What is acc fault code 11? - SaabCentral Forums
Old 18th April 2011
Superwiser5 Superwiser5 is offline
My Saabs: 2000 Saab 9-5
Default What is acc fault code 11?
I fixed the 08 code with the saabservices.com part and I still have a code 11. What is it and how do I fix it? I get random hot air in the back and passenger side while driving with the air conditioning on...
Old 19th April 2011
LEP3 LEP3 is offline
My Saabs: 2001 9-5 Aero
Garage
There is a huge amount of information in the FAQ on this, check there.
Old 19th April 2011
bob3000's Avatar
bob3000 bob3000 is offline
My Saabs: 2000 9-5 AERO 5spd man MPS STG2
http://www.saabcentral.com/forums/sh...d.php?t=117379
Old 19th April 2011
Jssaab Jssaab is offline
My Saabs: 2000 9-5 320hp, 2003 Aero Hirsch "Clone"
I have seen that code when the servo motor shaft was no longer engagned into the gears, take the motors out ( there are 3 start at the one where the arm is that you replaced) and press the shaft back in to engage the gears) if that isnt the problem one of the servo motors is dead ( most probably the one where the arm is it can get burnt out when its jammed by the broken arm
Old 19th April 2011
Saaber95er's Avatar
Saaber95er Saaber95er is offline
My Saabs: 1999 9-5 SE 5spd
Garage
SAAB ACC codes. Press AUTO & OFF simultaneously to view.-
CODE
ITEM
Open/Short
Jammed
Loose
01
ACC internal fault
02
cabin temp sensor
03
solar sensor
04
left mixed air temp sensor
05
right mixed air temp sensor
06
left blend door
07
left blend door
08
left blend door
09
right blend door
10
right blend door
11
right blend door
12
air distribution motor
13
14
15
16
17
18
heater valve solenoid
19
heater circulation pump
20
control circuit blower
check fan control
21
Recirculate motor
22
Reflash per SB 271-2206
23
control module sensor ground
missing
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
AC Fault code helmetvonthrob 9-5 Workshop 7 1st August 2010 06:39 PM
fault code albertan NG900 & OG9-3 Workshop 2 28th March 2010 11:52 AM
fault code joelee 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 0 16th March 2008 08:03 AM
Gunson fault code / flash code reader nbell C900 Workshop 27 18th April 2007 02:27 PM
ACC Fault code 5 and 9 grex25 9-5 Workshop 3 8th February 2007 12:19 PM
