Still has a slight miss on highway - SaabCentral Forums
Old 16-02-11
2000saab95's Avatar
2000saab95 2000saab95 is offline
My Saabs: 2000 Saab 9-5 Aero
Default Still has a slight miss on highway
After everything..you will see below. I still have a slight hiccup on my highway and the car just seems like it is lacking some pop. I am wondering if I should run some fuel injector cleaner through it. I run regular gas and have since I owned it about a year and half ago I know should have premium. Today on the way in the engine light flashed when it missed and then went off agian. Last time I checked it with a computer when it flashed and went off it didnt throw a code.
replaced plugs with platinum ngks when I changed plugs there was a gas smell when I removed end plug.
replaced maf
replaced dic
replaced oxygen sensor
replaced temp sensor
So
Old 16-02-11
mt.aero's Avatar
mt.aero mt.aero is offline
My Saabs: '02 9 Aero, '89 900S
You are trying to get peak performance out of a car that the manual suggests using premium and decide to run a lesser grade gasoline?
Does it make a rattle sound when it misses? My first guess is that you are pinging.
Old 16-02-11
2000saab95's Avatar
Default no noise
it doesnt make any noise. I am going to start using premium. I didnt relize i was suppose to be using it for a while and never felt any ill effects.
Old 16-02-11
jefspg jefspg is offline
My Saabs: 88 SPG, 2001 Aero Wagon
I would make sure your fuel lines at the pump have had the safety recall done. They can come loose and cause the symptom you describe. This happened to me and caused the exact same problem.
Also a failing engine crank sensor can cause this. This should be replaced around the 100K mark as a preventative maintenance item.
Old 16-02-11
mt.aero's Avatar
no noise is good! Couple things to do that are cheap and easy that helped with my car and its hesitation problem. Check/replace vacuum lines, clean throttle body and clean MAF sensor.
Old 16-02-11
2000saab95's Avatar
Default running
I replaced the maf already. I was told the crank sensor will just go and not have these symptoms. Would the crank sensor set off the cel. How hard of a job or how can you check the fuel line at the pump issue?
Old 17-02-11
2000saab95's Avatar
Default where to buy best gas
What are some of the best places to get gas. Since I have heard some loose discussion on this in the past. Are there certain places you think have a better gas product. Since I am going to start putting premium in it figured I would get some thoughts of what places might have the best gas.
Old 17-02-11
mt.aero's Avatar
AFAIK, the CPS wont cause a misfire, it will shut the car down completely. No CEL either. I would really clean your throttle body and replace vacuum lines though. It ought to run you about $25 and and hour total to do it all. Its a pretty easy job.
Best gas is Shell V-Power, hands down. After testing every gas company in my area, its the only brand that doesnt make my engine ping at WOT. I live at 8000 ft and drive up to 12000 so its a big concern for me.
Similar Threads
2003 Aero slight stutter/miss fire chrisgsi Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop 0 25-11-10 05:09 PM
9-3 Tid error code p0314(miss fire) but don't have a miss fire Frenchington Saab 9-3 & NG900 Workshop 0 08-10-10 08:49 AM
I'm going to miss the SS, but hello........... rabbit Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop 12 21-05-10 08:53 AM
900 Miss farnson@hotmail.com Saab 9-3 & NG900 Workshop 7 27-06-06 06:41 AM
Did I miss something? saablui Saab 9-3 & NG900 Workshop 4 05-08-05 11:55 AM
