P0705 Fault Code Problem - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9-5 Mk.II, 2010 onwards > 9-5 Workshop
9-5 Workshop 9-5 2010 onwards Technical Forum
Old 3rd June 2011
BenP BenP is offline
My Saabs: 2000 9-5 SE Wagon, 2000 9-5 Aero Wagon
Default P0705 Fault Code Problem
I've gotten to the end of my guess work on my own so I could use a little help from the membership here. I've got a 2000 9-5 Aero Estate wih an auotmatic transmission.
I started getting a P0705 fault code several months ago which usually indicates a neutral safety switch going bad. This resulted in the check engine light coming on with the check transmission light and going into the limp home mode. I reset the code and it drove normally for awhile but then the car wouldn't start a couple of times without rowing through the gears and the the code couldn't be cleared. I decided to rebuild the switch and it didn't solve my problem so I thought I had messed up the rebuild and bought a new $300 switch with the same result.
Help!
Are there any other causes for this code? I thought it might have been a Tech 2 reset only so I drove by my Indy and he had the same result. I put the rebuilt switch back in and now I'm looking for other possible causes. I can clear the code, start the car and as soon as all the diagnostic tests light go out the same two come back on and I'm back in the limp mode.
Anyone have experience down this path?
Thanks in advance for the replies!
Benp
Old 3rd June 2011
Default Sorry Wrong Forum
I moved this to the correct forum.
Sorry!
Benp
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
ACC Problem (but no fault code!) help please AIrey1507 9-5 Workshop 12 27th October 2014 08:39 PM
P0705 fault code stewartbaldwin NG900 & OG9-3 Workshop 2 21st October 2009 04:18 PM
9-5 Auto Problem - Fault Code PO 7306 Airflow1 9-5 Workshop 8 29th November 2008 10:18 AM
P0705, P1312, P1334 fault codes stewartbaldwin NG900 & OG9-3 Workshop 4 8th September 2008 02:59 PM
ACC Fault Code 08 & 13 and crank no start problem (CPS?). connie_russ 9-5 Performance, Mods & Tuning 4 19th October 2006 07:00 AM
