Hesitation on Acceleration - SaabCentral Forums
Old 28th March 2011
dwoolley dwoolley is offline
My Saabs: 1990 900i 16v, 1988 900 Convert Turbo
Default Hesitation on Acceleration
I'm having some trouble with acceleration 1900 saab non Turbo, the saab will try to accelerate but at the low rev range it struggles and really hesitates. High revs are fine!
I swapped the AMM/MAF but I get the same issue, I unplugged the AMM to get limp home mode and get the same issue but worse. I tested the o2 sensors and it seems OK, getting .1V when lean and .9V when rich.
12223 is the error code.
Any suggestions?
Old 28th March 2011
Raub's Avatar
Raub Raub is offline
My Saabs: Now: '93 900s 3dr. Then: '87 900T16 (x2)
Maybe a weak fuel pump? Clogged fuel filter?
Old 28th March 2011
Vollblut Vollblut is offline
My Saabs: 1992 900i 16v
Fouled spark plugs? Bad petrol in the tank?
Old 28th March 2011
d_ames117 d_ames117 is offline
My Saabs: 92 900T Convertible, 08 9-3 2.0T
I had a similar issue that was fixed by replacing the timing chain which had stretched to its limits throwing off the timing ever so slightly (or so it appeared, but it was the only thing I changed at the time and I haven't had the problem since). The symptoms were when trying to accelerate quickly from a stop the car would bog down and refuse to accelerate. However, letting off the gas slightly would allow the car to accelerating at a lower rate. Not a good thing when pulling out into traffic.
You may try checking the timing chain tensioner extension - 11mm is the limit for an old chain according to the greater minds on this forum.
Dustin
p.s. I assume you mean 1990
Old 29th March 2011
B202NUT B202NUT is offline
Banned
My Saabs: 1992 900S // 1991 Turbo Vert SE
Dustin
Slow the Rodeo Cowboy! Chain is a bit far fetched this early.
I had the same code last week. you checked the 02 sensor; BUT, did you check up in the preheater connector for corrosion? I am willing to bet my cash the 02 sensor is just a bit dirty; PB blast it and reconnect the preheater connection,
Remember the 02 sensor sends signal to the ECU to tell it how much fuel to deliver. Hence more than likely your lean codes.Disonnect the battery when you clean the sensor,,
Old 29th March 2011
Rodentmaster's Avatar
Rodentmaster Rodentmaster is offline
My Saabs: ....................empty.
Lambda probe (O2 sensor) is there to assist in the fine tune feedback loop.
99.9% of fuel ratio calculations are derived from the AMM, NTC, engine rpms and software fuel maps. The probe sniffs the output to confirm oxygen content in exhaust to qualify the calculations.
O2 sensor does not regulate the fuel delivery amount.
O2 sensor will not stop the engine running if disconnected.
It is a feedback source.
Woah! Don't expect men to talk to your face if you patronise that
RodentMaster, post links responsibly!
ODE to the N\A
"I have not TURBINE to compress my buttocks, O lord,
Pity will be thine when thoust can crap on with boost.
We of the 'N\A - N\A' knowst nil of the pulling glory,
Yea, to post, thy blight the day of those who pressurise their pipes,
Alas, suck be mine that my chariot breathes,
Strike me down for mine is an unworthy existance"
Old 29th March 2011
Banned
it will give the ECU a faulty reading if its corroded, which can cause lean mixture codes, that I know for sure!
I dont think he said anything about the engine not starting he said hesitation which can directly be related to the 02 sensor,.
my point was I would be looking there before pulling the timing tensioner. I am not guess working here. I had the EXACT same exact codes less than a week ago and cleaning and reconecting the 02 sensor solved the lean mixture codes: http://www.saabcentral.com/forums/sh...d.php?t=206839
Read your Bentley, when you pull code 12223; it send you to code 12225
12225 - incorrect 02 sensor output. Sensor preheat circuit may be open..
Checking the 02 sensor properly is the correct process of elimination in the fault tracing process; per the code. 12223 does not IMMEDIATELY suggest AMM or NTC.
I am just reading the book my friend and following the process suggested. Worked for me, but for all intensive purposes test everything..
Old 29th March 2011
Well the hesitation is not there today, but not much driving. But I did notice the Check Engine light come on under heavy throttle, when I back off the light also goes off.
Code :12223
Im 99% the O2 sensor is fine. So i'll be checking for leaks, esp around the FI. change the plugs, maybe change the fuel filter. fingers crossed.
and yes its a 1990
Old 29th March 2011
what is PB blast?
Old 29th March 2011
Raub's Avatar
PB Blaster. Like WD-40 on steroids.
Old 29th March 2011
Banned
I said dirty and corroded not faulty. but its your cup of tea your allowed to have it your way...
Old 29th March 2011
True enough, I wasn't getting a CEL with my issue. Although if there's no AC it's a fairly quick job.
Dustin
Old 30th March 2011
Rob22315 Rob22315 is offline
My Saabs: 1993 900S
I'm going through this on my 93 900S. My closest suspect is the AIC. I was getting periodic bogging down at low throttle openings and low RPM. High RPM and/or high throttle opening seem to be OK. I cleaned the connectors at the TPS and AIC (signs of obvious corrosion on both) and the behavior of the problem changed significantly. I now only get the hesitation for a brief period during warmup. The car runs fine otherwise. Before the cleaning, I would get bogging-down symptoms unpredictably at any time.
I believe the AIC connector or motor is faulty so the it's getting less air than normal as the AIC flutters aimlessly against a showering electrical input. I don't have 100% proof that this is the problem but I think I'm close because of the above behavior change after I cleaned the connectors. I've noticed the engine continues to produce power during the bogging-down episodes so it doesn't feel like a spark or fuel problem.
Also, at high throttle opening, I don't have the problem either since any air coming from the AIC would be inconsequential.
Old 3 Days Ago
Jake Hiscox Jake Hiscox is offline
New Member
My Saabs: 1997 saab 900 se turbo convertible
I have a 1997 900se turbo, when im at low rpms it has a lot of trouble picking up, etc. pulling out into traffic, getting on the highway. When im at higher rpms though it seems to do fine. Havent started working on it yet, any suggestions on where i should start? Help is much appreciated.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
hesitation in acceleration 4saabstoomany C900 Workshop 13 13th March 2008 04:35 PM
Hesitation under acceleration - ideas? nuclear_jimbo C900 Workshop 11 10th December 2007 02:05 PM
hesitation on acceleration SPDFRK 9000 Workshop 2 27th November 2007 10:24 PM
99 9-3 hesitation upon acceleration waldo_2001 NG900 & OG9-3 Workshop 2 27th September 2006 03:20 PM
Sudden acceleration = hesitation ohird NG900 & OG9-3 Workshop 3 26th December 2004 06:26 AM
