3309/Dexron III/Valvoline Maxlife???? - SaabCentral Forums
Old 14th April 2011
bornfromjets03 bornfromjets03 is offline
My Saabs: 2003 9-5 linear
Garage
Default 3309/Dexron III/Valvoline Maxlife????
I need a trans flush (or fluid change) on my 03 liner (AW55-50SN) with 85K miles.
I know Saab recommends 3309 or whatever, but I live in a small town where european imports are rare and knowledge of them is even more rare!
one shop told me Dexron III. Another shop told me 99-01 was Dexron III but 02+ is 3309, a third shop told me Valvoline Maxlife works just as well.....
HELP! (oh ps i'm WAY too broke to buy 3309 from Saab.... so there's no way i'm just biting the bullet on this one)
2003 9-5 linear sedan
Find us on Facebook!
facebook.com/groups/saabclubok/
facebook.com/groups/saabtx/
Old 14th April 2011
SaabScott's Avatar
SaabScott SaabScott is offline
My Saabs: 2006 9-7X 5.3i
You are "too broke" to maintain your car?
Well, then I hope you aren't too broke to replace the transmission!
At the absolute worst, 3309 should cost $15 per Litre/quart.
So you need 4 of them and then (unless you are doing it yourself) labour to do the work.
You can also source Toyota transmission fluid (search for more details) as it is the same and much cheaper.
And no, DexIII is not compatible ... you would be mixing the remaining 3309 and that won't be good.
Plus ... Saab switched to 3309 for a reason.
But for crying out loud, either figure out how to pay to properly maintain your car or trade it in for a bike and public transit.
It will cost you a lot more in repairs in the long run than it will to maintain it.
President,
The Saab Club of Canada
2006 9-7X 5.3i
Old 14th April 2011
Garage
yeah well i'm in college and live in a town with a failing economy.
as far as I know, to do a flush, I need 10 quarts. thats $150 without labor.
and I need to travel at least 110 miles to the nearest place that carries 3309
Old 14th April 2011
honkahonka honkahonka is offline
My Saabs: 2003 9-5 Aero manual
Default Order it
here:
http://www.eeuroparts.com/Main/PartD...px?id=93160393
Old 14th April 2011
Paul in NM's Avatar
Paul in NM Paul in NM is offline
My Saabs: 6 former Saabs
I buy mine online.
AV Lube
Old 14th April 2011
Garage
Originally Posted by Paul in NM View Post
I buy mine online.
AV Lube
wow! that's cheap too!
Thanks!!
Old 14th April 2011
SaabScott's Avatar
You would need that only if you were planning on doing multiple drains.
Normally, a tranny service is draining the fluid and replacing ... that is only 4 quarts.
To do more than that would either require a pressure system or simply doing the drain and fill method multiple times.
And I wasn't knocking you with your comments about money ...
But, anyone who buys/owns a car needs to be prepared to maintain it.
Otherwise it will fall apart around you and be unsafe for you to drive (not to mention those around you or those in your car).
One thing you can do is learn how to do this sort of thing yourself.
Draining the transmission fluid is about as easy a job as you can get on a car.
President,
2006 9-7X 5.3i
Old 14th April 2011
Garage
Yeah, no offense taken.. like I said though, i'm in college. Anytime I can penny pinch I will! (like buying that 3309 online.)
you also bring up another good point which I would like to discuss...
flush vs. drain(2-3 times) anybody have a preference?!?!?!
and yeah I can do it myself, but I don't have the time until early June...
Old 14th April 2011
Paul in NM's Avatar
Well "flushing" on the 9-5 means drain, refill, drive, repeat. And I did it 3 times initially and then about once every other oil change.
Old 14th April 2011
whiteblur whiteblur is offline
My Saabs: 03 9-5 Linear
Getting ready to change out the ATF in my car this weekend and was wondering if I can do it all in one day. I have 12 quarts and know that you have drain ~4 quarts and repeat the process. Can I just drain and fill without driving the car?? Just start and cycle the trans through the gears enough?
Old 14th April 2011
saabfire's Avatar
saabfire saabfire is offline
My Saabs: 99' 9-5 SE
So would it be alright to use 3309 in a 99' 9-5se even though the owners manual calls for DexIII?
Old 14th April 2011
Paul in NM's Avatar
NO. 4 spd auto trans = DexIII. 5sp auto = 3309.
Old 14th April 2011
Paul in NM's Avatar
Meh. Not as good as driving it around for a bit to get the oil cycling through the system.
Old 14th April 2011
first-saab first-saab is offline
My Saabs: '99 9-5 V6, 200k+mls, '08 9-3 Aero Vert
Toyota type IV may be your best bet, 4 Qrts should be around $ 20.
I switched from Mobil 3309 to type IV, same thing.
Old 14th April 2011
Apocaliptic Apocaliptic is offline
My Saabs: 2003 Saab 9-5 Arc V6 3.0t
Thanks!!
And you need a pack of 12 quarters for a full flush. 3 times and 4 quarters every time. You can do it yourself, it is very easy, easier than the oil change because you don't need a filter.
Tags
transmission, transmission fluid
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Valvoline SynPower 5w-30 Q's cavedudejeff 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 8 13th March 2011 05:19 PM
Dexron VI? SaabBlackMan 9-5 Workshop 10 12th October 2009 09:00 AM
Valvoline MaxLife Synthetic in '01 Aero (new to forum) cbfan 9-5 Workshop 3 14th September 2009 05:32 PM
Valvoline.com has a wierd car on it.. mikeucr The Lounge 9 19th October 2008 09:54 AM
Dexron III autobox justyjust 9-5 Workshop 1 21st April 2008 05:34 PM
