Evaporative Emission Control System leak- gross leak detected - Any ideas? - SaabCentral Forums
Old 19th April 2011
bequino bequino is offline
My Saabs: 1997 Saab 900 SE Turbo
Default Evaporative Emission Control System leak- gross leak detected - Any ideas?
My check engine light came on about a month ago. I went to autozone and pulled the CEL code. It first came back as a "P0442 Evaporative Emission Control System leak Detected (small leak)". Usually that is a bad gas cap. I replaced the cap, then cleared the codes. The CEL came back, this time as a "gross leak detected". I have pulled and lubricated the 'purge valve", and it seems to be functioning and "ticking" properly. All vacuum tubes are in place and seem to be in good shape. The car runs perfectly, and idles even better. Any ideas, before I take it to an official SAAB tech, and pay out the rear end? BTW I have a 1997 Saab 900SE Turbo 106k mi. Thank you!
Old 19th April 2011
hkayssi hkayssi is offline
My Saabs: 1997 900S
Check the vacuum hoses going to the Evap valve one is probably split or broken
Old 20th April 2011
Cm452 Cm452 is offline
My Saabs: T5 Suited Stg T28++ 9-3
You've got is backwards; a small leak is generally a vacuum line or cracked hose, a big'un is from a faulty gas cap or an 'effed charcoal canister.
The charcoal canister is near the gas tank, its a black box about the size of a "munchkins" box from dunkin donuts. Make sure the hoses are connected and integral to that and make sure you have an EXACT oem gas cap.
Best of luck,
-Cm
P.s I struggled with issues like this foooooooooooooooooooorever. I had a bad tune on my ECU FWIW.
Old 20th April 2011
Thanks for the info guys. I replaced the gas cap with an autozone equivalent part, maybe ill look into getting an actual Saab OEM gas cap. I will also check the charcoal canister and vacuum lines this weekend. It may be appropriate if I just swap all the visible vacuum lines out, seeing as tubing is pretty inexpensive. Someone also suggested the fuel filler neck... Looks like I have some more investigating to do!
BGE
Old 20th April 2011
My Saabs: 1997 900S
BGE
That usually causes some bucking and an inaccurate fuel level reading. You may also have a deformed gas tank in that case.
Old 28th December 2011
SpongeBob's Avatar
SpongeBob SpongeBob is offline
My Saabs: Peruse my photo gallery.
Default Same problem
Can you please tell me where the EVAP VALVE is located. Also the charcoal cannister - I read thats near the gas tank but where?
I suspect that my problem may be at the cannister or filler neck because the fault shows up usually when I go through a car wash - so perhaps the force of the water on the underside may be moving something.
earthworm's Avatar
Saab Sage!
I suspect that my problem may be at the cannister or filler neck because the fault shows up usually when I go through a car wash - so perhaps the force of the water on the underside may be moving something. Possible, check the tanks security and vent system...
As I recall, its above the master cylinder area.
http://www.saabcentral.com/forums/sh...d.php?t=204594
Money was wasted on the fuel caps, unfortuniately..There should be a way of testing a cap. Maybe a little blue or white chalk on the sealing surface ???
I suspect a malfunctioning purge valve..And the things controlling it could be suspect...
The earthworm
'96 900S, Automatic
busaboy busaboy is online now
My Saabs: 2000 Viggen 5-door
EVAP purge valve is right next to the right shock tower, just behind the airbox.
SpongeBob's Avatar
Thanks...
tax tax is offline
My Saabs: 1997 900se
My charcoal canister is in the right front wheel well - I also have a 97 900 SE turbo
Good luck - I'm still trying to figure mine out - without taking it to a shop to blow smoke
up a tube.
Tax
Old 29th December 2011
My Saabs: 1997 900S
Charcoal canister is under the passenger side fender behind the plastic skirt behind the wheel well. The Evap valve is located on the firewall. Just follow the medium sized hose behind the throttle body to find it; it's mounted to the passenger side shock tower.
Make sure you perfor the ralls on the fuel system
http://www.automallusa.net/2001/saab/9-3/recalls.html
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
P0455 Evaporative Emission Control System Leak Detected scdevils2 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 10 20th January 2016 04:14 PM
P0455 Gross evap leak questions TwoManyPassats NG900 & OG9-3 Workshop 9 4th September 2009 12:02 PM
Large Evap Leak detected. michaLcoughliN 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 2 15th November 2007 02:17 PM
Evaporative emission cannister pkb2109 C900 Workshop 5 4th September 2003 06:47 AM
Evaporative emission control canister garry NG900 & OG9-3 Performance, Mods & Tuning 0 18th August 2003 05:42 PM
