Water pump replacement - doable? - SaabCentral Forums
Old 3rd April 2011
motogman motogman is offline
My Saabs: 2001 9-3 SE
Default Water pump replacement - doable?
My leakeage problem may be a water pump - 2001 9-3 eco-boost.
I have read through some threads on replacing water pumps and some way it is very hard, others that is is doable by the weekend mechanic. I think this variation must be for different engine designs.
What is the concensus for the 2001 2.ot eco-boost. Is the water pump replacement a hard job? How long? What are the biggest issues?
Old 3rd April 2011
watkins's Avatar
watkins watkins is offline
My Saabs: '99 Viggen
Did it in a few hours at a leisurely pace on my Viggen.
Old 3rd April 2011
N.E. Swede N.E. Swede is offline
My Saabs: 4 c900, 97 9k Aero, 02 9-5 aero
http://www.saabcentral.com/forums/sh...d.php?t=206826 See this post, it's for a 9-5 so disregard the part about the engine mount. Also on a 9-3 you may want to loosen the 3 bolts on the a/c compressor and slide it forward to get better access to the water feed line for the turbo
Old 3rd April 2011
watkins's Avatar
The turbo water line was the biggest problem for me.
Old 3rd April 2011
Chaccof in VA Chaccof in VA is offline
My Saabs: 2001 9-3 SE 94,000 miles
I agree that the turbo water line was the most difficult part of the job. There are two banjo bolts - one on the WP itself and one on or near the turbo - it's a little line that snakes down and the goes right below the car as looking from the front. I ended up loosening it at the turbo and that made it much easier to remove at the WP and then subsequently replace on the WP.
Old 4th April 2011
spikeieos's Avatar
spikeieos spikeieos is offline
My Saabs: Viggen, SPG, 9-5
The trick with the water line to the turbo is using the right tool. Basically what you need from snap-on is a 12 point swivel head socket to get the correct angle so you can turn the bolt. Otherwise you will do lots of cursing trying to get that one bolt off. It's worth the wait to get the right tool.
Old 4th April 2011
Is there a way to know for sure the leak I have is the pump? Pressure test?
Symptoms again: Looses fluid sometimes. No steam. Often no trace on ground but when there is it is in the right location for the WP. Fliud often disappears after being parked.
Old 6th April 2011
redrum's Avatar
redrum redrum is offline
My Saabs: 1997 900SE 2.0t
Make sure to check the condition of all your coolant hoses. For that leak location the lower radiator hose, and the small hose that goes from the throttle body to the back of the head, on the waterpump side. This one was leaking on my car and I was originally convinced it was the waterpump..
signature here.
Old 6th April 2011
dfera dfera is offline
My Saabs: 2000 9-3 SE HOT
What does your oil look like?
Thanks
Dom
Old 6th April 2011
Oil is fine - no signs of fluid. This has been going on since I got the car (about 4000 miles) and I just changed the oil. All good there.
Also no sign of oil in the fluid... however, I am adding a gallon or so over the course of about 2 weeks, small quantities at a time of course.
The fluid loss is erradic. I will sometimes go 3-4 days with no loss and sometimes I will fill the overflow tank once or twice a day. Only 3 times have I had a spot under the car but when I did it was dripping from the undercar plastic shield in the right front corner. I dropped the shields but could not detect a precise location for the leak (it also started to sleet on me which dampened my enthusiaum to probe deeper at the time).
Any other ideas... I am still trying to nail the cause before I fix something that ain't broke...
Old 14th November 2015
ologist's Avatar
ologist ologist is offline
My Saabs: 2002 9 SE & 2005 9 Linear
What size is this bolt?
ScottSaab66's Avatar
ScottSaab66 ScottSaab66 is offline
My Saabs: 2003 9-3 Cabrio
If the water is backing up and overflowing the tank,there's a distinct possibility that a head gasket may be the culprit. Especially if it's an erratic loss prob. Have a system pressure test performed,some auto parts houses load a gauge-pump for this.
Old 15th November 2015
kghaddon kghaddon is offline
My Saabs: Saab 9-3 convertible
Ditto on the bolt size, I don't mind ordering the right tool. It's just nice to know which one I need before I tear the car apart.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
water pump replacement cseturbo 9000 Workshop 7 3rd October 2010 11:17 AM
Help with Water Pump replacement JOE01952 9-5 Workshop 12 10th August 2010 09:36 AM
water pump replacement SuperFlyGuy NG900 & OG9-3 Workshop 4 15th October 2009 08:18 AM
Water pump replacement Somberlain C900 Workshop 14 13th February 2006 12:39 PM
Water pump replacement Herbert 9000 Workshop 0 5th March 2003 10:35 PM
