Fuse box diagram - SaabCentral Forums
Old 14-03-11
KingAnthonyJr KingAnthonyJr is offline
My Saabs: 2003 Saab 9-3 ARC
Default Fuse box diagram
does anyone have a fuse box diagram for 2003 9-3 Arc?? Im really needing one right now. thanks
Old 14-03-11
HuNtS's Avatar
HuNtS HuNtS is offline
My Saabs: Silver 2003 9-3 ARC
Garage
which fuse are you trying to figure out? i can look in my owner manual, but my phone wont take clear pics of the diagram
Old 14-03-11
I am just trying to figure out if I blew a fuse when my stereo wires touched. (causing car to stall, key to be stuck in the ignition, unable to start car, ect.) but didnt want to yank all the fuses out
Old 14-03-11
HuNtS's Avatar
Garage
ill see what i can do for ya
Old 14-03-11
appreciate it
Old 14-03-11
aerojon's Avatar
aerojon aerojon is offline
http://www.extendedgmwarranty.com/ow...-Saab-9-3M.pdf
owners manual
ICM3 13sp system now with bluetooth audio streaming..
Old 14-03-11
JonV JonV is offline
Saabista
My Saabs: 03 Vector
Fuse panel in end of fascia
No. Amp. Function
1 15 Steering wheel lock
2 5 Steering column unit; ignition switch
3 10 Hands-free; cabin CD changer; SID
4 10 Main instrument unit; manual climate control;
automatic climate control (ACC)
5 7.5 Control module in front doors; Park Brake Shift Lock
(automatic transmission)
6 7.5 Brake light switch
7 20 Fascia fuse panel; fuel filler door
8 30 Control module in passenger front door
9 10 Fascia fuse panel
10 30 Trailer socket; electrical socket in storage compartment
between seats
11 15 Data link connection (diagnostics)
12 15 Interior lighting incl. glove compartment
13 30 Accessories
14 20 Radio, sound system I; control panel,
Infotainment System
15 30 Control module in driver’s door
16 - -
17 - -
18 7.5 Manual climate control; fan
19 - -
20 7.5 Headlight levelling switch
21 7.5 Hands-free; brake light switch; manual climate
control; clutch pedal switch
22 30 Cigarette lighter
23 40 Cabin fan
24 7.5 Airbag control module
25 - -
26 5 Yaw sensor (cars with ESP)
27 - -
Trunk fuse panel, left-hand side
No. Amp. Function
1–5 MAXI -
6 30 Control module in left rear door
7 30 Control module in right rear door
8 20 Trailer
9 - -
10 30 Left-hand brake light; rear right turn signal; right tail
light; right reversing light; high-mounted brake light;
trailer lights
11 - -
12 - -
13 - -
14 - -
15 15 Seat heating, left seat
16 15 Seat heating, right seat
17 7.5 Autodimming rearview mirror; rain sensor; tire
pressure monitoring
18 15 Sunroof
19 7.5 Telematics (OnStar)
20 7.5 DVD player (navigation system)
21 7.5 Saab Parking Assistance (SPA); control module in
rear doors
22 30 Amplifier, sound system III
23 - -
24 10 Movement sensor; CD changer in trunk (accessory)
25 30 Electrically adjustable driver’s seat with memory
26 30 Right-hand stop light; rear left turn signal; left tail
light; rear fog light; left reversing light; license plate
lighting; trunk lighting; trailer lights
27 - -
28 - -
29 - -
Fuse panel in front of battery
No. Amp. Function
1 60
MAXI
Secondary air injection pump (certain models)
2 20 Fuel pump; preheated oxygen sensors (lambda
probe)
3 10 A/C compressor
4 30 Main relay
Relays
1 Secondary air injection pump
2 A/C-compressor
3 Preheated oxygen sensors (lambda probe)
4 Main relay, engine (ECM/EVAP/injectors)
Old 14-03-11
Default Nice
Originally Posted by aerojon View Post
much needed I cannot find my manual anywhere. thank u
Old 14-03-11
Smile your the man!!!!
No. Amp. Function
between seats
13 30 Accessories
Infotainment System
16 - -
17 - -
19 - -
23 40 Cabin fan
25 - -
27 - -
No. Amp. Function
1–5 MAXI -
8 20 Trailer
9 - -
trailer lights
11 - -
12 - -
13 - -
14 - -
pressure monitoring
18 15 Sunroof
rear doors
23 - -
27 - -
28 - -
29 - -
No. Amp. Function
1 60
MAXI
probe)
3 10 A/C compressor
4 30 Main relay
Relays
2 A/C-compressor
my ignition fuse was blown.. PROBLEM FIXED
Old 27-03-12
kyanox kyanox is offline
My Saabs: 96 900 S, 03 9-3 Linear
My driver doors have stopped locking/unlocking but my windows work. Any clue as to what fuses to check on these?
Old 21-10-12
krock1030 krock1030 is offline
My Saabs: 2003 9-3 ARC
Default Type of 30 Fuse
I'm definitely a newbie when it comes to any electrical stuff. I know the 30 fuse that controls a slew of tail light, turn signal functions is blown. What type of 30 fuse do I pick up? I've seen 30ATC and 30ATM and though they look the same size as the one in my car, I don't want to take the risk of having it blown in the near future.
Any help would be much appreciated!
2003 Laser Red 9-3 ARC
5-Speed Auto-manual
Born from Cessna.
Old 21-10-12
aerojon's Avatar
if it's not one of the maxi fuses it's an atm(mini fuse)
http://www.autozone.com/autozone/cat...37&isApp=false
Similar Threads
2003 linear fuse diagram Velvet Jones Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop 5 15-08-11 01:51 AM
Help Please. Need Fuse Diagram for 1994 V-6 900S Open Sky Saab 9-3 & NG900 Workshop 1 19-05-10 12:12 PM
Fuse Diagram mrwagner86 Saab 9000 Workshop 0 08-03-10 03:58 PM
Lost fuse diagram cmeens Saab 9000 Workshop 4 13-07-09 01:48 PM
1991 Saab Fuse Diagram Renaemo Classic Saab 900 Workshop 13 19-06-06 12:51 PM
