Parking light out in the headlight with HID - SaabCentral Forums
Old 6th April 2011
denisk denisk is offline
My Saabs: '05 9-3 Aero vert 5 sp m. LR Disco 2
Default Parking light out in the headlight with HID
Please pardon my ignorance, and I know some people actually prefer to have the little bulbs off, but I am kind of new to this car and want/like the stock look. So, I took the battery cover off, took the air tube out, took the neck of the windshield tank out, took the fuse box out of the way by way of sliding it up and to the side. Took the boot off, took the bright light bulb out. Tried pulling the wires for the lil' sucka called dead parking light. No such luck: its stuck.
MY Question: Do i really have to take the entire headlight assy out to be able to replace a stupid parking light bulb???
C'mon SAAB, you can do so much better than this crap! How much of the car do I have to disassemble to replace a burnt lightbulb? Whoever decided upon such a "design" has to be beaten with a huge huge wooden stick! The time it took me to do all this and to fail would have been sufficient to take the entire front end of my 99' 9-3 completely apart and then put it back together again. Sad, and i used to think my Discovery Series II took the cake in terms of positioning important components in impossible to reach spaces, I was wrong.
Old 6th April 2011
borderwave2 borderwave2 is offline
My Saabs: 1992 900 S
Like the headlight bulbs, I think you have to rotate the city light bulb before removing it. I believe this is the case, however, I'm not entirely. sure.
Saab is not only a car.. but a state of mind.
Old 6th April 2011
Gs04aero's Avatar
Gs04aero Gs04aero is offline
My Saabs: 2004 VTuned Aero
We're talking about the small driving lights right? Pull. It will feel like you're going to pull the wires out of the socket really. The drivers side sucks to get to but you can just barely get a hand in there to pull on the wires. If you cant, just pull the front bumper and remove the headlight. I find that easier than removing everything you removed. Takes me less than 1 minute to remove my front bumper now.
Old 6th April 2011
HuNtS's Avatar
HuNtS HuNtS is offline
My Saabs: Steel Grey '03 ARC 6MT
Garage
like mentioned, just PULL HARD on the wires. if you're able to at all give it a little wiggle and it should pop no problem. yes it's stupid, but once you do it, you shouldnt have a problem doing it time and time again.
Old 6th April 2011
fuserest's Avatar
fuserest fuserest is offline
My Saabs: 2007 60th Anniversary 9³
Yeah, make sure you're pulling the right wire, and yank it out. There's actually kind of a rubber brace of sorts on the wires where you can grab.
Old 6th April 2011
Thank you all! I will def. try that again (bummer with removing all 133 things again). I felt that extra rubber layer on the wires close to the socket, but my meathook hands are not suitable for such a small space. I finally gave up as pulling the wires with such a force just felt like vandalism to me: I just thought to myself, why am I hurting my new car? So I gave up.
Why did they NOT make the round opening, say, square, and larger, larger? Because a larger rubber boot would cost more fractions of a cent to GM? Whoever is the ******* that OK'd this design, I want to drag him out of his office, preferably in freezing cold, rain, snow and sleet, and dark, and watch him do the burnt bulb (5w) replacement procedure, time and time again. b-a-s-t-a-r-d!
Old 7th April 2011
limmerbr's Avatar
limmerbr limmerbr is offline
My Saabs: 2006 Saab 9-3 SS Aero V6T Maptun Stage 1
yeah i had this problem too and I just gave up.
2006 Saab 9-3 Aero Maptun Stage 1
Best car I have ever owned!
Old 7th April 2011
tomk17 tomk17 is offline
My Saabs: 2003 9-3 Linear 2.0t
I think I saw a You Tube video showing the bulb removal with some needle-nose vise grips. With those you apparently reach in a grab it or at least the wires very close to the bulb base.
Old 7th April 2011
JonV JonV is offline
Saabista
My Saabs: 03 SE 5 Spd
http://www.mrandmrs-g.net/LightingGuide/e-city.htm
Old 7th April 2011
limmerbr's Avatar
I notice on the older cars such as in the you tube video that the lighthing fixture configuration is slightly different than newer models and easier to access.
some older models even have this parking light in a separate housing but not on new models like my 06.
The newer models make it a real pain to change.
Maybe one day when its not raining here in NY I'll attempt again, this time with needle nose and I'll try this time to turn it out.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Tech 2 tool at my house right now, help with headlight/ parking light please Wrightsfd 9-5 Workshop 6 29th May 2010 10:40 PM
Diagram of headlight parts - parking light etc. Darmok NG900 & OG9-3 Workshop 7 12th January 2010 07:52 AM
Front left parking light bulb (Bi-Xenon headlight) SAAB 9-3 AE-RO 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 4 16th February 2009 10:43 PM
Parking Light Saaboy NG900 & OG9-3 Workshop 18 20th March 2007 10:00 AM
Parking lights and headlight switch adamsonem NG900 & OG9-3 Performance, Mods & Tuning 6 18th September 2005 03:19 PM
