center console power outlet not working. - SaabCentral Forums
Old 18th April 2011
Titansaab27's Avatar
Titansaab27 Titansaab27 is offline
My Saabs: 9-3 Aero Vtune stage 0 rev 2
Default center console power outlet not working.
the other day i went to go use my ipod and i find that it's almost dead. this struck me as weird since it is pretty much permanently plugged into the socket in the center console. after much testing out, i found that the socket is dead, and the bulb that is adjacent to it is burnt out. are these connected? if so how can i replace the bulb? its completely enclosed.
help would be appreciated.
2007 Saab 9-3 Aero ---> Mods: Vtune Stage 0 rev. 2.01, custom short ram intake, GS 3pt subframe brace, Maptun Strut bar.
Old 18th April 2011
Saabstory34's Avatar
Saabstory34 Saabstory34 is offline
My Saabs: 2006 Saab 9≥ 2.0T Custom E85 tune by JZW
Garage
Could be coincidence, but you might also want to check your fuses. (I dont know which one it would be, but a test light, or volt meter can find out quickly)
As far as how to replace a light, honestly I have so much **** in mine I didnt know there was a light in there
JZW Custom E85 Tune, JT 3" DP with 3" exhaust, Spec 2+ clutch, H&R Springs, Koni yellows, TSW Nogaro 19s wrapped in 245/35R19 Hankook Ventus V12 Evo, boost gauge, TWM Short Shifter
Old 18th April 2011
stpoolshark's Avatar
stpoolshark stpoolshark is offline
My Saabs: 2004 9-3 linear
I have the same problem. My center console outlet is dead, but the one next to the flip down tray works fine. I didn't know there was a bulb in there either
If anyone has a way to fix it then I'd definately like to know too.
Old 18th April 2011
PaulOliver's Avatar
PaulOliver PaulOliver is offline
My Saabs: 93 2.2tid Vector Sport
To replace the bulb and check the wiring, you literally need to yank out the unit, it kinda pops out. Behind will be 3 wires, 2 going to the socket and 1 to the bulb. To remove the bulb, you need to push in some clips. I replaced mine with a green led (and ran a resistor on the wire that powers it) as it'll last longer
04 Saab 9-3 2.2 TID Vector Sport. 6K dips, 3K projector fogs, LED sides, Nav, Aero Leather, Boston S35 dash, Fli rear, Infinity doors, JL sub, hidden park sensors, pressed plates, full LED interior lights, black badges, M5 window spoiler, 08+ bridge spoiler, colour coded bump strips, washers and nav fin, Aero front splitter, Duplex straight through exhaust
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Center console cigarette lighter -- No Power lukin36 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 1 22nd September 2009 11:01 PM
Center Console Outlet furstwinhall 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 7 9th November 2007 12:12 PM
Power in center console Archangel6 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 2 1st June 2006 11:04 PM
12v outlet not working TenTonHammer 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 3 4th February 2006 01:23 AM
Rear Console Cigarette Lighter Outlet postpunk 9-5 Workshop 0 19th May 2005 08:38 AM
