Is this this the correct way to test a DIC (Direct Ignition Cassette) - SaabCentral Forums
Old 25-04-11
brupoo brupoo is offline
My Saabs: 1995 900 S 3Dr
Default Is this this the correct way to test a DIC (Direct Ignition Cassette)
Hi guys, I know its considered pretty dangerous to test the DIC's in the manner described on the saabsite, but I think i'l going to have to do it. I am about to purchase a car and I am 95% sure it doesn't start because of a bad DIC, so I am going to check out the car and test it if I can, most likely it is dead so It may not actually be that dangerous. Anyhow, understanding that it is dangerous, I want to go about this correctly and minimize problems, so I read the description and this image is what I understood as the way to go about it.
Does that seem right?
Old 25-04-11
'97 Saab SE Turbo's Avatar
'97 Saab SE Turbo '97 Saab SE Turbo is offline
My Saabs: Black on black '97 Saab 3-door SE Turbo
You need to ground all the plugs at the threads, then plug in the DIC and turn the engine over to check for spark. But, a faulty CPS will keep the DIC from firing.
A bad CPS may be determined by watching the tach; no movement generally points to a bad CPS. You can also take a multimeter with you to check resistance in the CPS. IIRC, 580 +/- ohms for a turbo car is a good test.
If you have spark, a little starting fluid in the throttle body should get it to fire for a second or two.
But, if you get the engine running the owner my not want to sell it... Ron
Old 25-04-11
THanks for the reply '97
A couple clarifications:
Would I do one wire to each thread, or use one long wire wrapped around each thread in series as I drew in my masterpiece originally?
I have my multimeter, set to resistance/ohms, what part of the CPS should I be touching with the ends though?
Thanks!
Old 25-04-11
The wiring doesn't matter; one long ground cable or four separate cables. The test cable in the WIS has one large alligator clip for each plug, and a fifth clip to ground on the engine/frame.
To check the CPS, remove the cable connector, rotate the connector so that the tab is up, and looking at the pins, they number 1, 2, 3 from left to right. Pins 1 & 2 should measure 540 +/-55 ohms and pins 1 & 3 should measure infinity (or an open)... Ron
Similar Threads
Wanted: Direct Ignition Cassette (ignition discharge module) auk Parts for Sale/Wanted - North America 0 27-08-10 09:21 AM
direct ignition cassette?????? DJamesUofM Saab 9-5 Workshop 3 26-08-10 10:02 PM
Wanted: Direct Ignition Cassette glassybarrel Parts for Sale/Wanted - North America 0 04-01-10 05:04 PM
direct ignition cassette boosterseat Saab 9-3 & NG900 Workshop 10 31-05-07 05:44 PM
Direct ignition cassette SPG85 Classic Saab 900 Workshop 3 06-07-04 08:56 PM
