As you with the 6-Speed Automatics made by Aisin-Warner they require an ATF "AW-1" that is basically only available from the Dealer.
None of the usual USA mfrs are on record as providing an "equivalent"
(not Penzzoil, Castrol, Havoline, Valvoline, Quaker State, Royal Purple, Red Line, or Mobil 1, nor Amsoil)
Nevertheless, I have discovered after much searching five (5) "AW-1" ATFs that are available in the USA - and not from your local Dealer, so they're much cheaper. I've linked to their websites so you can download the spec sheets to check it out personally.
Sorry, but all of the pdfs were too big to upload!
So, in no particular order ...
This one is available from the local O'Reilly store for $7/qt
Lucas Semi Synthetic Multi-Vehicle ATF
http://www.lucasoil.com
This one is available all over the place, I even saw it in the local Walmart. But I don't know if it's in every Walmart.
Wolf's Head Universal Synthetic ATF
http://www.wolfshead.com
Wolf's Head is owned by another company names Amalie Oil in Tampa Fl.
Theirs is called Amalie Universal Synthetic ATF coincidentally
http://www.amalie.com
Another company called Total Lubricants USA out of Plano Texas
they make a product called Fluidmatic Syn NA Multi Vehicle ATF
http://www.total-us.com
but the link to their spec sheet is messed up
just google the name of the product and the pdf should come up
Then there's Full Throttle Performance Products
with a name like that how could you go wrong?
Their product is CVT Plus ATF, and it's billed as:
"Possibly the Most Universal Transmission Fluid on the Planet"
So apparently they're trying to keep the hyperbole to a minimum :roll:
http://www.ft-automotive.com
although they do make a good point about ATF on their website
...many years back there was only two ATFs on the market - now there's nine.
No wonder the ATF manufacturers can't keep up. But, I think the real reason is for the lack of certifications from the big name guys is - the bigger the ATF manufacturer - the bigger the Legal Department. So it takes longer and requires way more 3-drink Lunches for certification. The little guys are "what the hell, this meets the spec, let's sell it!"
Anyway, I hope this helps those of you like me who have been struggling to find some AW-1 equivalent ATF for your beloved Aisin-Warner AF40-6.
