code P0455 "Gross Evap Leak" and the Purge Valve - SaabCentral Forums
Old 18th May 2011
jwwells's Avatar
jwwells jwwells is offline
My Saabs: 2000 9⁵ 5-speed Stg1 207K Miles
Default code P0455 "Gross Evap Leak" and the Purge Valve
Hey All
I am working on a 99 9-3 Vert that has the P0455 "Gross Evap Leak" code and has been on for quite some time. The gas cap is sealed and all looks good without dropping the gas tank and looking around there. I've been doing quite a bit of research and want some opinions as to the legitimacy of my proposed repair.
Here's a brief description of the EVAP system.
When liquid gas is being filled into the fuel tank and sloshing around there is quite a bit of vapor hydrocarbons which need to be taken care of (not released into the atmosphere). The way they deal with it is vent the vapor first into a canister with carbon pellets in it which absorbs these free hydrocarbons. Then while you are running the engine the vacuum from the engine is used to draw the hydrocarbons out of the charcoal canister and into the combustion chamber to be burned.
Now the purge valve. The purge valve is a simple solenoid which is electromechanical which means when it is supplied power it opens to allow the vacuum to draw the hydrocarbons, but when the engine is off and no power is being supplied it is closed. The P0455 code is thrown when the pressure in the tank is too high and there isn't a vacuum present. This would indicate to the computer that perhaps the gas cap is off or some other leak. This could also be the case if the vacuum from the engine were being blocked entirely.
Here's what I did.
I pulled this purge valve and tried to clean it then after I plugged it back in and tried blowing through it with the engine running (it should be open when the ignition is ON) it was completely blocked no air moving through. So I bypassed this purge valve and used a one way valve from a parts car brake booster vacuum line. It now draws a healthy vacuum and although I haven't driven it for awhile hopefully it will now register the proper pressure (low) in the tank.
Will this work?
Is my understanding and overview of the system correct? Most of this info is from my reading on WIS.
Thanks, sorry for the long post.
2000 9⁵ Black 2.3 5-Speed TD-04, ECUproject Biopower Tuned Stage 1- 196K miles
2001 9⁵ Black Auto Aero Wagon
Old 18th May 2011
Frank_Drebin's Avatar
Frank_Drebin Frank_Drebin is offline
My Saabs: '96 900 `04 9 Arc Vert
Originally Posted by jwwells View Post
Hey All
Here's what I did.
Will this work?
You would do better to disconnect it and seal the line from the TB. Let the Evap valve vent to atmosphere. Having a constant pull will surely cause fuel flow issues at lower fuel levels.
Old 18th May 2011
jwwells's Avatar
Well that would put me in the same position I am in now throwing the CEL and it won't pass inspection. Just curious... how would a vacuum in the tank cause fuel flow issues?
Thanks for the input!
Old 18th May 2011
watkins's Avatar
watkins watkins is offline
My Saabs: '99 Viggen
The purge valve is not open all the time when the engine is running. Only under certain situations. It also cycles rather than staying open or closed. The blow test doesnt mean much
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
"HOW TO" replace EVAP Purge Valve on 2.8T V6 Ferms_93_2.8T 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 87 7th June 2016 12:11 PM
P0455-EVAP large leak-?? jswain 9-5 Workshop 9 10th April 2011 09:06 PM
"Gross evap leak" code....??? nightskyisme 9-5 Workshop 36 1st May 2010 06:38 PM
P0455 Gross evap leak questions TwoManyPassats NG900 & OG9-3 Workshop 9 4th September 2009 12:02 PM
TPS or EVAP purge valve lancelot8602 NG900 & OG9-3 Workshop 3 9th July 2008 02:34 PM
