9-7x oil change - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9-2X, 9-4X & 9-7X > 9-7X Workshop
9-7X Workshop 9-7X Technical Forum
Old 26th February 2011
WhiteSaab95 WhiteSaab95 is offline
My Saabs: 2008 Saab 9-5
Default 9-7x oil change
What type of oil is needed for a 9-7x 5.3i. every saab tells me a different story. my service place has been using regular, and now i changed my service spot, and they say its synthetic...whats the real deal. can anyone help me out?
Old 27th February 2011
chiller chiller is offline
My Saabs: Saab 9-7X 5.3
I always just put Synth into mine... from day 1... but I do that for all my vehicles...
Old 2nd March 2011
1BAD97X 1BAD97X is offline
My Saabs: 2007 Saab 97X (5.3l Altitude)
Me too. Mobil 1 synthetic on ALL my cars.
Old 22nd April 2011
Road Ghost's Avatar
Road Ghost Road Ghost is offline
My Saabs: Saab 9-7X 5.3i (not anymore)
I put synthetic in and it burns more in 3000 miles than regular oil. And I only have 65,000 miles. Don't notice obvious oil burning.
Old 22nd April 2011
saabmeatball saabmeatball is offline
My Saabs: 2007 9-3 2.0T
it is a known problem that the vortec 5.3 burns oil and that gm says 1qt per 2000 miles is normal.
i have read it has something to do with the cylinder deactivation.
Old 23rd April 2011
Road Ghost's Avatar
Yeesh! I should have done more research on this engine! Burning oil, unless abused or high mileage, should not be normal. Thanks GM!
Old 23rd April 2011
Yeah, I didn't know until recently. I was wondering where 1 qt of oil was going, no drip, no leaks, no smoke. weird.
That is what I found. I orginally thought it was maybe the valvoline oil I was using but changed to Penz Plat, may move to a high mileage oil to see fi that helps.
if someone uses the olm that goes off at about 7500 miles, they could be down 2-3 qts.
Old 23rd April 2011
Road Ghost's Avatar
Funny thing is, I did notice the very odd puff of blue smoke out the tail pipe on the highway when I had the full synthetic in. But it was so random, I couldn't make it happen. I started to get concerned about piston rings, leaky valves and clogged PCV. Regardless thats how I found to be low on oil before doing a change (to normal 5w-30).
This damn DOD is a decade behind my wife's Jeep Grand Cherokee 5.7 Hemi, which not only doesn't use any oil (@ 120,000 miles) but the deactivation is whisper quiet and doesn't rattle around like an old clunker whilst coasting.
Old 23rd April 2011
I think I posted about smoke about a year ago, I saw it once or twice.
I have not seen it since switching to Pen Plat.
Not sure if this can be fixed? I am under CPO warranty still...
Old 24th April 2011
Road Ghost's Avatar
I have an extended warranty on my used purchase, but until its doing it consistently, I won't worry about it just yet. Just have to keep an eye on it.
Old 30th April 2011
I found this:
UPDATE: TSB 10-6-01-008A
10-06-01-008a
#10-06-01-008A: Engine Oil Consumption on Aluminum Block Engines with Active Fuel Management (AFM) ( Install AFM Oil Deflector and Clean Carbon from Cylinder) - (Sep 28, 2010)
Subject: Engine Oil Consumption on Aluminum Block Engines with Active Fuel Management (AFM) (Install AFM Oil Deflector and Clean Carbon from Cylinder)
Old 30th April 2011
Road Ghost's Avatar
I found this:
10-06-01-008a
Cool! So does that mean I can get it fixed for free?
Since I went to regular 5w-30 its been a lot less burning, but still!
Old 8th May 2011
i guess you can try, let me know how it goes!
I kept Pen Plat in the truck this time around I will see how it goes.
Old 8th May 2011
TC's Avatar
TC TC is offline
My Saabs: T5 9-3, 9000 Aero, 9-7X
Glad I have a 2005 which does not have the deactivation. I have almost 90K on mine and it doesn't burn any.
And the beat goes on...
Old 8th May 2011
mikeucr mikeucr is offline
My Saabs: None anymore
Me neither. I change the oil every 5k miles and it might go through MAYBE 1/4 of a quart. Thats nothing.
Also, I run regular dino oil. I only run synthetic if the car calls for it. I am at 90k miles and the engine is running fine.
Old 8th May 2011
it doesn't ? I thought all years of 97x have DOD ?
Old 8th May 2011
I am not sure if the 2005 could have the v8, but I could be wrong.
I will try dino next time, I had a similar problem with a Honda CR-V, syn would just leak though the oil pan gasket, regular dino, nothing.
Old 9th May 2011
TC's Avatar
TC TC is offline
The 2005 V8 does not have deactivation, they added it in 2006
Old 9th May 2011
according to here the 97x had the LH6 motor in it ... the older LH4 motors are in the pre 05's... or is it the 05's have the LH6 motor but just no DOD ?
http://en.wikipedia.org/wiki/GM_Vortec_engine
Old 10th May 2011
Dirty 30's Avatar
Dirty 30 Dirty 30 is offline
My Saabs: '08 Saab 9-7x Aero
GM LSx Vehicles are notorious for burning oil coming through the PCV system. What I did on mine was to install an LS3 valley cover with the PCV provision on it. Then block off the nipples on the valve covers and only run the one from the valley cover. Oh wait, that's for NON-DOD V8's. You'd have to eliminate the DOD in order to use the LS3 valley cover. Which by the way, I eliminated the DOD on my wifes '06 Envoy Denali with the 5.3L LH6 and MPG didn't change (probably gained some instead). HP also went up with the "LS6" cam that I put in it.
I use only Mobil 1 synthetic 5w30 and Mobil 1 oil filter.
'08 Saab 9-7x Aero - 11.9 @ 111 mph
'99 30th Anniversary Trans Am
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
shuddering tranny, to change or not change fluid, please adivse limmerbr 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 6 7th July 2010 05:47 PM
cSlave cylinder change or not to change that's my question! 007GSAAB NG900 & OG9-3 Performance, Mods & Tuning 5 10th April 2009 03:44 PM
Timing Chain Change: To change the guides and sprocket too? vbadoni91 C900 Workshop 18 18th August 2006 09:46 PM
clutch change and head gasket change - what parts? gazraa 9000 Workshop 26 16th May 2005 12:23 PM
O2 Sensor - Change or not Change Armando C900 Workshop 3 5th December 2002 09:43 PM
