Girlfriend wont ride in my car. No Heat. No ACC codes. Losing GF - SaabCentral Forums
Old 19-02-11
DJJames DJJames is offline
My Saabs: 1999 Saab 9-5
Default Girlfriend wont ride in my car. No Heat. No ACC codes. Losing GF
I am getting pretty frustrated with my 9-5 because I still have no heat. I finally fixed all of my ACC error codes by replacing the heater box. I also replaced the heater core while I was in the area. I still have no heat. I have messed with the coolant bypass valve to try to get coolant into the heater core. One side of the heater core is very very hot and the other is noticeably less. What could be causing this, an air bubble in the new heater core?
any ideas would be appreciated. I spent many hours looking thru this site and the WIS and alldata and still haven't found a solution
if i shut off the heat for a few seconds when the car is running warm, both of the heater core pipes become very hot but when i turn the heat back on, one of the heater core pipes becomes slowly colder. Where my heat is going??
Old 19-02-11
domer94's Avatar
domer94 domer94 is offline
My Saabs: looking to get back in the game
try blowing compressed ait onto the coolant resservoir , cup your hand tight as you can around the openning and pressurize it with the hose. it may force the coolant through the system enough to knock out any airbound point. just remember to have your heater set to full heat before hand. you may notice a large burp back through the system ... then youll know. also check to see of your hoses are all connected back up correctly i.e. your line to the heater core or bypass valve isnt mixed up with the return end etc etc .
2005 JAGUAR S-TYPE - RACING GREEN
1989 900 CONV RED / TAN / BLK TOP
2004 MAZDA 6S WAGON -(COOL) FAMILY TRUCKSTER
1974 MGB - PURPLE!
Old 19-02-11
zachc's Avatar
zachc zachc is offline
My Saabs: 01' 9-5, 91' 9000 5spd stg 2
Garage
could be a bad thermostat. does your needle ever get to halfway and drop? or not get to the halfway mark at all?
my heat worked like crap then i put a new T-stat in and its blazin.
I <3 SAAB, so i tattooed the Griffin on my arm.
http://www.cardomain.com/ride/389851...bo-cd-sedan-4d
Old 19-02-11
@Domer94: I don't have access to compressed air in my home garage, I will try that either later tonight or maybe tomorrow.
@Zachc: I am pretty sure my t-stat is okay because my motor is very warm and one of the heater core lines gets really hot but I have not ruled out replacing it again yet but want to further explore other options first.
I am pretty sure my temp stays in the middle of the operating range after a couple minutes of driving, have never noticed it dip down at all but will keep an eye on it. Will be driving it in an hour or so.
Old 19-02-11
9-5Aero22's Avatar
9-5Aero22 9-5Aero22 is offline
My Saabs: BSR stg.III 9-5 aero
take both hoses off that are leading to the heater core and take a garden hose and spray a good stream through one of the holes. water should flow out of the other side. if it doesnt you have an issue still inside. try this out and put it all back together to see if it helps.
Current Mods: Stage III BSR tune, K&N intake, Taliaferro intake pipe, forge BPV, dual 3" flowmaster exhaust, custom FMIC, Bilstein Sports, sub-frame brace, poly trans mount, HID headlights/foglights, debadged hood, and other little stuff here and there....
Old 20-02-11
SaabDozer SaabDozer is offline
My Saabs: 1999 9-5 SE Halfbreed
Garage
Get a new girlfriend
Old 20-02-11
scoobdude scoobdude is offline
My Saabs: 9-5
What you need is a hotter girlfriend to keep you warmer.
Old 20-02-11
Saab_Sweetheart Saab_Sweetheart is offline
My Saabs: 98 900s Turbo 3-Door
Buy her a Snuggie (and a winter jacket, hat, gloves, scarf, well you get the idea)
That is what I wear when I ride in my ex's 68 bug with no heat.
Old 20-02-11
Haha I told my GF about this thread I started. She frowned when I showed her the post "get a new girlfriend" so we concluded that I would post one of her twit pics.
http://twitpic.com/3zk48p
Old 20-02-11
Back to my car: didn't notice the heat gauge going down at all (stays a 9 o'clock)
I think I switched the hoses on the bypass valve before I replaced the heater box and put the vacuum line directly to the valve to activate it. So there should be coolant going thru it but maybe it doesn't flow as efficiently as the correct path?
Old 20-02-11
Jssaab Jssaab is offline
My Saabs: 2000 9-5 320hp, 2003 Aero Hirsch "Clone"
Ok the girl is hot we can rul ethat out as a problem..
Needs to be in tthe right orientation to work correctly..
Did you buy a new heater box ( or a used one?) may have added a new problem with that...
Stepper motors don;t give codes ( except on Tech II) and a jamed flap from a broken shaft ( probably your issue) can burn out or make the stepper shaft slip ad not correct your airflow ...
Old 20-02-11
The heater box is brand new. I found a great deal on eBay for just under 300 shipped and it included 2 of the motors which were also brand new.
Old 20-02-11
CKING CKING is offline
Reminds me of my 1969 Karmann Ghia with no heat...I bought one of those plug in heater from my GF at the time...of course she was so hot that she kept the car warm
Old 20-02-11
Chris74 Chris74 is offline
My Saabs: 04 9-3, 230K...
I'd bet the hoses are swapped on the bypass valve. I did that and had no heat for two days...
If you think it is the thermostat, let it get hot then crank the heat. If the needle drops, I'd replace the thermostat, too.
Old 20-02-11
Sounds like its the hoses swap em as stated. DId you re-calibrate the air box once you got it in?
Old 20-02-11
Yes I recalibrated the ACC like 6 times, no codes at all anymore.
Old 20-02-11
Swap the hoses and report back,
Also did it stop being warm when you swapped the t-stat before?
Old 21-02-11
Tailspin's Avatar
Tailspin Tailspin is offline
My Saabs: '01 9-5 Stg1, 08 9-3, '89 C900LM
I did this too, very easy to do. Swapped them back and huzzah heat!
24hrs of LeMons SAAB 900 project: The Carbeque Updated 3/21/13
We beat Emanuele Pirro (driving a Porsche) at Road America in a SAAB, while cooking BBQ ribs in the engine bay. Fourth in class, first in total badassery.
Old 21-02-11
ChattySaaby's Avatar
ChattySaaby ChattySaaby is offline
My Saabs: 2003 9-5 Aero Wagon 5-sp manual
The online instructions I used when I replaced my bypass valve warned about crossing the hoses (with the consequence being no heat), and suggested that the hoses be clearly marked so reinstallation would be clear. I did as suggested and my valve replacement went off without a hitch.
Old 21-02-11
ppetree ppetree is offline
My Saabs: 2001 9-5 SE, 178,000 miles
Just what I was thinking... certainly be cheaper than the parts needed to fix your heater! LOL
Phil "Pete" Petree
www.thesocialstop.com
Similar Threads
No Heat. error codes 0 then heat comes on cmesposito Saab 9-5 Workshop 3 31-10-10 10:06 PM
Engine heat wont allow car to start? DuffyS aab Saab 9-5 Workshop 18 28-07-09 03:39 PM
Still Wont Start, Here's some Codes... KaMiKaZi_t0M Saab 9-3 & NG900 Workshop 14 01-08-08 01:39 PM
It's wont heat up quick4door Classic Saab 900 Workshop 5 09-01-04 01:18 AM
wont shift? rough ride, 92 900 turbo coupe vertiblechickmag Classic Saab 900 Workshop 9 22-12-03 12:28 PM
