Removing Crank Pulley ????? - SaabCentral Forums
Old 11th March 2011
jamiessaab jamiessaab is offline
My Saabs: 89 saab coupe
Question Removing Crank Pulley ?????
Hello, I have decided to change the Crankshaft seal & the O' ring myself & save a few $$$$, What is the best way to go about it - from the top of engine looking down or from underneath working up - as i was under the Saab a few weeks back & had trouble getting my hands to the crank pulley !!!! I was going to replace my Crank pulse sensor but i think i will just give it a good clean & inspection, What size socket is the Crank bolt ???? Thanks.
Old 11th March 2011
dmgb5's Avatar
dmgb5 dmgb5 is offline
dmgWarden
My Saabs: '89 900 T16Spg, '97 9000 Aero
Garage
Replaced the pulley working from above. You will need a 30mm socket, a breaker bar, a flywheel lock tool, some patience and couple pints for when you finish.
This is a great tutorial... http://www.twinsaabs.com/900_repair/...o.asp?nsteps=5 I followed it step by step my first time replacing the pulley.
Old 11th March 2011
rawill's Avatar
rawill rawill is offline
My Saabs: 06 93 2.0,93 9000griffin 92 900s LPT vrt
Great link - but not an easy job to d. Would it be easier to take the engine and trans out?
03 V6 Renault Laguna! 06 93 Linear 2.0t, 93 9000 griffin 2.3 St-II. 93 9000CSI na man,350,000km. 92 900 S LPT vert.
Old 11th March 2011
peva's Avatar
peva peva is offline
My Saabs: '94 T16 Ruby 3dr, '93 T16 Ruby Vert.
You've got to be joking.
Old 11th March 2011
SpecialTool's Avatar
SpecialTool SpecialTool is offline
My Saabs: '88 Aero, '88 vert
Good luck Jamie. Most overseas how-tos say you have to cut down a 30mm socket to fit but I found the standard Sidchrome 30mm socket (P/N 14247) fits fine.
Whale oil beef hooked
Old 11th March 2011
Wink
Thanks......... Yes it looks like a pain in the *** job but it will save me a couple of hundred $$$$, As i need to visit the Saab wreckers for a blinker arm & wires - there's $50 to $100 there so the $$$$ i save on doing crank seal / O'ring will pay for that, i have a couple of days free so i will start on it this Tuesday, will post if I get stuck.
Old 11th March 2011
d_ames117 d_ames117 is offline
My Saabs: 92 900T Convertible, 08 9-3 2.0T
You can save yourself some aggravation by bracing a breaker bar against something (say the ac compressor or shock tower) and bumping the starter (briefly!) to release the bolt.
Edit: Some years have a 27mm bolt, like my 92, but I'm not sure when the crossover happened.
Dustin
Old 11th March 2011
Raub's Avatar
Raub Raub is offline
My Saabs: Now: '93 900s 3dr. Then: '87 900T16 (x2)
Originally Posted by jamiessaab View Post
As i need to visit the Saab wreckers for a blinker arm & wires.
What is the issue with your turn signal stalk? If it is not staying engaged to the right or left, you can fix that pretty easily by disassembling the stalk.
Old 12th March 2011
Wink
Can I ????? I did take it out & have a good look at it, as its all loose - when i put the right blinker on I have to hold it up other-wise it will drop down & go off, It sounds like it has 2 ball bearings inside that hold it in place when you turn- as i can hear the click, would i have to drill thru those 2 holding spots on the back of it to get to the inside of it, I did fix the passenger side power window switch by taking it apart so i might try the blinker stalk...............
Old 12th March 2011
Raub's Avatar
Yes, you drill out those 2 "rivets" and the stalk will come apart. There is a little wheel at the end that falls into grooves when you put the signal on. Those grooves get worn. You just make them a little deeper with a dremel or similar tool. Then use 2 small screws to put it back together. They don't have to be pretty, they just have to hold it together. I use #4 x 3/8" metal screws. It will work like new when you're done.
Old 12th March 2011
crwchf01's Avatar
crwchf01 crwchf01 is offline
My Saabs: Menagerie of 19 and climbing
Change for bolt size (30 to 27mm) occurred around 88. Of course a PO may have changed a pulley and used the first bolt they could find (naaaaaaaaaahhhhhhhhh, never could happen).
It's too late for blind faith and ignorance.... gotta get a bigger hammer.
Old 12th March 2011
dmgb5's Avatar
dmgWarden
Garage
I am pretty sure bolt size changed in 91' from 30mm to 27mm.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Crank pulley 900t C900 Workshop 7 5th January 2011 04:01 PM
Removing Crank Pulley Jssaab 9-5 Workshop 9 10th November 2009 02:38 PM
crank pulley? (I know I know not again) ziddey C900 Workshop 7 6th April 2009 01:29 PM
Can't Get crank pulley on rabraker C900 Workshop 6 29th March 2009 11:19 AM
Crank Pulley smckinley C900 Workshop 10 18th March 2004 12:12 AM
