Help installing Pioneer AVIC - SaabCentral Forums
Old 10-04-11
Danv's Avatar
Danv Danv is offline
My Saabs: 1999 9³ 2.0L Turbo
Lightbulb Help installing Pioneer AVIC
Hey guys,
Here is my situation, I have a 1999 Saab 9-3 Base. I am still stock on audio.
I got myself a used Pioneer AVIC-F700BT.
It came with everything and today I received the Metra 70-1784 harness.
I took reference from this post for the wiring.
I followed what he said except that I actually wired red (acc power) to red I didn't want to mess with the headlight plugs.
So yeah I tried to plug it in and it's working !
One thing though, the volume is so low. I maxed the volume as it's still low; speakers are working well on stock radio...
Front and rear are working... Doors is not, it's normal I guess.
What am I missing ? An amp perhaps? Lol
Also after, which dash kit would I need? The pioneer one? The Metra? Which one will perfectly fit a og9-3 ?
Thanks
Old 10-04-11
Danv's Avatar
I just figured out something. There is actually no amp powering the speakers... This is my first install sorry!
But.. on the power harness, there's some output which the HU's internal amp will power... I have to do the harness all over again.. LOL
Old 11-04-11
markyboy75's Avatar
markyboy75 markyboy75 is offline
My Saabs: 1999 9-3 turbo s stg 2
My front speakers aren't working in my 99 either. But I'm running a cheap jvc HU along with a 400w fusion sub and amp. It still chucks out some bass mind you. I'm not that worried about the door speakers as it still sounds pretty clear.
Old 11-04-11
Danv's Avatar
I'll still try to wire them. Sucks to know they are there but not using them. Feels like 'wasting' them
Here's my plan... Front and Rear into the HU via the internal amp. Doors into 'Rear' preamp and I have an mono-channel amp for the sub which will be into preamp output labeled 'Subwoofer'
Old 11-04-11
markyboy75's Avatar
That's cool may give it a try myself but just use the amp I have already.
Old 11-04-11
Danv's Avatar
If I ever find my factory amp* (the one which is powering the doors speakers), I have to make a custom wire for that amp to the preamp of the HU.
Something like that
http://www.ericsaabsite.com/Audio/Preamp.html
*This is so dumb.. I can't find it behind the kickpanel
Old 11-04-11
markyboy75's Avatar
You may find there is no factory amp mate. Not all models have them as it depends on the car spec.
Old 11-04-11
Danv's Avatar
So that may lead to the other option... the doors's speakers are wired in the main harness too.. but I can't find any diagram of the main harness
Old 11-04-11
Danv's Avatar
This is really wierd... how are they wire ?
I found this... but there's nothing else than
Rear Right Pos
Rear Right Neg
Front Right Pos
Front Right Neg
Rear Left Pos
Rear Left Neg
Front Left Pos
Front Left Neg
on the B-connector.
ref.: http://www.genuinesaab.com/psi/files...adioWiring.pdf
Old 12-04-11
markyboy75's Avatar
Looks as if the dash and door speakers could be running from the same source then. I know that when I had the standard stereo in all the speakers worked. As well as the radio controls on the steering wheel.
Old 12-04-11
Imspace2's Avatar
Imspace2 Imspace2 is online now
My Saabs: 2011 9-5 Turbo4 Premium / 2008 9-3 AERO
Thumbs up
Hey guys talk to "asaturn" on here he makes the pre-amp cables. Can't wait to get mine, all the stereo shops in town tell me that I need to rewire my entire car to install a stereo such BS. Our cars have just about the same wiring as a Saturn L series sedan and wagon. Most shops hear SAAB and they just see dollar signs.
Something like that
Old 13-04-11
markyboy75's Avatar
Thanks m8 I'll have a word.
Old 13-04-11
Danv's Avatar
Alright, fine I have no factory amp. LOL
Though, my guess is my doors speakers must be wire with the front speakers.
(They are working now with the appropriate amp lol)
I redid the harness and it looks like this.
My mistake was wire the speakers into the preamp (the dark grey wires) those must be lead to an amp.
So instead of undoing my wire .. I wired some female RCA to plug my Metra harness in. In that case, if ever I go with an aftermarket amp, I'll be ready
All I need now is to fit the HU into the 9-3 dash.. any recommandation on the fit kit ?
Old 13-04-11
SleeperSaab's Avatar
SleeperSaab SleeperSaab is offline
My Saabs: 1999 9-3 : Sleeper Project
Hey, I don't know if this is a stupid thing to ask, but you know you said that your amp wasn't working and found there wasn't one... you also said that your door speakers aren't working... do you HAVE door speakers?
As far as wiring outside of the Headunit, check out how I did things...
http://www.saabcentral.com/forums/sh...d.php?t=199063
Old 13-04-11
Danv's Avatar
Hahaha yes I do! They are working now.. I guess they are not powered by any amp... They must be wired from the front speakers.
Old 16-04-11
nevi325 nevi325 is offline
My Saabs: 01 9-3
my door speakers do not work. and i have a stock radio? i have been trying to figure this out. there are speakers there
Old 17-04-11
markyboy75's Avatar
Think you will find the door speakers are wired to the dash speakers and should be working if you stock stereo is running 6 channels. Most after market stereo's only run 4 channels and will state this, as in 4 x 50 watts. As most peeps say on here you may need to think about a separate amp or re doing your wiring harness. Check pics above for diagrams m8.
Old 17-04-11
My Saabs: 01 9-3
Are you suggesting redoing the wiring with the stock stereo? i dont want to upgrade i just want the speakers to work, ill have to check into it. thanks
Old 18-04-11
markyboy75's Avatar
Not really, just make sure the door speakers are in working order as they have a fault.
Old 23-04-11
Danv's Avatar
It's on!
Though, I'll have to install it again when I'll have a proper fit kit
Similar Threads
Pioneer AVIC-F700BT Wulf Saab 9-5 Workshop 401 3 Weeks Ago 12:20 AM
Another Pioneer AVIC 'fread. meltdowndave Saab 9-3 & NG900 Workshop 3 27-05-09 10:06 AM
Pioneer AVIC-D3 will it fit?? depth wise that is Carter Saab 9-3 & NG900 Workshop 2 03-01-08 07:34 AM
Pioneer Avic-N1 Stratixman Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop 4 26-07-05 08:15 PM
Pioneer AVIC-N2 DT_saab Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop 1 18-05-05 08:42 PM
