Cooling fan staying on longer than it should - SaabCentral Forums
Old 24-05-11
05Aero21's Avatar
05Aero21 05Aero21 is offline
My Saabs: Steel Grey 05 Aero automatic
Default Cooling fan staying on longer than it should
Engine/radiator fan- can't really hear it kick on while driving through town or at a stop. Usually I'll hear it come on once I get in my driveway. Normally it will stay on 40-50 sec. Last couple of days it has stayed on at least 3 minutes. It would probably go longer if I left the car running, but after that long I shut it off. I normally wait till it kicks off before shutting the car off.........paranoid, phobia, anal... I don't know. I just do it.
Causes, fix appreciated!
Women have the uncanny talent of asking a question and making a statement at the same time:
"Your going to do that today right?"
Not that there is anything wrong w/that.
Old 25-05-11
eggsngrits's Avatar
eggsngrits eggsngrits is offline
My Saabs: 1991 900 16v Turbo Conv. SE, 1999 9-5 SE
Best guess -- you're starting to use your A/C and the fan has more to cool.
Second guess -- bad thermostat.
Mike / Mike's Flickr
Old 25-05-11
porsche996 porsche996 is offline
My Saabs: US
Garage
The hotter the outside temperature, and the longer you sit there with the car idling in your driveway, the hotter the engine will get, the longer the fan will run...
Essentially, you're causing it to run longer by sitting and idling.
There is no need to sit there idling waiting on the fan to turn off. It will stay on a little bit after you shut down the engine (it's supposed to....), and that's not a big deal.
Old 25-05-11
05Aero21's Avatar
Makes sense, although it has not done so since my original post. These engines really run hot and take longer to cool down,don't they?
Similar Threads
SRS light staying on rawill Saab 9000 Workshop 41 24-03-13 09:59 PM
Staying cold SDTurboEstate Saab 9-5 Workshop 8 06-12-10 01:56 PM
Engine cooling fan staying on! quann Classic Saab 900 Workshop 3 22-05-09 05:17 PM
air con switch not staying on superseven Saab 9-3 & NG900 Workshop 8 21-06-05 01:05 PM
starts get longer and longer... saabkid37 Saab 9000 Workshop 8 18-05-04 01:56 AM
