SRS light - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > 9000 Workshop
9000 Workshop 9000 (1985-1998) Technical Forum
Old 5th June 2011
cghag1 cghag1 is offline
My Saabs: '87 900 8V, '99 9-5 S
Default SRS light
I had the dash apart on my wife's '95 9000 cs to correct some gauge cluster lighting issues. I think I've corrected the problem with the cluster going completely dark at random times, plus I replaced a couple of bulbs so the information screen lights up as it should. Now the SRS light is on continuously.
Other than completely removing the instrument cluster and unplugging all the connections to the cluster, I did not touch anything related to the airbags. Does anybody have a suggestion as to where I should start? My assumption is that I may have failed to reconnect one of the plugs properly, but I thought I'd throw this problem out there in case anyone had a suggestion. I'm also assuming I'll need to take the dash apart once more and verify that everything is as it should be.
Thanks in advance!
Dave
Laugh often, it's life's lubricant!
Old 6th June 2011
JeffCullen JeffCullen is offline
My Saabs: '85 SPG (11/84), '89 SPG (01/89)
I suspect you disturbed the clockspring connection. You absolutely will require someone with an ISAT or Tech 2 (dealer, well equipped indy, local Saab nutcase) to clear the code you have caused.
SAABCENTRAL.COM -- where the kool-aid never runs dry, and misinformation is always on special!
Old 6th June 2011
Jim Mesthene's Avatar
Jim Mesthene Jim Mesthene is offline
Saabista
My Saabs: Wife's 9-3
Or, if you turned the Ignition on to check your bulbs without having every part of the SRS system installed (including the light itself), you set a code that requires a Tech II to reset.
Either way, you'll have to visit a Dealer or very well-equipped SAAB independent shop to diagnose and reset.
The fact that there's a Highway to Hell and only a Stairway to Heaven says a lot about anticipated traffic numbers...
Old 6th June 2011
SaabKen's Avatar
SaabKen SaabKen is offline
My Saabs: '06 9 2.0T Combi, BCB Stg 2
Garage
So if the light itself wasn't reconnected when re-starting, that would trigger an error code (and light up SRS once it is reconnected itself) ?
2006 9 2.0T SportCombi BCB Stg 2 | 2004 Subaru Outback H6 3.0 | 1993 9000 CSE (RIP)
"Honesty is the best policy, but insanity is a better defense." - Steve Landesberg
Old 6th June 2011
Saabista
Yes elkparts
Old 6th June 2011
Yes
While I don't remember my full sequence of events, I'm confident I did indeed turn on the car without having everything plugged in so I could check the voltage from the wiring harness and see that the bulb repair worked. Oh well. I guess it's time to pay a visit to my local indy mechanic, or the dealer if need be. Live and learn!
Thanks everyone!
Old 7th June 2011
chengny's Avatar
chengny chengny is offline
My Saabs: 96 9K CSE, 97 9K CS, 96 9K CS, 94 9K CSE
"I had the dash apart on my wife's '95 9000 cs to correct some gauge cluster lighting issues. I think I've corrected the problem with the cluster going completely dark at random times, plus I replaced a couple of bulbs so the information screen lights up as it should. Now the SRS light is on continuously."
Maybe a stupid question but;
Is it possible that one of the bulbs you replaced was the SRS MIL?
If it was burnt out, the control module may have been activated at some point in the past. Now since a new lamp has been installed it might seem as if a new problem has developed.
I'm not being very articulate - but you know what I mean? It might have been trying to tell you that the SRS was inop for a long time. But without a functioning lamp, who would know?
Did you change this bulb?
Old 8th June 2011
santeria600's Avatar
santeria600 santeria600 is offline
My Saabs: '96 9000 2.3 CSE LPT Auto
I've got the same issue with my SRS light staying on too. For my part I replaced the ignition contact switch which seems to have set it off. Battery negative terminal was disconnected during the work and I left the steering wheel alone, simply removed the shrouds and was extremely careful to not disturb any of the airbag related wiring.
I'll get the dealer to have a look during the forthcoming MOT.
Owned:
'80 900GLe Auto 5dr/'84 99GL/'85 900t16 3dr/'86 9000t16 Own: '96 9000CSE 2.3 Auto
Old 9th June 2011
Very good question!
That bulb was fine and functioning as it should. That is until I changed the bulbs in the center info display area (miles to empty, mpg, PRND123, etc.)! I'm sure that when I was replacing those bad bulbs I turned on the ignition to see if they worked, but did not have all the other plugs connected. Hence the SRS warning light staying on after I completely reassembled the dash.
Anyway, I just came back from a local independent garage and they reset the light for me. No clue, however, what the cost will be. They'll just mail me a bill. Probably $30-$50, but that's what I get for screwing it up. Next time I'll know better! Doesn't mean I won't do something stupid somewhere else on the car, but I'm good to go when I next decide to replace a bad bulb in the gauge cluster.
Old 9th June 2011
rawill's Avatar
rawill rawill is offline
My Saabs: 06 93 2.0,93 9000griffin 92 900s LPT vrt
Exactly what I did!!, 1200km later after a visit to the agent it was all good.
I turned the key on with the SRS system disconnected, to check lights etc!!
However I found I also had water in the SRS ecu, so it was only a matter of time before something went bang! So I was happy I made the "mistake"!
03 V6 Renault Laguna! 06 93 Linear 2.0t, 93 9000 griffin 2.3 St-II. 93 9000CSI na man,350,000km. 92 900 S LPT vert.
Old 9th June 2011
Eazy-O's Avatar
Eazy-O Eazy-O is offline
My Saabs: '96 9000 CSE 2.3T @ 240ish HP
My SRS light has been on since I got my 9000... I've been told it's nothing to worry about. It could be a problem like some of you guys have with something being disconnected in the past (car had an engine swap) or a problem with the SRS itself?
How would I go about diagnosing which is it? Suppose I reset the error, will the light come back on if there is an actual problem with the SRS? I suppose it should, since the problem would still be there and the computer should still check for it... But heck do I know.
Thanks in advance :)
Old 10th June 2011
rawill's Avatar
I think the only way to diagnose the problem is to get an agent or someone with Saab Tech II to plug in and read the fault for you.
Here in NZ we can not get a WOF/MOT with the light on, so it has to be fixed or we can not take it on the road.
Old 10th June 2011
Eazy-O's Avatar
Thanks for the quick reply, I'll go bug our club president for his Tech II again.
We have a bunch of points for MOT failure, but the SRS light is not one of them. I think. They didn't bother with it last year.
Old 10th June 2011
1quickbeater's Avatar
1quickbeater 1quickbeater is offline
My Saabs: '88 Saab 9K Turbo
Garage
MOT and WOT????
i love saabin' but the blazer is my baby!
Old 10th June 2011
rawill's Avatar
Originally Posted by 1quickbeater View Post
MOT and WOT????
WOF in NZ is a 6 monthly vehicle inspection which you must pass to let vehicle be on the road, MOT is the UK inspection for a similar purpose (I think- UK person can correct this).
Old 3rd July 2014
jnormie2011 jnormie2011 is offline
New Member
My Saabs: 1992 Saab 900 turbo Convertable
Cool Simple fix to blinking SRS on 1992 900 turbo
There are 2 screws on the dashboard speaker. Remove the screws, lift the speaker and pull the "bloody" light out.
Old 3rd July 2014
Saabista
Thus ensuring your airbags and seat belt tensioners won't work. The belts are too long to be effective without the tensioners.
Last edited by Jim Mesthene; 4th July 2014 at 01:15 AM. Reason: apostrophe missing
Old 4th July 2014
davide c davide c is offline
My Saabs: 9000
Yessss. the 'explosive' seat belt tensioner gizmos are a potential grey area loss.
There are still the required (as in any other car) self lockers on the belts .. which presupposes one is capable enough to fit one's belts adequately.
My view is that the Airbags loss isn't a major problem
I've seen the carnage that the early primitive/brutish airbag contraptions caused. IMO not having those isn't as bad as words suggest.
Old 4th July 2014
Saabista
I saw less blood in the wrecked cars towed in, after the cars got airbags.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Few issues. Cluster light, window off track, fasten seltbelt light cover. Xugos NG900 & OG9-3 Workshop 1 11th August 2010 03:51 AM
Draper Airbag light reset tool and common SRS light fault. Chris_300 NG900 & OG9-3 Workshop 3 19th February 2010 05:54 PM
Failed Inspection! - OBD Malfunc. Indicator Light and Odometer Light not workign! dougwentzel NG900 & OG9-3 Workshop 4 18th September 2009 07:21 AM
central warning light, flashing engine light, and battery light haedong12 9-5 Workshop 6 20th June 2006 02:56 AM
Warning Light + ABS Light + Brake Light, they are all on! 9-5inLA 9-5 Workshop 52 25th March 2006 01:34 AM
