DIY How to clean your Mass Air Flow (MAF) sensor - SaabCentral Forums
Old 29th March 2011
gso_saab gso_saab is offline
My Saabs: 2007 Saab 9-3 Anniversary Edition
Default DIY How to clean your Mass Air Flow (MAF) sensor
Cleaning the MAF sensor has come up a few times on the forum recently, so I thought I'd post a DIY How To on it. This is an easy job, but like all easy jobs, someone can botch it badly, and a new MAF sensor ain't cheap.
MAF sensors get dirty from the flow of dust, dirt, pollen, and such that slips past the air filter. They really get dirty when people put too much oil on a K&N type filter. The oily sensor then builds up globs of crap. A dirty sensor can contribute to rough idle and lower performance, so we ought to clean them at least every 30,000 miles.
You'll need the following:
1. A T20 Torx bit or screwdriver.
2. A can of MAF sensor cleaner. CRC and Gunk make this; most parts stores have the CRC one for around $7. DO NOT USE CARB CLEANER.
http://dl.dropbox.com/u/1127582/CRC.JPG
3. A sparkly pink princess wand for dramatic pointing (optional). Those of you with car seats in the back of your Saab probably have one or two of these laying around.
Your MAF sensor is on the intake tube, as indicated by the sparkly wand.
http://dl.dropbox.com/u/1127582/MAF_Spot.JPG
To remove it, unscrew the two T20 screws. The hardest part is probably removing the clip; here's a close up:
http://dl.dropbox.com/u/1127582/Clip1.JPG
Push in the small tabs and slide the clip out toward the firewall so it looks like this:
http://dl.dropbox.com/u/1127582/Clip2.JPG
Then pull down on the wiring to remove it from the MAF sensor. Pull the MAF sensor straight out. It's a tight fit.
The MAF sensor looks like this:
http://dl.dropbox.com/u/1127582/MAF.JPG
Carefully place it on a dropcloth or old towel away from the engine and the car's painted surfaces. Spray it 5 to 10 times with the MAF sensor cleaner and let it dry via evaporation.
Never use carb cleaner, brake cleaner, degreaser, rubbing alcohol, generic cleaners, or anything else. Don't touch the delicate wires inside the sensor with anything other than the spray. Yes, there are a lot of videos of young guys cleaning their riced-out Integra's MAF sensor with carb cleaner or with a q-tip, but somehow those guys forget to upload the video of them sheepishly ordering a new sensor for $150 a week later.
The MAF cleaner will evaporate in a few minutes, but be sure it's dry before you put it back in. Don't get the cleaner on your skin.
If you like, you can lightly recondition the sensor's o-ring before reinserting it.
Some people recommend doing this every time you clean your air filter. People with aftermarket oily filters ought to do it pretty often.
And that's it. Let me know how this works for y'all.
Old 30th March 2011
chris_de_ze's Avatar
chris_de_ze chris_de_ze is offline
My Saabs: '03 9-3SS Aero, I4, MT6, Maptun Stage 1
Nice and clear write up!
Very good!
Old 30th March 2011
Vector-SS's Avatar
Vector-SS Vector-SS is offline
My Saabs: 2006 9-3 Aero Vtuner Stage 0 Rev 2.0
Garage
Nice writeup. Now, can you attest to the "proven to gain 4-10hp at the wheels"?
Old 30th March 2011
Yeah, I'm pretty skeptical of CRC's HP claim . If you keep your air filter fresh and clean, the MAF sensor will never get too dirty.
People with oiled filters and people who neglect their cars will probably see a big gain from a MAF sensor cleaning.
In way, the state of the MAF sensor is a clue to how well your air filter works. My sensor looked factory clean at 33,000 miles, which is a good sign.
Old 31st March 2011
Cafasco Cafasco is offline
My Saabs: 2008 9-3 SS 2.0T
Great write up! This should be a STICKY!
Old 31st March 2011
Titansaab27's Avatar
Titansaab27 Titansaab27 is offline
My Saabs: 9-3 Aero Vtune stage 0 rev 2
anyone know how to do this for the V6 9-3s?
2007 Saab 9-3 Aero ---> Mods: Vtune Stage 0 rev. 2.01, custom short ram intake, GS 3pt subframe brace, Maptun Strut bar.
Old 31st March 2011
limmerbr's Avatar
limmerbr limmerbr is offline
My Saabs: 2006 Saab 9-3 SS Aero V6T Maptun Stage 1
I second that with the v6 cleaning.
I know where the MAF is but don't want to screw anything up cause this stuff can get sensitive.
2006 Saab 9-3 Aero Maptun Stage 1
Best car I have ever owned!
Old 31st March 2011
boxman boxman is offline
My Saabs: -
Interesting,
I have been cleaning Air Mass Meters for years with brake cleaner
so would be interested as to why you cant use it now, admittedly old style Air Mass Meters used a hot wire not bead thermistors like our 9-3 uses
and as requested I will sticky this
Old 31st March 2011
I'm glad you guys find this helpful.
For the V6, the MAF will also be between the air filter and throttle body. I don't have a picture handy, but it should be easy to access. Cleaning it is the same: just remove it, spray it, let it dry, and reinsert it.
From what I gather, the newer MAF sensors are much more delicate than the old ones. Some other cleaners are probably okay for the metal and electronic parts but bad for the plastics that house them.
Old 31st March 2011
Actually it's between the air filter and the turbo unit.
Same setup in the 2-litre engine as well.
The output of the IC is connected to the intake manifold (and throttle body).
Old 31st March 2011
My bad.
Old 31st March 2011
okay not sure how to clean it, but to access the MAF on the V6, you
1. remove top of the airbox and filter,
2. undo the two torx screws that hold the intake pipe to the radiator support,
3. disconnect the crank case breather and secondary air injection hoses
4. disconnect the harness from the MAF (the MAF itself is the section of pipe that the harness is connected to
5. undo the 2 clamps that hold the MAF to the two sections of pipe before and after it
6. slide off each section of the rubber pipes (one comes from the air filter, the other goes to the turbo)
assembly is the reverse of disassembly (make sure when installing the maf back in that it flows in the correct direction)
after taking it off i'm not sure how to clean it though. there is no exposed wire or anything like the 2.0 one. its basically a honeycomb section of pipe with the sensor buried in it, and the sensor is not removable from this pipe section.
the tools required are the exact same as would be needed to remove the air filter.
Old 31st March 2011
Diggs's Avatar
Diggs Diggs is offline
My Saabs: 2003 9³SS Linear
Added to the how to post.
I'm not saying it's a coilpack.....but it's a coilpack.
Old 1st April 2011
Cleaning the V6 tube-style MAF sensor is the same basic process: remove it, douse it with the MAF cleaner spray, and let it dry completely before reinstalling it. Like the other kind, this kind shouldn't be touched or swabbed directly.
Old 2nd April 2011
Noted. Thanks
Old 2nd April 2011
xp3's Avatar
xp3 xp3 is offline
My Saabs: '03 Saab 9-3 2.0t
Pics fixed.
BTW, great writeup, definitely a sticky.
Current mods: 14t swap w/ JZW tune, GS Strut Brace, Aero front lip, 9-5 Aero turbine wheels,
(check out my for-sale-thread)
Coming soon: downpipe/exhaust, Aero body kit
My other SAAB is a car.
Old 18th June 2011
jim808 jim808 is offline
My Saabs: 2007 9-3 Aero VTuned Stage 0
Bought some MAF cleaner today and was planning to do this on the v6. Can't the MAF just be removed from the pipe by removing the torx pin head screws? Anyone know what size they are?
Old 18th June 2011
Vector-SS's Avatar
Garage
Yes, on the V6 you can unscrew and pretty much pull it out. Not sure about the size of the torx head screws.
Old 18th June 2011
EuroStyle's Avatar
EuroStyle EuroStyle is offline
My Saabs: 2006 9-3 Aero Convertible 2.8TM, Vtune 0
First Aero owner to do it, post a quick pic of the V6 one as you remove it....I am repainting the living room, so I might not be first...
Sean
2006 Saab Cars, N.A. "Top Gun"
Saab Aero Academy Alumni
Old 26th June 2011
littlebeetle's Avatar
littlebeetle littlebeetle is offline
My Saabs: Saab 9-3t Linear
thanks for this thread.
I follow exactly the instruction and got it done!
Better idling is true!!
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Where is the Mass Air Flow Sensor? pkmacfei 9-5 Workshop 6 22nd August 2016 09:18 PM
Mass Air Flow Sensor or What??? ASAAB95 9-5 Workshop 4 4th October 2009 09:25 PM
run without mass air flow sensor Leichtbau NG900 & OG9-3 Workshop 3 13th August 2007 04:49 PM
Mass Air Flow Sensor jedi_master58 9-5 Workshop 1 3rd April 2006 12:30 PM
mass air flow sensor Saab4Life NG900 & OG9-3 Performance, Mods & Tuning 0 11th May 2003 02:08 AM
