Temp Gauge Question - SaabCentral Forums
Old 06-04-11
narlinghaus narlinghaus is offline
My Saabs: 2000 Saab 9-5 4cy 5sp
Default Temp Gauge Question
Just bought this Saab from my brother who let it sit for awhile with a broken fuel pump. Fixed the fuel pump and the car runs great.
Drove it for about an hour yesterday and for 20 minutes this morning and the temp gauge never got above 9:00. The fill fluid coolant message came up this morning and eventually the CEL came on. When I stopped at a gas station the engine compartment was smoking. Popped the hood and there were evident signs of fluid that had spewed, but no drips under the car. I opened the fluid reservoir slowly to let out the pressure and once I removed the lid, fluid filled back into the reservoir and at an acceptable level.
Finished the drive to work and when I stopped the car no signs of smoke came from the hood. The fluid messaged did not come on the last leg of the trip either.
I have not had a chance to get the CEL scanned but will do that tonight. I did notice a little bit of fresh liquid/fluid of some kind on the front right side of the engine where the exhaust turns toward the rear of the car.
Any thoughts or ideas? I have searched quite a bit on here so far but nothing jumped out at me. Is it possible that the temp gauge is reading wrong and the engine was running hot?
Any help is appreciated.
Old 06-04-11
Jssaab Jssaab is offline
My Saabs: 2000 9-5 320hp, 2003 Aero Hirsch "Clone"
Retorque the head, early models had bad headbots and were not torue properly at the factory...
get the codes read...
and welcome to saabcentral
Old 06-04-11
justinsaab's Avatar
justinsaab justinsaab is offline
My Saabs: 2001 Saab 9-5 2.3T
Yes I would say that it's possible that the temp sensor is reading wrong and its overheating without the gauge saying so. After you see what the code is of course, I would start looking for leaks in the cooling system. Use a pressure tester if you have one or can borrow one to pressurize the cooling system and look for leaks.
Old 06-04-11
Saaber95er's Avatar
Saaber95er Saaber95er is offline
My Saabs: 1999 9-5 SE 5spd
Garage
Check the heater valve for any leaks; the valve could be bad and leaking antifreeze onto the exhaust. I would also change the thermostat since the car was sitting for awhile. Can you see where the antifreeze is leaking from?
Old 06-04-11
Can't tell for sure where it is leaking from but it is definitely towards the front right of the engine. There is a little bit dripping off the bottom of the engine near where the Front Cover would be on the engine...
I'll try tightening the Head Bolts tonight. I probably will end up replacing the t-stat as well.
Old 07-04-11
So I tightened the Head Bolts last night...bolt number 10 according to the directions was so loose I could turn it by hand...hopefully that solved the problem. The car seemed to be fine this morning on the drive in so we will see. I think I am going to replace the t-stat anyway in the next few days.
Thanks for the help.
Old 08-04-11
Pabllh Pabllh is offline
My Saabs: '02 9-5 2.3t wagon - '00 9-3 Base
While you're there change the temp sensor also.
Similar Threads
CHECK RADIATOR Light flashes on, then temp gauge and fuel gauge drop all the way down 389is Saab 9000 Workshop 13 11-04-12 07:13 PM
Engine coolant temp sensor and temp gauge drglock Classic Saab 900 Workshop 4 11-11-10 01:06 PM
temp gauge question~ kitechan Saab 9-5 Workshop 12 09-03-08 06:12 PM
Quick 9-3 temp gauge question largo77 Saab 9-3 & NG900 Workshop 5 20-01-06 05:31 AM
Wiring Oil Temp Gauge & query turbo gauge Adriano Classic Saab 900 Performance, Mods & Tuning 4 25-03-04 05:30 PM
