Engine blowup - SaabCentral Forums
Go Back   SaabCentral Forums > Classic Saab 900, 1979-1993 & 94 Convertible > Classic Saab 900 Performance, Mods & Tuning
Classic Saab 900 Performance, Mods & Tuning Covers Tuning & Performance modifications for the Classic Saab 900
Old 05-05-02
Eric van Spelde Eric van Spelde is offline
Engine: 2,500 kms 'old' 2.1 litre bored & balanced bottom end. Rebuilt '87 B202 cyl. head.
Symptoms: all of a sudden, clouds of blue smoke from tailpipe on full-boost accelaration. Looked under bonnet: throws out oil through the filler tube. Lost close to 1 quart of oil within 60 miles, and also a fair bit of coolant. White 'mayonaise' stuff in the top part of the dipstick tube, so coolant is mixing with engine oil. Traces of oil leaking onto turbo heat shield. Both crankcase breather hoses look OK, aerospace grade check valve fitted in smaller of the two lines
Seemed to run OK otherwise on limping home, but idled a bit lower than usual and sounds just ever so slightly different than usual, indicating that it might not have even compression on all four cyls. Had to move the car today and it barely idled at all. Idled perfectly smooth and went like sh*t off a shiny shovel before this happened. Did use a fair bit of oil, though, and there were some whezing sounds at certain rpm's/loads,and some tapping noises on idle.
Methinks the headgasket has blown and oil is leaking into one or more cylinders when under boost. But would that alone cause such enormous crankcase pressure? And what would cause a professionally installed head gasket to fail in under 2,000 miles, given that I'm running fairly moderate boost now (although before, APC would allow 'beyond red' boost.)
I'm baffled and frustrated.
Any help?
TIA,
Eric
Old 05-05-02
87SPGIN 87SPGIN is offline
well u definetely are having problems sealing the compression for each cylinder, did u use new head bolts for the head job or not....When the head gasket is blown it allows compression into the coolant system which will build up enough pressure to blow one of the weakest hoses in your system and also allow pressure to get into the oil system which causes the "mayo" that is coolant mixed with and compressed with oil now about the oil spraying out of the fill tube over full oil level or enough coolant in the oil pan that it moves the oil up reil floats on water..and therefore ruins your mains!!!!( not a good thing at all!) well that should answer that feel free to ask anything else
Old 05-05-02
oh sorry the oil on the turbo shield is caused either by an increase in oil pressure hence it leaks at the weakest spot,and or there is an o-ring in the dist that keeps oil in and its not doing its job so replace it mine i had to cut off w/ a knife it was rock hard.
Old 06-05-02
Janne Selinummi Janne Selinummi is offline
Oh dear!
I really hope it's nothing but a blown head gasket. Eric, all good wishes for you and your lovely car!
Old 06-05-02
Alex's Avatar
Alex Alex is offline
My Saabs: 3dr c900 T16RA, 9-5 Aero Estate
Have you checked the check valve isn't gunged up with oil. The Norgren valve used by Trent is smaller than the standard Saab unit.
Old 12-05-02
Keith Keith is offline
Could it be blowpast on a broken piston ring?
