How To - Ignition Switch Module Removal - SaabCentral Forums
Old 16th February 2011
MyersGraphics MyersGraphics is offline
My Saabs: 2003 9-3 Linear 2.0 Sport
Default How To - Ignition Switch Module Removal
Hello everyone, I underwent removing my Ignition Switch Module (ISM) this winter and thought that this might come in handy. Hope that it helps!!
As always, a disclaimer: I take no responsibility with any damage done by following these directions
First, let me just say that this problem comes in different varieties and sometimes replacing the ISM alone won't fix your entire problem. I would read this: http://www.saabcentral.com/forums/sh...ferrerid=72235 as well as other write ups and websites regarding ISM issues to narrow down similar situations.
Some things to consider:
Battery issues (low charge, not holding a charge, etc.) can cause some trouble with the Ignition System on Saabs (and I'm sure other makes). If you have the original "Low Maintenance", you can top off the cells with distilled water and recharge the battery to regain some charge holding capability and circumvent some issues. I would try this first, just to make sure!
Certain components in the ignition system require a Tech II device to work at all, however the ISM does not require programming by Tech II Device.
Even thought it costs money, take it in and get it diagnosed on a Tech II device.
In my situation, after replacing the ISM and not having any luck I took it in and got it diagnosed. I found out then that the SCL was malfunctioning as well. I did save money by doing the ISM replacement myself (cost of part only, no labor), but I still had to pay to get the SCL replaced ~$800 ($100 was for Tech II diagnosis).
With regard to this write up on ISM removal, I paraphrased my response since it's been a little while from when I actually did it. I may not have all of the steps here, so if you find something not working shoot me a PM and I'll usually be able to respond in a reasonable amount of time. I'll try to edit this document as necessary.
Images reference the approximate position of certain screws and components. Use these images as a guide (images are stock images, not my car). Certain circles show the position of screws underneath other components, so use your brains here.
I'll format my response as this: what to do and (# in image) - how to do it.
  1. Remove the coin tray rubber mat (1). - use very fine screwdriver or finger nail, peels right up.
  2. Remove two torx screws underneath coin tray mat. (2)
  3. Remove plastic frame (goes around gear shift and ignition switch). (3) - I think that this just pulled up...
  4. Remove torx screw at base of shifter. (4) – Located at the 6 0'clock position from the “Drive” position of the shifter (automatic, obviously...).
  5. Remove the plastic components around the shifter. (5) - There are two pieces held together in a strange way, so make sure to note their configuration before removing them as this will make it easier to put back together!
  6. Remove cover underneath parking brake and “cd holder” cover and remove torx screws. (6 & 7) - Cover underneath parking brake pulls out towards driver seat, “cd holder” cover (opposite side of parking brake) pulls up and off.
  7. Remove rubber mat inside center console and remove two torx screws underneath. (9)
  8. Move seats all the way back and remove two torx screws and remove front side kicker panels (underneath plastic caps). (8a, 8b, 8c) - Squeeze the cap and it's hinge to remove, avoid prying; easily removed if done right. Panels slide backward and down to remove.
  9. Move seats all the way forward and remove plastic component at rear of center console (it holds the ashtray and is underneath rear heater vents). – While in front seat, face backwards and place fingers on both sides of component (in between the seats, and below rear heater vents) and push it backwards; it just snaps out (this is quite difficult to explain without pictures, but it is a quite simple procedure).
  10. Remove rear side kicker panels. (11) – These are literally between the center console and the seats, they simply pull out backwards.
  11. Move seats all the way back and locate two torx screws just below ignition, on both sides of the console. (10) – These are the most difficult torx screws to remove as the seats prohibit tool movement, but they are the last two!!
  12. Remove center console frame, making sure to remove all wires connected to it while doing so. – There is the Parking Brake sensor, the ISM wiring harness, and I believe one other nondescript wire I believe...
  13. Replace ISM
  14. Reverse directions to complete
I hope that this helps!! Again, please critique my work and let the community know if some steps need revising!
Alex
Nocturne's Avatar
Nocturne Nocturne is offline
My Saabs: 2005 SAAB 9-5 Aero fully loaded
Garage
Thumbs up
Great job - Mods, can this be moved to the how to section? It'll come in handy.
2004 9-3 Linear Fully Loaded - R.I.P July 28 2015
2005 Saab 9-5 Aero Fully loaded
Old 17th February 2011
pkny102's Avatar
pkny102 pkny102 is offline
My Saabs: 03' 9-3 Arc Stage 1
Nice write up, did you notice anything underneath or around the shifter that can produce a buzzing/rattling noise? i want to see if that the culprit to my buzzing sound seemingly coming from that area.
Old 20th February 2011
Thanks Nocturne. pkny102: I didn't notice anything that would necessarily rattle unless something came undone. Do step 8 and you could have a good amount of access to see what's going on underneath there. Good luck!
Old 11th June 2011
Bdeschler Bdeschler is offline
New Member
My Saabs: 04 93 sports sedan
Used these instructions today. Got the ignition switch in 2 days after ordering online for 100. I was doing this to eliminate steering lock malfunction message, and so far so good. Instructions were so good, my 8 year old daughter helped me do it. Thank you!
Old 11th June 2011
dzlsabe dzlsabe is offline
My Saabs: 06 93 TiD Combi, #2 TiD Combi Running
Ive done quite a few of these now and have gotten it down to about 20 minutes. 1) Disconnect - battery cable. 2) Slide L (US driver) seat back all the way. 3) Remove T25 under cap and slide console cover panel out. Release the PurpleU and disconnect harness and move aside. 4) Release (push in) the two left side stainless catches on the ISM and push down. 5) Remove ISM. It will be necessary to push the switch into the plastic air duct slightly, but there is enough "give" in the duct. Disconnect the wiring harness on the ISM. 6) Install is the reverse. Just be careful sliding the new ISM in as the rubbery covering around the fob/keyhole wont endure much force. Cover with a plastic bag if desired.
Only US diesel?? 03 93 Cosmic Blue
Also Black 06 93 Combi, White 89 900TCV
Old 30th January 2012
Jat007 Jat007 is offline
My Saabs: Black 2002 Saab 9-5
What's the part number that you ordered online for $100. WD-40 is no longer works on my ignition switch.... SO, I need to replace my really soon...
You can e-mail me directly xmdms@yahoo.com
Thanks,
Jay
Old 24th March 2012
Svenpup Svenpup is offline
My Saabs: 2007 9-3 Aero Sportcombi
i just did this on my '07 Aero manual and noticed a few differences.
Step 2: There were no torx screws here, so I skipped this step.
Step 4: There were no torx screws here, so I skipped this step.
Step 5: Apparently not relevant to the manual transmission.
Steps 9-12: I didn't perform these as there was enough play in the center console at this point that the ISM could be easily removed. This is a compromise between MyersGraphics instructions on this page, and the abbreviated instructions that dzlsabe and jcliff posted at http://www.saabcentral.com/forums/sh...gnition+switch
I have seen people post that the Steering Lock Malfunction can be fixed with a new battery, or buy cleaning the contacts on the ISM. I charged my battery at the same time I was removing, cleaning and replacing the ISM, so I am not sure which solved the problem, but it appears to have gone away.
Old 18th May 2012
Jenifer.andrasko Jenifer.andrasko is offline
New Member
My Saabs: 2007 9-3aero
This post has been extremely helpful, but can anyone tell me how to remove the electrical harness from the back of the IS!. I have everything else done, but can't get the ism out became I can't figure out how to release the electrical harness from the back.
Thanks!
Old 18th May 2012
aerojon's Avatar
aerojon aerojon is offline
Thanks!
another thread..http://www.saabcentral.com/forums/sh...gnition-switch
is it shown in above thread
Is still running factory oe coils with Hirsch tune..
Old 18th May 2012
New Member
Thanks aerojon, I used the post you quoted to walk through the ISM removal, but it just says remove the electrical harness and doesn't have a picture of how to do it. I just can't seem to get it off ... It's pretty small and doesn't seem to have an obvious release mechanism. I've spent nearly an hour trying to remove it ... As soon as I can get the harness off, I'm done and an remove the ISM from the car, the rest of the post and photos were so helpful, but there aren't any pics of the back of the ISM.
Old 18th May 2012
New Member
Got it! There is a lever on the top of the harness that had to be pushed forward to release.
Old 30th May 2012
SAABalingus's Avatar
SAABalingus SAABalingus is offline
My Saabs: Ltd. Edition 2008 Lynx Cabrio.
Does anybody know if the light up ism from a 2003 can be used to replace the ism in a 2004 vert? I love how the 2003 lights up the off on start positions in green like everything else. So if anyone knows I would appreciate it.
Thanx
Old 30th May 2012
Do you know if the light up switch from a 2003 9-3 ss 4 door can be used to replace one in a 2004 9-3 ss vert? I love the green backlighting.
Thanx
Old 10th July 2012
karman12 karman12 is offline
My Saabs: 2007 wagon 93 tid
Default ISM - part number ?
saab 93 2007 - Ignition Switch (ISM) - Can anyone give me the part number or help me source an ISM for my SAAB?
Im in Australia but can order and have one sent from anywhere,,,
Old 10th July 2012
jcliff jcliff is offline
My Saabs: 2006 9-3 SS
Here's a couple, don't know if they are in stock or not
Jim
http://www.thesaabsite.com/93/93ignition03on.htm
http://www.saabpartscenter.com/parts...FYao4AodIRWbFQ
Old 10th July 2012
PaulOliver's Avatar
PaulOliver PaulOliver is offline
My Saabs: 93 2.2tid Vector Sport
Thanx
I know you asked this a while ago but just add some LEDs in there, that's what's did
04 Saab 9-3 2.2 TID Vector Sport. 6K dips, 3K projector fogs, LED sides, Nav, Aero Leather, Boston S35 dash, Fli rear, Infinity doors, JL sub, hidden park sensors, pressed plates, full LED interior lights, black badges, M5 window spoiler, 08+ bridge spoiler, colour coded bump strips, washers and nav fin, Aero front splitter, Duplex straight through exhaust
Old 10th July 2012
BRob2's Avatar
BRob2 BRob2 is offline
My Saabs: '05 arc vert
Karmen, I just got one on Ebay from "BarnfindBernie". Don't let the name fool you. Good price, OE, shipped the next day and shipped very cheaply, unlike others I checked.
Old 22nd July 2012
BRob2's Avatar
For future reference, my manual convertible does have the torx screws in step 2 (labeled 2 in the diagram above), just underneath the area where the coin tray mat and the shift knob meet. FWIW, the extra give they offer is so little I don't think it is worth the time to remove them, unless you have a cabriolet where you need ever millimeter you can get to work in the very confined space.
Old 11th November 2012
SebastianG's Avatar
SebastianG SebastianG is offline
My Saabs: 2006 Saab 9-3 Aero
How do you guys put back the spring/plastic piece back? It seems when I put it back the whole lock gets stuck. Im about to give up and just order one
Tags
ignition problems, ignition switch, ignition switch removal, ism
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Ignition switch module inergen 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 30 12th June 2016 01:19 AM
1997 900 Ignition Switch Removal JaySaab08 NG900 & OG9-3 Workshop 6 11th May 2015 08:42 AM
Wanted: Direct Ignition Cassette (ignition discharge module) auk Parts for Sale/Wanted - North America 0 27th August 2010 09:21 AM
ops! she did it again, Ignition module Shinnes 9-5 Workshop 22 25th June 2008 12:31 PM
Removal of Ignition switch Gilbert Alfaro C900 Workshop 3 12th March 2006 07:19 PM
