clutch, H&R Springs, Koni yellows, TSW Nogaro 19s wrapped in 245/35R19 Hankook Ventus V12 Evo, boost gauge, TWM Short Shifter
Old 10th June 2011
no it doesn't let me turn the key
Old 10th June 2011
PTCsanchez PTCsanchez is offline
My Saabs: 03 9-3 linear
Yeah sounds like the batt has passed on. Also check the batt cables for corrosion. My car did the same thing back in march. Turned out to be very corroded batt cable.
Old 10th June 2011
but i can still open and lock the car with the keys so does the car do that even though if a battery is dead?
Old 10th June 2011
JMarkert's Avatar
Yes, sometimes, mostly . The computer and starter seem to get flakey when the battery is low. Locks, lights, radio etc might seem just fine.
Old 10th June 2011
bubbalee bubbalee is offline
My Saabs: 2006 Saab 9-3 Aero V6
Default Get for a New Battery
It doesn't matter. My car started fine and everything worked properly but once those messages start appearing on your SID, your battery is dying. The dealer explained that Saab's have many electronics that continually go one once the car is turned off. It is time for a new battery.
Old 10th June 2011
MI-Roger MI-Roger is offline
My Saabs: '08 9-5 Aero, '06 9-3SC, '00 Viggen
Your battery still has voltage, but it doesn't have enough amperage to power the starter motor - the single largest power draw. Time for a new battery.
2008 9-5 Aero Sedan
2006 9-3SC 2.0T
2000 Viggen Convertible
2000 9-5 lpt Sedan, Retired at 318,000 miles
Old 10th June 2011
problem solved disconnected battery and it works now thanks for the helps guys
Old 10th June 2011
lschu440 lschu440 is offline
New Member
My Saabs: 2003 9-3
Hi there,
I had the same exact problem happen and it turned out to be that they needed to replace the ignition switch. I think it was around $500 if I remember correctly.
Old 11th June 2011
maybe ur right cuz problem came back
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
steering lock malf/wont lock etc timmmy 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 5 2nd January 2011 05:43 PM
"Steering lock malfunc" langers_00 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 7 14th June 2010 07:46 PM
Steering wheel lock malfunc warning!! nuch25 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 1 20th September 2007 06:38 PM
To lock or not to lock (steering) Silver Poppy 9-5 Workshop 6 27th December 2005 06:18 PM
Steering lock Woodman 9-5 Workshop 4 24th February 2005 01:51 PM
