2001 Saab 9-3 Engine and TCS warning light - SaabCentral Forums
Old 25th March 2011
ozarshad ozarshad is offline
My Saabs: Saab 9-3 Aero MY2001
Exclamation 2001 Saab 9-3 Engine and TCS warning light
I will kindly apprecaite if someone help me resolve the Engine and TCS warning light issue on my 2001 Saab 9-3 Aero.
Symptoms are
1-Engine and TCS Warning Light
2-Very Low idle
3-Unable to engage Cruise control
4-Clicking noise when inginition is turn
5-Loss of Power
Took the car to mechanic he first Change the Throttle Body (brand new) after i got the car back all symptoms reappear
Took it back and this time he changed the Airflow Meter and that didnt fix anything either.
I got the car back with me and dont know what to do now.
I can drive the car but i have to keep my foot on the accelerator and also seems to loose the power and i noticed average feul use remain constant at 11.5L/100Kms.
Please Help this is my fisrt Saab, i bought it 3 months ago.
Kind regards
Ash
Old 25th March 2011
redrider7202 redrider7202 is offline
My Saabs: 00 9-3 SE
What does the code say?
Old 25th March 2011
The fault code number os 1260
Old 25th March 2011
My Saabs: 00 9-3 SE
quick google search suggest throttle return spring is to soft
Old 25th March 2011
Thanks for your help
Is it part of the Throttle Body?
regards
Ash
Old 26th March 2011
My Saabs: 00 9-3 SE
Not a clue... just as a usual rule of thumb if u have a check engine light, check the code, it usually helps. Although a weak return spring doesn't quite sound like it would cause your problems.
Old 26th March 2011
lms's Avatar
lms lms is online now
Usually this points to a TB being bad and 9 out of 10 times a rebuilt/new one will fix it. Are you sure they replaced it, and is this a Saab shop? Your car is in limp mode like you know and you will need a code reader to clear the code because from what I have read, resetting the TB and disconnecting the battery will not do it when it comes to limp mode. First make sure there is nothing impeding the operation of the TB, take the delivery pipe off and check to see that the butterfly is closing all the way and then make sure everything in connected properly around the TB. If so, the next thing to do is reset limp mode: http://www.youtube.com/watch?v=wr_CmGp20mk
Then you have to clear the code using a scanner, if it comes back then bring back to shop if they have a tech 2 and read below..
The electronic throttle body of your car was designed with to tight of operating parameters (sometimes called good/no good values). It kind of means that if the throttle body senses a value/restriction/hesitation that is outside its preprogrammed memory of allowed deviations, it sends the system into limp home mode.
In one attempt to stop Saab dealers from throwing on new throttle bodies for no apparent reason, Saab came out with a software fix that widens the accepted parameters inside the computer to allow a bigger deviation of the good/no good values before the system goes into limp home. Have him check to see if the latest trionic update has been installed.
Old 26th March 2011
The TB is replaced with brand new one and he has clear the code as well. I will take the car back sometime next week and give the suggestion given by lms with thanks.
Will post any outcome about this when i will get the response back from mechanic.
I will ask him to check for Trionic update as well.
Once again thanks for all response.
Ash
Old 11th April 2011
coaxi coaxi is offline
New Member
My Saabs: 9.3 Aero MY2001
Ash
How did you get on with fixing the engine and TCS warning light issue? Did replacing throttle body and clearing code the fix? I've same model, same issues as you've described (just this morning), with 85,000 km on clock.
Cheers
Old 11th April 2011
Default Booked with Saab Tech
Preblem is still there
I have booked my car to be checked by Saab Tech at North Parramatta for Thursday 14th April.
I will post the outcome as soon as I get the answer from them.
Old 12th April 2011
New Member
Have my car booked in at Edgecliff to run tests (http://www.pateandvernooysaab.com.au/) Wed 13th Apr. Looks as if they may end up replacing TB (~ $AUD 1000 groan).
As "lms" posts (hi lms), Saab came out with a software fix that widens the accepted parameters inside the computer to allow a bigger deviation of the good/no good values before the system goes into limp home. Have him check to see if the latest trionic update has been installed.
And "new TB, reset limp mode, clear code using scanner".
Been through this sequence already? Upgraded trionic software? It would be interesting to see the results of updating trionic software prior to replacing TB.
Old 12th April 2011
Default Trionic Upgrade
Hi again,
They are among only handfull of techs who know about saab. I dont know about the trionic update on my car, it will be checked tomorrow.
TB is replace already I supplied to my mechanic, bought from ebay UK brand new and saves more than half of the price.
Resttting the Limp mode was the first thing he did and after clearing the code i think its p1260 it just keep coming back after 15 to min, starts with engine light followed by TCS after a while and the fuel indicator on the computer goes very high as well between 18L/100 to 33L/100 ks.
I have also invested under $20 in OBD scanner for fun and I can reset all the fault codes myself
I hope yours can be fixed by just cleaning the TB and may be the Airflow meter.
Keep me posted thanks
Ash
Old 14th April 2011
New Member
Hi again,
x
Ash
Hi Ash
Faut was P1230. Replaced with new Throttle Body (12 months part warranty), took car home all good so far, no warning lights. Asked shop about Trionic software update, and they said that I can only get it from the SAAB dealer. Left with impression that it'd be prefereable to have software update before the part replacement How'd you go today?
Cheers
Old 15th April 2011
Default Engine and TCS lights Gone
Im glad your problem is fixed so is mine
I had the same fault code from day one as well.
I got my car back from Saab Serv since I already had the TB replaced he told me that beofre resetting the fault code the Limp mode has to be cleared and only after that the code resetshould be done.
I drive my car for couple of hours today and both light have not appeared yet.
Im hoping my car is all fixed now.
My advice for P1230 code
  • Dont reset the fault code
  • Clean the Throttle Body
Engine Code 126002001 Throttle Body Cleaning
When cleaning out the throttle body you need to be sure that you reconnect the hoses leading to it correctly. If you do not get them installed fully back onto the throttle body or you pull the other ends of the hose off the turbo that will lead to stalling when letting off the throttle on deceleration. This is a very common problem with cleaning throttle body out with a toothbrush.
Throttle body Error Code 126002001 means that the traction control system is in limp home mode. With this code you must clear the code then reset the limp mode. This must be done and then the car must be driven to see if the code comes back. If it does check the big connocter on the firewall unplug it and clean the pin connocters and plug it back in. That should cure the problem unless you have a permanent fault code caused by a component failure in the system.
Obtain from ( http://www.thesaabsite.com/93/93faqs...up+information)
http://photo.platonoff.com/Auto/2004...throttle_body/
  • Reset Throttle Body Limp Mode
  • Reset Code
You can do it all yourself by purchasing ODB scanner it cost under $30.00
If the fault returns its i guess it time to replace the Throttle Body.
All the best
Happy Saab Driving
Ash
Old 27th April 2011
oli917 oli917 is offline
My Saabs: CA
Default hmm..
I have the same problem/ symptoms. I JUST bought the car. Drove it for a while.. and when I gave it the boot, TCS OFF and CEL both came on. It happened during my test drive also. But when we unplugged the battery for a while and then hooked it back up. Both lights were out, and everything was fine.
I can deduce, that this only happens when I drive the car hard. It was fine for about an hour on the highway. And when I got close to home, BAM there it went again with the two lights. So I tried resetting by unplugging the battery, and sure enough, that solved it.
So can I deduce from this that the TB is NOT in safe mode; since it would require me to reset it manually?
Old 8th July 2012
Tornadic1 Tornadic1 is offline
New Member
My Saabs: 2001 9-5 Aero
Default Video on Youtube
Thank you lms! Your video on Youtube explained perfectly how to reset the limp mode, an it really made a difference. I used it to get my 2001 Saab 9-5 Aero running and off the side of the road.
Tags
2001 9-3, engine light, idle problem, power loss, tcs light
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
HELP!! Saab 95 engine warning light. smith1 9-5 Workshop 2 9th January 2011 11:15 AM
check engine warning light on my 2001 9.3 roy sayers NG900 & OG9-3 Workshop 32 12th June 2007 03:50 PM
central warning light, flashing engine light, and battery light haedong12 9-5 Workshop 6 20th June 2006 03:56 AM
Engine warning light - on and off, on and off Cliffhanger 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 1 13th October 2004 11:12 AM
Engine Warning Light awjr 9-5 Workshop 1 24th November 2002 03:32 PM
