Bad Slave - SaabCentral Forums
Old 07-04-11
SOAB's Avatar
SOAB SOAB is offline
My Saabs: 1990 900s and 1995 9000 Aero
Default Bad Slave
Hey guys I have got some advice but I am kinda confused and Ifigured Id give a little more info here. My 1990 C900 is havin clutch/brake issues, and I don't know if they are inter related.
The brake pedal is stiff as hell.. takes a ton of strength to push it and the car does not stop well at all. Anti Lock light is on. Swapped newer front pads and helped a LITTLE, but not really.
Slave is not fully compressing the pressure plate fingers, or releasing fully from the pressure plate fingers. Could these issues stem from the system needing to be bleed? I pulled the slave out and it seems fine. Never leaked.. What should I check with the slave out?
Any advice would be geately appreciated!
Thanks!
Alex
www.freebord.com/ride <-- Snowboard the Streets!
"Maturity is too high a price to pay for growing up."
Old 07-04-11
B202NUT's Avatar
B202NUT B202NUT is offline
My Saabs: 1992 900S // 1991 Turbo Vert SE
Thanks!
Alex
I am sure you asked the same question last week; no??? (maybe it wasn't you)
the brake fluid if it hasn't been completely changed within the past year, drain, flush, fill, and bleed the system; it may help.
the clutch read here on going thread: http://www.saabcentral.com/forums/sh...d.php?t=207718
"Everyday Above Ground, Is A Good Day"
Old 07-04-11
SOAB's Avatar
Yeah it was me, figured I'd give more detail.. Im ready to give up on it at this point.. whether th slave is good or not the clutch is now bad.. my method of compressing the pressure plate fingers with a screwdriver (which has never done damage before took a chunk outta the clutch.. I don't have 300.. I barely have the money for the ticket I got for expired inspection I got and the inspection Im getting tomorrow for my 9k.. my girl frined got a ticket driving it today too.. they are pulling everyone over for anything cause Obamas in town.. im just ****ing done..
Old 07-04-11
anjum anjum is offline
My Saabs: Saab c900 vert 1992, Jaguar XJS 1992 4L
Re the brakes, sounds like the brake pump is not working for some reason. When I first put my car together, I had exactly the same symptoms. Luckily turned out I hadn't pushed a connector at the side ot the pump under the resevoir fully home. Other things to check are the ABS/brake fuses.
Old 07-04-11
B202NUT's Avatar
Loss the tude my friend; the car has no feelings and wont be bothered either way. Its yourself you hurt. its mechanical, your options are clear, fix it or forget it.
Quite simple really..
Go back and re-read all the post to your initial question. Search the forum for posts with good results to your issue; determine what your gunna do and get to it! the answers you get now wont change from what you got before...
In the words of the Cable Guy; "Get Er Done"!
Check the ABS Module under the back seat.. Your Anti Lock is on could mean the entire Module is toast; they sell for about $100 used... If the light is on, you can pull the code and find out the issue
Old 07-04-11
SOAB's Avatar
Yeah thanks dude.. sorry 'bout that. Please excuse that rant, I snapped. I know it didn't help. I hope you know none of that was directed at you!
Sorry guys!
Ill quit the *****in!
Similar Threads
Slave Cylinder Saab6 Classic Saab 900 Workshop 24 13-04-07 10:48 AM
more slave cyl help please jbvw96 Classic Saab 900 Workshop 4 22-08-04 06:25 PM
slave cyl. help !?!?! jbvw96 Classic Saab 900 Workshop 5 21-08-04 11:26 AM
Clutch Slave??? the big jc Saab 99 & 90 Workshop 5 24-07-04 04:22 PM
Clutch slave SPG85 Classic Saab 900 Workshop 10 22-07-04 06:52 PM
