New intercooler idea!... Maby - SaabCentral Forums
Go Back   SaabCentral Forums > Classic Saab 900, 1979-1993 & 94 Convertible > Classic Saab 900 Performance, Mods & Tuning
Classic Saab 900 Performance, Mods & Tuning Covers Tuning & Performance modifications for the Classic Saab 900
Old 26-01-04
henderd henderd is offline
Default New intercooler idea!... Maby
I was checking out the new audi s3 and saw that it runs 2 small intercoolers at the two front corners of the car.
http://www.s-cars.org/s3/Gallery/S3_...allery_48.html
I think this will work in a 900 clasic turbo.
Has anyone seen this?
Has anyone given this some thought?
I think it will work with one modified (shortened) IC to turbo pipe running to the "new" stock 900IC placed in front of the battrey, a custome crossover pipe to the stock IC then in to the throttle body as usual. I think it will work.
I am in to the "junkyard" upgrades, as I am hardly employed now.
Old 26-01-04
DeLorean DeLorean is offline
there are a lot of intercooler options out there, many more complex than others! What a lot of people here will tell you is to go with a Volvo 740 intercooler with the C-900. The Volvo intercooler is massive compared to the classic 900 intercooler, and it's front mount so it will get much more airflow as well... the reason my SPG does not have one is because in my opinion the pipe work required to install the unit hangs too low to the ground for a safety margin Something to think about may be to get a volvo intercooler and change the end caps to something that's custom. That should eliminate the problems with routing the intercooler pipe work. the dual IC idea is neat, but to my knowledge no one has ever tried it. For all out performance, you want an FMIC. it's simply the best way to go for maximum intercooling. Anyway, just posting a few ideas!
http://www.saabcentral.com/techhelp/...ic/default.htm
That's a link to Petes set up, but you know my problem with that :-? Still, there may be some way to make it work...
Old 26-01-04
Thanks for the input jeff.
I do not like the Volvo IC: too much front-end modd, susceptible to damage, plus lots of time. I think the extra thermal mass of a second IC would give my modest 15 psi of boost just what it needs (only 91 octane in Denver ). With two IC fans, some ducting in the front bumper, should give me more than twice the stock intercooling capacity.
David
Old 27-01-04
Matthew's Avatar
Matthew Matthew is offline
Saab Mad
My Saabs: 900 S Aero Turbo, 9-5 Aero
The Volvo IC flows only 200CFM due to its thin core and miniature channels. If you accept the rule that required airflow = BHP x 1.5, then the 200CFM Volvo is good for a shade under 134BHP.
The IC is unlikely to saturate due to its huge size, but it will strangle your engine's airflow IMO. This has the effect of making the turbocharger work harder than it has to, with consequent rise in EGT and intake charge temp.
Old 27-01-04
Janne Selinummi Janne Selinummi is offline
It's also worth a note, that the standard I/C of the C900 is a bad design by flow standards as well. It will feature quite a lot of pressure drop when used under high boost, and two similar units connected would just make that worse. You would end up losing lots of the gained hp because of that pressure drop. I wouldn't go for a Volvo I/C nor a 9000 I/C, since all they are in the end, are just standard OE parts with poor flow. Get a thicker, better flowing core from a truck, for example, and have some smoothly-shaped alloy end tanks made. Then fit the thing in front of the radiator, and you will have real intercooling!
Old 27-01-04
Matthew's Avatar
Saab Mad
The C900 IC as a complete unit is a poorly performing intercooler. However, this IMO isn't due to bad core design but it because of the location, forced airflow U-turn and the small core size.
Forget for a moment all the above factors which compromise the intercooler's performance.
If you analyse cross-sectional area of the channels on a late-model core, they're really quite a good size. In fact, it's a better design IMO than some aftermarket ICs (Pace springs to mind).
If the C900 core was three times the size, with alloy end-tanks and top-to-bottom airflow, you'd have a very capable IC: excellent airflow, significant thermal mass and short channel lengths.
All IMHO of course
Old 27-01-04
tandino tandino is offline
This test (Autospeed) wasnt a conclusive 'flow bench' test iirc,
Afaic there is no definative cfm test for the Volvo i/c,
Agreed the Volvo i/c is not the best flowing i/c out there but for its chargecooling ability it does a good job for little money,
Throttle response in my car subjectively did not change when installing the Volvo from the stock C900 i/c...
Iirc the tests i have seen highlighted the Volvo i/c was more efficient than the Saab 9000 i/c and there are plenty of 9000's running around producing 300+bhp on the stock i/c.
I also cant see Volvo installing a i/c rated at &lt;134bhp on a car which as standard produced 180+bhp - Volvo have been in the turbo game as long/longer than Saab in terms of HGV's so i doubt they would overlook this simple calculation....
Pete.
Old 27-01-04
mattfaulks mattfaulks is offline
Location: Hinckley, Current: 9-5 2.3T aka F/R 5, Ex - F900, F9000
All IMHO of course
Shall I get the TIG welder out?
Old 27-01-04
Alex's Avatar
Alex Alex is offline
My Saabs: 3dr c900 T16RA, 9-5 Aero Estate
Pete.
The Autospeed test was a good comparative test, its the shame that the Saab IC wasn't tested at the same time (infact the original wording on the Autospeed test was Saab/Volvo as they weren't sure which car the IC came from) as the 'leaf blower' test didn't really flow enough air to be representative.
Old 27-01-04
uberfast's Avatar
uberfast uberfast is offline
My Saabs: 1986 Saab 900 16v Turbo
Yeah I thought about creting a setup useing two c900 8v turbo ic's... the alloy ones. Using an airflow bumper would help out the most py proving a good amoutn of both room for two seperate ic's and to flow a good amount of air to each ic. I'll have to draw a diagram some time.
Old 27-01-04
Widde's Avatar
Widde Widde is offline
My Saabs: 88 900 aero, 02 9-3 aero, 97 900t cab
I've got my two stock 900ic at my local welder right now . Two are becoming one (crossflow ofcourse :wink: )
The welder has time until march until it needs to be done so it might be awhile until pictures and data will be avaible.
first sketch (pipes will be 2.5" in the finished IC)
Old 27-01-04
What about turning the core so that the tubes would be vertical? Then take the inlet-outlet pipes from the ends of the end tanks - this would make for an ideal shape, according to Corky Bell, and it would result in better flow and more even cooling... Just an idea!
Old 27-01-04
ejenner's Avatar
ejenner ejenner is offline
Banned
My Saabs: 900 Carlsson, 99t, 99 T16, 900 t16 vert
How does the Abbott chargecooler system fit in here?
Just read the entire thread - (since getting into Saabs) - I only know that intercoolers are important but have heard so much info on different options that there does not appear a to be a device or setup that really stands out.
Obviously Abbotts talk-up they're own system - not always best to go with what you read on commercial sites though!
Old 27-01-04
Matthew's Avatar
Saab Mad
There was a bit of discussion on the Abbott chargecooler in this thread:
http://www.saabcentral.com/forums/viewtopic.php?t=11198
Old 27-01-04
ejenner's Avatar
Banned
That's all quite interesting - RE: Abbott chargecooler thread.
Someone was saying the Abbott setup was 140cfm - this post says the volvo unit is 206cfm - if I remember right.
Volvo unit is the obvious way to go - ??
Old 27-01-04
Alex's Avatar
The cfm figures do depend on what test circumstances are used. There is no mention of inlet pressure at all for the Abbott figures and their cfm for the standard c900 IC is only enough for 65bhp!
The Autospeed figures are relative against the other ICs in the test, not absolute values.
Old 28-01-04
boxman's Avatar
boxman boxman is offline
My Saabs: 9-3 SS Aero TTiD + 9-3 SV Aero
i thought of doing this on a 99 that i fitted a t16 to but
a) there wasnt room
b) i decided that there would be too much heat soak from the turbo its self therefor heating the charge air not cooling it as planned
