standard transmission fluid - SaabCentral Forums
Old 17th April 2011
supasaab9k supasaab9k is offline
My Saabs: 1993 9000CSE 5 speed 1996 900s 2D
Default standard transmission fluid
How much fluid dose my 96 saab 900s 5 speed transmission take. also what is best to use.
Old 17th April 2011
'97 Saab SE Turbo's Avatar
'97 Saab SE Turbo '97 Saab SE Turbo is offline
Saabista
My Saabs: Black on black '97 Saab 3-door SE Turbo
Hopefully, you are asking about manual transmission. If you are, the Owners Manual recommends 2L (or roughly 2 quarts) of 10W30 motor oil. I use Quaker State, but I change it every year. You will be very surprised at how many filings are attached to the drain plug magnet the first time you drain the oil. BTW, make sure that you can get the fill plug out before you remove the drain plug... Ron
Old 17th April 2011
adamhalliwill adamhalliwill is offline
My Saabs: 2000 Saab 9-3 SE Turbo
I thought transmissions required dedicated transmission fluid. Can you really use motor oil?
Old 17th April 2011
Tweek's Turbos Tweek's Turbos is offline
My Saabs: 07 9-5 Combi, 99 9-3 Viggen, 85 900 SPG
If you wanna spend some money.
Read up on this
http://www.genuinesaab.com/psi/files/trans-oil-9000.pdf
and this:
http://www.genuinesaab.com/psi/files/93-95man-oil.htm
If you want, use the 0063 oil but use the procedure in the first link to change over to it properly.
Old 17th April 2011
Not in your car, you will have "Saab Synthetic Man Trany Fluid".
Old 17th April 2011
Saabista
Again, please specify if you are asking about an manual or auto transmission. If you are asking about a manual transmission, I will scan the page from my 1997 Owners Manual. Some switch to synthetic oil, but remember that synchronizers require some friction to shift properly and some synthetic oil reduces the friction too much... Ron
Old 17th April 2011
Jeremy R.'s Avatar
Jeremy R. Jeremy R. is offline
My Saabs: '97 900SE Talladega, 2000 9-5 Aero Wagon
That's true for Adam. The original poster's car came with motor oil in the transmission from the factory, though. I'm waiting for Saab to come up with yet another oil for our transmissions. We've had motor oil and two different synthetics so far!
Old 17th April 2011
Saabista
Sorry, didn't see the title. I'll send a scan in a few... Ron
Old 17th April 2011
Saabista
Here you go. Note the comment about not using synthetic oil... Ron
Old 17th April 2011
sideshowbob9's Avatar
sideshowbob9 sideshowbob9 is offline
My Saabs: 1998 900s Convertible
If I wanted to change the MTF in my 98 900, and didn't want to go to the expense of using the MTF0063, would either Red Line or Royal purple be a good substitute? Can I change directly to them without doing the fill, drain, refill procedure?
Tom
Old 18th April 2011
Jeremy R.'s Avatar
Redline MTL works great. I know it's a direct replacement for the synthetic that came before MTF0063. I'm not sure if any flush/fill procedures are required if you're replacing motor oil with MTL, though.
Old 18th April 2011
Saabista
Here's something from Townsend Imports concerning the type of fluid to use in Saab manual transmissions... Ron
http://townsendimports.com/Web/trans...earboxlube.htm
Old 18th April 2011
Thanks for the info Jeremy and Ron.
Tom
Old 19th April 2011
mr rx-7 tt mr rx-7 tt is offline
Interesting. I know if you put synthetic gear oil in a 3 gen RX-7 Manual gearbox it will turn it into slop.
I know Honda supposedly makes a fantastic gear box oil, wonder what it is. Also what should I put into my 2000 Viggen?
1999 Turbo SE
2000 Viggen
1993 Mazda RX-7 "It ain't stock"
I live in a high test world...
Old 19th April 2011
bogan's Avatar
bogan bogan is offline
My Saabs: 97 900se Talladega stage 5....b234 RWD
Garage
Does any body know what would suit Australian conditions better or what the shifting differance would feel like between
10w 30 or 10w 40 . I'm going to change mine this weekend
and where are the plugs ? got a pic anyone
cheers
B.L.T.H.....Brake late Turn hard
Old 19th April 2011
bogan's Avatar
Garage
sorry guys,just read all the links. answered all my questions and good pics too
mineral 10w 30
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
transmission fluid?? shrugod 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 7 8th June 2012 10:07 AM
Transmission fluid Waterskier 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 4 19th May 2010 05:20 PM
Transmission fluid mike427 9-5 Workshop 2 13th November 2009 09:57 AM
Transmission Fluid OxyCoSaab NG900 & OG9-3 Workshop 1 27th June 2009 10:20 AM
Fluid for Standard Transmission Sparkymarvin C900 Workshop 2 12th November 2002 10:56 AM
