9-5 does not idle well....what's the problem? - SaabCentral Forums
Old 31st March 2011
mrpoopypants mrpoopypants is offline
New Member
My Saabs: 2003 Saab 9-5
Default 9-5 does not idle well....what's the problem?
Hi, I recently purchased a 2003 Saab 9-5 4cyl 2.3T. I took it to my local Saab dealer to get an oil change the other day. It had been having trouble idling at stop lights. It kind or "putters" and sometimes seems like it is going to "conk out" although it hasn't yet. The Saab dealer gave me a long list of things that need to be done to maintain the car and I was wondering if anyone nows what on this list may be causing the idle problem. Here's the list:
-REPLACE UPPER REAR IDLER PULLEY
-PERFORM PCV UPDATE
-REPLACE SERPENTINE BELT
-PERFORM AUTOMATIC TRANSMISSION FLUSH
-REPLACE AIR FILTER ELEMENT
-TOP ENGINE CLEAN
-REPLACE LOWER FRONT TORSION MOUNT
-REPLACE LOWER RIGHT ENGINE COVER
Any ideas which one of these things could fix the idle problem..
Thanks.
Old 31st March 2011
Saaber95er's Avatar
Saaber95er Saaber95er is offline
My Saabs: 1999 9-5 SE 5spd
Garage
Check and replace all vacuum lines and Check the lines to the TB. WELCOME TO THE FORUM!!!!
Old 31st March 2011
New Member
Thanks for the quick reply and the welcome. Do you know if this is a costly job at a shop? Can I do it myself? I am not very car savvy. Sorry for the dumb questions but what are the vacuum lines and the TB?
Also not sure if it matters but the problem doesn't occur when in park. Just in drive stopped.
Thanks.
Old 31st March 2011
Mike Brennan's Avatar
Mike Brennan Mike Brennan is offline
My Saabs: (4) 2 01 95's; an 08 95 & a 09 93
pull your oil pan and forget the top clean. Oil pan is the most important thing you can do. Wont help your idle but neither will an oil starved motor. Read the forum on sludge tonight. And then read all of these. http://www.saabpros.com/saab/nines/ Pay particular attention to replacing your oil pump and housing. Not hard and not all that expensive. Run a can of sea foam thru your gas tank first before you start replacing a bunch of stuff. PVC update is also a must in conjunction with oil pan and pump.
Old 1st April 2011
justinsaab's Avatar
justinsaab justinsaab is offline
My Saabs: 2001 Saab 9-5 2.3T
From what i've seen, if an engine is having trouble idling already it will have an even harder time once you put it in drive sitting still because of the added load put on it, so id say that just a consequence of whatever is causing the idle problem. Problems with the vacuum system on an engine will show themselves at idle when the throttle plate is closed and virtually disappear off idle. I would start looking for any vacuum leak, check the air filter, spark plugs, fuel pressure, etc. Is the Check Engine Light on?The items that the shop said needed replaced probably do, but im not sure that's your immediate problem. Although I would get all of them addressed as soon as possible.
LOOOVE that username by the way
Old 1st April 2011
justinsaab's Avatar
TB= Throttle body. Its the housing that contains the throttle plate and probably some sensors and hoses connected to it. Bolts onto the intake manifold or plenum.
Old 1st April 2011
Saaber95er's Avatar
Garage
Not hard to do at all; get about 8' of 5/32 tubing from autozone and replace the lines; the attached picture should help (hoses in the upper right) just replace all the hoses of the same size. When you get it idling properly then you can address the items on your list as well as getting the sump (oil pan) dropped and cleaned out. GOOD LUCK!!
Thanks.
Tags
9-5, idle problem, idler pulley, pcv update
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
idle problem on 2l lpt white.akita 9-5 Workshop 5 23rd February 2010 01:49 PM
Idle Problem! ALVIN 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 4 5th September 2008 12:37 PM
Stumbling problem, idle problem 89 900S qgardiner C900 Workshop 2 15th March 2005 03:11 AM
Can't seem to fix this Idle Problem ajgardner01 9000 Workshop 4 17th December 2003 06:53 PM
idle problem blobby12uk C900 Workshop 5 11th November 2001 01:57 PM
