01 9-5 se v6 - SaabCentral Forums
Old 28-03-11
Mantvis Mantvis is offline
My Saabs: 01 9-5 SE
Question 01 9-5 se v6
My father has 01 Saab 9-5 SE V6
The turbo failed at 100k, so we are trying yo replace it, we took everything out, adn all there is lef to do is to take out a dipstick tube, we unscrew 1 screw that we could see, and now we are ablt to wiggle it, turn it 360. Ive googled and everyone said that it just pulls out. we pulled, we used a car jack with a cable, the cable snaped. and the tube did not move an inch!
anyone has any ideas what do we need to do?
Old 29-03-11
Kermit's Avatar
Kermit Kermit is offline
Saabista
My Saabs: Citroen C5 2.2HDi
The turbo on the V6 is integral with the manifold so you need to get the manifold off to have any chance of removing it.
1...../ 5
Old 29-03-11
gbest gbest is offline
My Saabs: 99 9-5 SE(X2), 01 9-3 Vert!
I just did a V6 turbo and could not remove the tube, I tried everything.
I ended up gently twisting and bending it out of the way so I could get to the last bolt on the manifold.
Do yourself a favor and replace the exhaust studs once the manifold is out, if they didn't break taking it apart, they will when reassembling.
2011 Infiniti G37XS, missing my Aero!
Old 29-03-11
SaabDozer SaabDozer is offline
My Saabs: 1999 9-5 SE Halfbreed
Garage
I just had my motor out a few months back and I snapped three of my manifold studs off during re-assembly. Replace the studs!
Old 29-03-11
pegasus50's Avatar
pegasus50 pegasus50 is offline
My Saabs: 1999 95 SE V6
The Dipstick tube is held by a single bolt once located and removed it can be removed. I clamped mine with vice grips and tapped firmly until it popped free. Good luck with the Turbo replacement I was able to reuse my manifold studs and they have not given me any problems after a a full year since I performed the repair. Read every thread you can. It will save you time and sanity.
Old 29-03-11
My Saabs: 01 9-5 SE
The turbo is out! I was not able to get the dipstick tube out...
It was nice to see "Garrett GT1549"
